查看: 11718|回复: 1
在循环中如何用按键控制暂停和继续,用的millis()函数控制周期的
发表于 2015-1-27 16:22:00 | 显示全部楼层 |阅读模式
目前在做控制步进电机的实验,正反转各10s,速度控制与周期控制都是基于millis()函数,想用按键控制程序暂停和继续。目前程序里的按键在外部中断时,由于millis()函数始终运行,所以中断时间也算在周期时间内,难点在于比如先运行3s,中断一段时间后如何继续运行剩下的7s,求各位大神帮忙指导一下,不胜感激!!!!!
int CLK1=10;
int DIR1=11;
int key=7;
boolean direct=true;
  pinMode(CLK1,OUTPUT);
  pinMode(DIR1,OUTPUT);
  pinMode(key,INPUT);
long interval1 = 1;
long previousMillis1 = 0;
static boolean SteperState1 = HIGH;
boolean key_scan()
     if(digitalRead(key) == HIGH)
          delay(10);
             { direct = ! direct;}
           while(digitalRead(key) == HIGH);
      return direct;
unsigned long timegap=10000;
unsigned long begintime=0;
int stepstat=1;
            if(!key_scan())
                 unsigned long currentMillis1 = millis();
                 if(currentMillis1 - previousMillis1 > interval1)
                     previousMillis1 = currentMillis1;
                     SteperState1 = !SteperState1;
                     digitalWrite(CLK1, SteperState1);
                  unsigned long time=millis();
                  begintime=time;
                  if(time-begintime>=timegap)
                      begintime=time;
                      stepstat=!stepstat;
                  if(stepstat==1)
                     digitalWrite(DIR1, LOW);
                     digitalWrite(DIR1, HIGH);
                 digitalWrite(CLK1, HIGH);
发表于 2016-1-10 09:44:56 | 显示全部楼层
请问你的问题解决了吗
GMT+8, 2026-7-27 11:33 , Processed in 0.045353 second(s), 18 queries .
