查看: 11104|回复: 3
Arduino pro mini下载程序不成功
发表于 2015-1-28 23:26:40 | 显示全部楼层 |阅读模式
确保连线正确,而且版型和串口号都已选择好,下载完后显示如图片所示,显示成功,但是好像根本就没下载到板子里面,请教高手这是什么原因?
发表于 2015-1-29 03:06:20 | 显示全部楼层
你可以先试一下自带的Blink程序。
  1. /*
  2.   Blink
  3.   Turns on an LED on for one second, then off for one second, repeatedly.
  4.   This example code is in the public domain.
  5. */
  6. // Pin 13 has an LED connected on most Arduino boards.
  7. // give it a name:
  8. int led = 13;
  9. // the setup routine runs once when you press reset:
  10. void setup() {
  11.   // initialize the digital pin as an output.
  12.   pinMode(led, OUTPUT);
  13. }
  14. // the loop routine runs over and over again forever:
  15. void loop() {
  16.   digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  17.   delay(1000);               // wait for a second
  18.   digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
  19.   delay(1000);               // wait for a second
  20. }
发表于 2015-1-29 10:42:01 | 显示全部楼层
如果你手头有UNO,可以用UNO来接它写入程序,又方便又安全
 楼主| 发表于 2015-2-3 20:01:51 | 显示全部楼层
谢谢大家的指点。现在已经确定,这样也是下载成功的,就是不知道为什么这样显示
GMT+8, 2026-7-26 17:37 , Processed in 0.034217 second(s), 20 queries .
