查看: 9349|回复: 1
关于红外接收程序错误
发表于 2015-3-24 16:20:39 | 显示全部楼层 |阅读模式
#include <IRremote.h>
int RECV_PIN = 11;
int LED1 = 2;
int LED2 = 3;
int LED3 = 4;
int LED4 = 5;
int LED5 = 6;
int LED6 = 7;
long on1  = 0x00FFA25D;
long off1 = 0x00FFE01F;
long on2 = 0x00FF629D;
long off2 = 0x00FFA857;
long on3 = 0x00FFE21D;
long off3 = 0x00FF906F;
long on4 = 0x00FF22DD;
long off4 = 0x00FF6897;
long on5 = 0x00FF02FD;
long off5 = 0x00FF9867;
long on6 = 0x00FFC23D;
long off6 = 0x00FFB047;
IRrecv irrecv(RECV_PIN);
decode_results results;
// Dumps out the decode_results structure.
// Call this after IRrecv::decode()
// void * to work around compiler issue
//void dump(void *v) {
//  decode_results *results = (decode_results *)v
void dump(decode_results *results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN)
     Serial.println("Could not decode message");
    if (results->decode_type == NEC)
       Serial.print("Decoded NEC: ");
    else if (results->decode_type == SONY)
       Serial.print("Decoded SONY: ");
    else if (results->decode_type == RC5)
       Serial.print("Decoded RC5: ");
    else if (results->decode_type == RC6)
       Serial.print("Decoded RC6: ");
     Serial.print(results->value, HEX);
     Serial.print(" (");
     Serial.print(results->bits, DEC);
     Serial.println(" bits)");
     Serial.print("Raw (");
     Serial.print(count, DEC);
     Serial.print("): ");
  for (int i = 0; i < count; i++)
      if ((i % 2) == 1) {
      Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
      Serial.println("");
  pinMode(RECV_PIN, INPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  pinMode(LED5, OUTPUT);
  pinMode(LED6, OUTPUT);
  pinMode(13, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
int on = 0;
unsigned long last = millis();
  if (irrecv.decode(&results))
    // If it's been at least 1/4 second since the last
    // IR received, toggle the relay
    if (millis() - last > 250)
       on = !on;
//       digitalWrite(8, on ? HIGH : LOW);
       digitalWrite(13, on ? HIGH : LOW);
       dump(&results);
    if (results.value == on1 )
       digitalWrite(LED1, HIGH);
    if (results.value == off1 )
       digitalWrite(LED1, LOW);
    if (results.value == on2 )
       digitalWrite(LED2, HIGH);
    if (results.value == off2 )
       digitalWrite(LED2, LOW);
    if (results.value == on3 )
       digitalWrite(LED3, HIGH);
    if (results.value == off3 )
       digitalWrite(LED3, LOW);
    if (results.value == on4 )
       digitalWrite(LED4, HIGH);
    if (results.value == off4 )
       digitalWrite(LED4, LOW);
    if (results.value == on5 )
       digitalWrite(LED5, HIGH);
    if (results.value == off5 )
       digitalWrite(LED5, LOW);
    if (results.value == on6 )
       digitalWrite(LED6, HIGH);
    if (results.value == off6 )
       digitalWrite(LED6, LOW);
    last = millis();
    irrecv.resume(); // Receive the next value
这是一个红外接收程序出现以下错误
sketch_mar24a.cpp:1:22: error: IRremote.h: No such file or directory
sketch_mar24a:-1: error: variable or field 'dump' declared void
sketch_mar24a:-1: error: 'decode_results' was not declared in this scope
sketch_mar24a:-1: error: 'results' was not declared in this scope
sketch_mar24a:20: error: 'IRrecv' does not name a type
sketch_mar24a:21: error: 'decode_results' does not name a type
sketch_mar24a:27: error: variable or field 'dump' declared void
sketch_mar24a:27: error: 'decode_results' was not declared in this scope
sketch_mar24a:27: error: 'results' was not declared in this scope
我是一小白不知道怎么改,求解
发表于 2015-3-25 12:19:06 | 显示全部楼层
善用搜索....论坛里不是有红外的好几篇帖子么  你这初始化都不对 肯定错误啊
GMT+8, 2026-6-17 14:43 , Processed in 0.101317 second(s), 19 queries .
