查看: 11160|回复: 3
uno r3 供电问题,百思不得其解
发表于 2015-1-23 21:04:13 | 显示全部楼层 |阅读模式
当用USB供电时,传感器给A0口的值稳定在300左右,但使用圆孔供电口(9V层叠电池或5V移动电源、4.5V干电池等),量测A0口的值在700左右,根据传感器的特性,之前300左右是靠谱的。
换了别的传感器,也发现读数与USB供电时有很大不同。
如果圆孔供电这么不可靠,R3板的外部供电功能是不是可以无视?那如何脱离电脑USB工作呢?
发表于 2015-1-23 23:13:10 | 显示全部楼层
供电方面 应该不会出现那么复杂的问题的 我觉得最好能有12V的供电吧
发表于 2015-1-23 23:14:55 | 显示全部楼层
看arduino网站上关于UNO供电的说明如下:
Power
The Arduino Uno can be powered via the USB connection or with an external power supply. The power source is selected automatically.
External (non-USB) power can come either from an AC-to-DC adapter (wall-wart) or battery. The adapter can be connected by plugging a 2.1mm center-positive plug into the board's power jack. Leads from a battery can be inserted in the Gnd and Vin pin headers of the POWER connector.
The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may be unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
http://arduino.cc/en/Main/ArduinoBoardUno
你用5V移动电源、4.5V干电池从圆孔供电,肯定是工作不正常的。
9V层叠电池的额定电流比较小,不知道你的UNO带了什么样的负载。用这样的9V电池供电是,万用表量5V、GND间的电压有多少?和标准的5V偏差有多少?
不要轻易怀疑人家的设计问题,多想想自己用得对不对。
 楼主| 发表于 2015-1-24 13:57:09 来自手机 | 显示全部楼层
Power
The Arduino Uno can be powered via the USB connection ...
明白了,英文资料非常有用,还是我采取的电源有问题,层叠电池时,5v口只有4.6了
GMT+8, 2026-6-17 14:51 , Processed in 0.046849 second(s), 19 queries .
