查看: 11928|回复: 6
PS2keyboard库函数.available()总是返回flase,什么原因
发表于 2015-3-25 11:06:06 | 显示全部楼层 |阅读模式
我在模仿freebuf上的
http://bluereader.org/article/10965311
文章做一个硬件键盘记录。
我的连接是正确的;
arduino IDE版本是1.6.1;
键盘是一个PS2接口;
板子型号是UNO;
PS2Keyboard下载最新的2.4版本
http://www.pjrc.com/teensy/td_libs_PS2Keyboard.html
用IDE打开库文件里的example/Simple_Test.pde,编译下载到板子上,发现keyboard.available()总是返回false
[pre lang="arduino" line="1" file="simple_test,pde"]/*  PS2Keyboard library example
  PS2Keyboard now requries both pins specified for begin()
  keyboard.begin(data_pin, irq_pin);
  Valid irq pins:
     Arduino Uno:  2, 3
     Arduino Due:  All pins, except 13 (LED)
     Arduino Mega: 2, 3, 18, 19, 20, 21
     Teensy 2.0:   All pins, except 13 (LED)
     Teensy 2.0:   5, 6, 7, 8
     Teensy 1.0:   0, 1, 2, 3, 4, 6, 7, 16
     Teensy++ 2.0: 0, 1, 2, 3, 18, 19, 36, 37
     Teensy++ 1.0: 0, 1, 2, 3, 18, 19, 36, 37
     Sanguino:     2, 10, 11
  for more information you can read the original wiki in arduino.cc
  at http://www.arduino.cc/playground/Main/PS2Keyboard
  or http://www.pjrc.com/teensy/td_libs_PS2Keyboard.html
  Like the Original library and example this is under LGPL license.
  Modified by [email protected] on 2010-03-22
  Modified by Paul Stoffregen <[email protected]> June 2010
#include <PS2Keyboard.h>
const int DataPin = 8;
const int IRQpin =  5;
PS2Keyboard keyboard;
  delay(1000);
  keyboard.begin(DataPin, IRQpin);
  Serial.println("Keyboard Test:");
  if (keyboard.available()) {
    // read the next key
    char c = keyboard.read();
    // check for some of the special keys
    if (c == PS2_ENTER) {
      Serial.println();
    } else if (c == PS2_TAB) {
      Serial.print("[Tab]");
    } else if (c == PS2_ESC) {
      Serial.print("[ESC]");
    } else if (c == PS2_PAGEDOWN) {
      Serial.print("[PgDn]");
    } else if (c == PS2_PAGEUP) {
      Serial.print("[PgUp]");
    } else if (c == PS2_LEFTARROW) {
      Serial.print("[Left]");
    } else if (c == PS2_RIGHTARROW) {
      Serial.print("[Right]");
    } else if (c == PS2_UPARROW) {
      Serial.print("[Up]");
    } else if (c == PS2_DOWNARROW) {
      Serial.print("[Down]");
    } else if (c == PS2_DELETE) {
      Serial.print("[Del]");
    } else {
      // otherwise, just print all normal characters
      Serial.print(c);
[/code]
有没有人跟我一样呀!!!!
发表于 2015-3-25 11:44:20 | 显示全部楼层
建议你用老一点的ide试试  最新的这个可能有点问题
另外检查连线是不是搞反了
我之前做过
http://www.lab-z.com/ps2a/
制作一个PS2键盘记录器
 楼主| 发表于 2015-3-25 15:23:58 | 显示全部楼层
另外检查连线是不是搞反了
hi~ zoologist 代码可以编译通过,应该不是IDE的问题吧?刚才仔细检查了一下我的接口和您的blog中的表示是相符的。我想问一个细节,就是我给键盘通电的一瞬间,键盘的提示灯会亮一下,之后就没反映了,这是可能是键盘原因吗?我用的是清华同方的,10年前的货。
 楼主| 发表于 2015-3-25 17:05:45 | 显示全部楼层
今天下午调试了一下,目前发现是
attachInterrupt(irq_num, ps2interrupt, FALLING);创建的中断有问题!!
UNO版不能接到有频率的时序信号!!
发表于 2015-3-25 21:09:40 | 显示全部楼层
Gwei 发表于 2015-3-25 17:05
今天下午调试了一下,目前发现是
attachInterrupt(irq_num, ps2interrupt, FALLING);创建的中断有问题!! ...
什么意思?
 楼主| 发表于 2015-3-26 19:36:46 | 显示全部楼层
zoologist 发表于 2015-3-25 21:09
什么意思?
应该是我接错线,才错的,这个应该是申请中断的意思,从high降到low就会触发中断。谢谢了 朋友!!
 楼主| 发表于 2015-3-26 19:37:04 | 显示全部楼层
什么意思?
GMT+8, 2026-6-21 16:01 , Processed in 0.043033 second(s), 18 queries .
