查看: 11323|回复: 4
数码管累加器
发表于 2015-2-15 09:42:42 | 显示全部楼层 |阅读模式
//按一下按键数码管加一
#include<Arduino.h>
#define a 2
#define b 3
#define c 4
#define d 5
#define e 6
#define f 7
#define g 8
#define h 9
#define com1 10
#define com2 11
#define com3 12
#define com4 13
#define an_jian 1
char anxia = 1;
char s = 0;       /*随便定义的变量*/
unsigned char tiaodeng[][8]=
        {0,        0,        1,        1,        1,        1,        1,        1},
        {0,        0,        0,        0,        0,        1,        1,        0},
        {0,        1,        0,        1,        1,        0,        1,        1},
        {0,        1,        0,        0,        1,        1,        1,        1},
        {0,        1,        1,        0,        0,        1,        1,        0},
        {0,        1,        1,        0,        1,        1,        0,        1},
        {0,        1,        1,        1,        1,        1,        0,        1},
        {0,        0,        0,        0,        0,        1,        1,        1},
        {0,        1,        1,        1,        1,        1,        1,        1},
        {0,        1,        1,        0,        1,        1,        1,        1}
  for(unsigned char z = 2; z <= 13; z++)
    pinMode(z,OUTPUT);
  pinMode(an_jian,INPUT);
  digitalWrite(an_jian,HIGH);
  if(jian_ce() == 1)
    s++;
    if(s > 9999)
        s = 0;
  shumaguang(1,s/1000);
  delay(2);
  shumaguang(2,s%1000/100);
  delay(2);
  shumaguang(3,s%100/10);
  delay(2);
  shumaguang(4,s%10);
  delay(2);
unsigned char jian_ce()
  if(anxia == 1 && digitalRead(an_jian) == LOW)
      anxia = 0;
      delay(1);
      if(digitalRead(an_jian) == LOW);
          return 1;
  if(digitalRead(an_jian) == HIGH)
      anxia = 1;
  return 0;
unsigned char shumaguang(unsigned char com,unsigned num)
  digitalWrite(a,LOW);
  digitalWrite(b,LOW);
  digitalWrite(c,LOW);
  digitalWrite(d,LOW);
  digitalWrite(e,LOW);
  digitalWrite(f,LOW);
  digitalWrite(g,LOW);
  digitalWrite(h,LOW);
  switch(com)
    case 1:
            digitalWrite(com1,LOW);
            digitalWrite(com2,HIGH);
            digitalWrite(com3,HIGH);
            digitalWrite(com4,HIGH);
    case 2:
            digitalWrite(com1,HIGH);
            digitalWrite(com2,LOW);
    case 3:
            digitalWrite(com3,LOW);
    case 4:
            digitalWrite(com4,LOW);
    default:break;
   digitalWrite(a,tiaodeng[num][7]);
   digitalWrite(b,tiaodeng[num][6]);
   digitalWrite(c,tiaodeng[num][5]);
   digitalWrite(d,tiaodeng[num][4]);
   digitalWrite(e,tiaodeng[num][3]);
   digitalWrite(f,tiaodeng[num][2]);
   digitalWrite(g,tiaodeng[num][1]);
   digitalWrite(h,tiaodeng[num][0]);
 楼主| 发表于 2015-2-15 10:21:06 | 显示全部楼层
//用数码管显示温度
#include<Arduino.h>
#define a 2
#define b 3
#define c 4
#define d 5
#define e 6
#define f 7
#define g 8
#define h 9
#define com1 10
#define com2 11
#define com3 12
#define com4 13
#define LM35 A0
int z,s;
    pinMode(z,OUTPUT);
  z = analogRead(LM35);                        //读取AD值
  s = z * 0.48876;
  Serial.print("LM35 = ");
  Serial.println(s);
  shumaguang(1,s/10);
  delay(2);
  shumaguang(2,s%10);
  delay(2);
unsigned char shumaguang(unsigned char com, unsigned num)
  switch(com)
    case 1:
    case 2:
    case 3:
    case 4:
发表于 2015-2-15 11:15:35 | 显示全部楼层
不错,挺好的啊
发表于 2015-2-16 04:42:40 | 显示全部楼层
正在学习Arduino……
发表于 2016-4-15 14:41:46 | 显示全部楼层
正是我找的,謝謝
GMT+8, 2026-6-19 16:46 , Processed in 0.039167 second(s), 22 queries .
