查看: 16996|回复: 1
求大神指点!esp8266传输数据问题
发表于 2015-1-22 00:27:42 | 显示全部楼层 |阅读模式
我现在用uno板连接一个ttl摄像头,已经调试成功了,代码如下(太多,省略了后面部分),然后又连接esp8266,也调试成功了,代码就不贴了,现在问题来了,我把两个东西同时连到uno上,需要怎么样才能让摄像头输出的数据传到8266上,并发射出去呢???大神们快来帮帮忙吧!谢谢
#include <SoftwareSerial.h>
byte incomingbyte;
SoftwareSerial mySerial(4,5);                     //Configure pin 4 and 5 as soft serial port
int a=0x0000,j=0,k=0,count=0;                    //Read Starting address
uint8_t MH,ML;
boolean EndFlag=0;
void SendResetCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
  Serial.begin(19200);
  mySerial.begin(38400);
  delay(2000);
  WIFISerial.println("AT+RST");
  delay(2000);
     SendResetCmd();
     delay(4000);                               //After reset, wait 2-3 second to send take picture command
      SendTakePhotoCmd();
  if (mySerial.available()){
    WIFISerial.write(mySerial.read());
     while(mySerial.available()>0)
        incomingbyte=mySerial.read();
      byte a[32];
      while(!EndFlag)
         j=0;
         k=0;
         count=0;
         SendReadDataCmd();
         delay(25);
               k++;
               if((k>5)&&(j<32)&&(!EndFlag))
               a[j]=incomingbyte;
               if((a[j-1]==0xFF)&&(a[j]==0xD9))      //Check if the picture is over
               EndFlag=1;
               j++;
        count++;
          for(j=0;j<count;j++)
          {   if(a[j]<0x10)
              Serial.print("0");
              Serial.print(a[j],HEX);
              Serial.print(" ");
          }                                       //Send jpeg picture over the serial port
          Serial.println();
     while(1);
发表于 2015-3-1 00:29:28 来自手机 | 显示全部楼层
请教你的WiFi串口用的是Uno上面的串口通讯端口0和1吗?
还用的soft.serial软串口?
GMT+8, 2026-7-26 19:24 , Processed in 0.059487 second(s), 19 queries .
