查看: 13811|回复: 2
arduino怎么用spi读从机寄存器数据
发表于 2015-2-3 14:15:22 | 显示全部楼层 |阅读模式
程序如下:
#include <SPI.h>
int RST_PIN = 4;
int SS_PIN = 10;
void LD_reset()
    digitalWrite(RST_PIN, HIGH);
    delay(1);
    digitalWrite(RST_PIN, LOW);
    delay(1);
    delay(1);
    digitalWrite(SS_PIN, LOW);
    delay(1);
    digitalWrite(SS_PIN, HIGH);
    delay(1);
uint8_t LD_ReadReg(uint8_t address)
          digitalWrite(SS_PIN,LOW);
          SPI.transfer(0x05);
          SPI.transfer(address);
          uint8_t result = SPI.transfer(0x00);
          return result;
   void LD_WriteReg(uint8_t address, uint8_t value)
            SPI.transfer(0x04);
         //   Serial.println("11111");
         //   Serial.println(address);
            SPI.transfer(value);
         //   Serial.println(value);
  pinMode(4,OUTPUT);
  pinMode(10,OUTPUT);
   SPI.setBitOrder(MSBFIRST);
    SPI.setClockDivider(SPI_CLOCK_DIV4);
    SPI.setDataMode(SPI_MODE1);
    SPI.begin();
  LD_reset();
// LD_ReadReg(0x6);
//  LD_WriteReg(0x35,0x33);
//  LD_WriteReg(0x1b,0x55);
//  LD_WriteReg(0xb3,0xaa);
  Serial.println(LD_ReadReg(0x06),HEX);
  Serial.println(LD_ReadReg(0x35),HEX);
  Serial.println(LD_ReadReg(0xb3),HEX);
 楼主| 发表于 2015-3-3 17:09:14 | 显示全部楼层
发表于 2015-3-21 23:14:57 | 显示全部楼层
读取的是什么传感器,传感器说明书,时序都没有
GMT+8, 2026-6-20 01:38 , Processed in 0.037033 second(s), 18 queries .
