研究了一晚上稍微有点成果分享下
HMC5883L使用i2c接口,接线很容易
以Arduino Uno为例:
SDA to A4
SCL to A5
Vcc to 3.3V
GND to GND
基本原理很简单:
方向角其实就是X轴和Y轴读数的反正切
而校准其实就是要排除环境中的磁场对地磁场的干扰
另外别忘了当地的磁偏角
如下代码没有使用专门的传感器库
上电后先进行20秒校准,请把传感器任意乱转,各个方向都要转到
然后就会显示校准值,然后持续显示初始值和方向角
不知道怎么在ide里面用中文写注释,所以就保留英文了
个人测试下来和手机上的指南针相差不超过5度,更精细的校准待研究
刚刚接触Arduino,望高手指教
- #include <Wire.h> //I2C Arduino Library
- #define address 0x1E //001 1110b(0x3C>>1), I2C 7bit address of HMC5883
- #define MagnetcDeclination 4.43 //Shanghai
- #define CalThreshold 0
- int offsetX,offsetY,offsetZ;
- void setup()
- //Initialize Serial and I2C communications
- Serial.begin(9600);
- Wire.begin();
- //Put the HMC5883 IC into the correct operating mode
- Wire.beginTransmission(address); //open communication with HMC5883r
- Wire.write(0x00); //select configuration register A
- Wire.write(0x70); //0111 0000b configuration
- Wire.endTransmission();
- Wire.write(0x02); //select mode register
- Wire.write(0x00); //set continuous measurement mode:0x00,single-measurement mode:0x01
- calibrateMag();
- void loop()
- int x,y,z; //triple axis data
- getRawData(&x,&y,&z);
- //Print out values of each axis
- Serial.print("x: ");
- Serial.print(x);
- Serial.print(" y: ");
- Serial.print(y);
- Serial.print(" z: ");
- Serial.print(z);
- Serial.print(" angle(x,y): ");
- Serial.println(calculateHeading(&x,&y,&z));
- delay(250);
- void getRawData(int* x ,int* y,int* z)
- //Tell the HMC5883L where to begin reading data
- Wire.write(0x03); //select register 3, X MSB register
- //Read data from each axis, 2 registers per axis
- Wire.requestFrom(address, 6);
- if(6<=Wire.available()){
- *x = Wire.read()<<8; //X msb
- *x |= Wire.read(); //X lsb
- *z = Wire.read()<<8; //Z msb
- *z |= Wire.read(); //Z lsb
- *y = Wire.read()<<8; //Y msb
- *y |= Wire.read(); //Y lsb
- int calculateHeading(int* x ,int* y,int* z)
- float headingRadians = atan2((double)((*y)-offsetY),(double)((*x)-offsetX));
- // Correct for when signs are reversed.
- if(headingRadians < 0)
- headingRadians += 2*PI;
- int headingDegrees = headingRadians * 180/M_PI;
- headingDegrees += MagnetcDeclination; //the magnetc-declination angle
- // Check for wrap due to addition of declination.
- if(headingDegrees > 360)
- headingDegrees -= 360;
- return headingDegrees;
- void calibrateMag()
- int xMax, xMin, yMax, yMin, zMax, zMin;
- //initialize the variables
- xMax=xMin=x;
- yMax=yMin=y;
- zMax=zMin=z;
- offsetX = offsetY = offsetZ = 0;
- Serial.println("Starting Calibration......");
- Serial.println("Please turn your device around in 20 seconds");
- for(int i=0;i<200;i++)
- //get Max and Min
- // this routine will capture the max and min values of the mag X, Y, and Z data while the
- // compass is being rotated 360 degrees through the level plane and the upright plane.
- // i.e. horizontal and vertical circles.
- // This function should be invoked while making continuous measurements on the magnetometers
- if (x > xMax)
- xMax = x;
- if (x < xMin )
- xMin = x;
- if(y > yMax )
- yMax = y;
- if(y < yMin )
- yMin = y;
- if(z > zMax )
- zMax = z;
- if(z < zMin )
- zMin = z;
- delay(100);
- if(i%10 == 0)
- Serial.print(xMax);
- Serial.print(" ");
- Serial.println(xMin);
- //compute offsets
- if(abs(xMax - xMin) > CalThreshold )
- offsetX = (xMax + xMin)/2;
- if(abs(yMax - yMin) > CalThreshold )
- offsetY = (yMax + yMin)/2;
- if(abs(zMax - zMin) > CalThreshold )
- offsetZ = (zMax +zMin)/2;
- Serial.print("offsetX:");
- Serial.print("");
- Serial.print(offsetX);
- Serial.print(" offsetY:");
- Serial.print("");
- Serial.print(offsetY);
- Serial.print(" offsetZ:");
- Serial.print("");
- Serial.println(offsetZ);
- delay(5000);
把冗长的数据手册读完了,有人想看的话,可以把自测试模式,空闲模式等的使用方法也写一下
参考资料:
https://www.sparkfun.com/tutorials/301
