查看: 38669|回复: 21
各位大神来交流一下呗
发表于 2015-3-27 20:50:30 | 显示全部楼层 |阅读模式
   我是一名高中生,喜欢玩Arduino,现正参加一个科技创新大赛
,明天就公开展出了,希望大神们给点建议或指导,Think you!!以下是程序:
//*********************用户自定义模块化云平台*********************************
//*********************广西师范大学附属中学创新实验室*************************
//*********************Write by*****************************************
//*********************http://www.gxsdfz.com**********************************
//*********************Date:2015.3.16*****************************************
#include <LiquidCrystal.h>
#include<Servo.h>
LiquidCrystal lcd(13, 12, 5, 4, 3, 2);
#define LED 13
byte x = 0;
Servo myservo;
int pos=0;
int Beep=8;
int wd=analogRead(4);
int key = 0;
float temperature = 0;
long val1=0;
int value=0;
int Pass=0;
char ss;
char Pass1_buf[4];
char Pass2_buf[4];
int z;
int b;
int dat;
int aj=7;
int p=1;
int dw=1,juli=0,num=0,jishu=0,flag=1;
/*SoftwareSerial serial1(7,6);//RX TX
SoftwareSerial serial2(3,2);//RX TX*/
pinMode(1,INPUT);
pinMode(LED,OUTPUT);
pinMode(Beep,OUTPUT);
pinMode(8,OUTPUT);
pinMode(aj,INPUT);
pinMode(6,OUTPUT);
pinMode(10,OUTPUT);
lcd.begin(16, 2);
delay(1000);
pinMode(9,OUTPUT);
//--------------------GM_Mode---------------------//
void GM()
lcd.clear();
lcd.setCursor(4,0);
lcd.print("GM_Mode");
lcd.setCursor(1, 1);
lcd.print("Enter");
delay(500);
lcd.clear();
Serial.println("GM_Mode");
Serial.println("Enter");
int o=analogRead(5);
while(key<1)
if (analogRead(5)<=40)
digitalWrite(9,HIGH);}
else{digitalWrite(9,LOW);
  switch(Serial.read())
  {case'q':
  key=2;
  lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
   Serial.println("back");
  break;}}
}//pass
//--------------------HY_Mode-------------------------//
  void HY()
  {int i=0;
/*lcd.clear();
lcd.setCursor(4,0);
lcd.print("HY_Mode");
lcd.print("Enter");
  delay(500);
lcd.clear();*/
Serial.println("HY_Mode");
while(key<1)
  if (analogRead(0)>=10)
    lcd.clear();
    lcd.print("Fire out");
    Serial.println("Fire out");
    delay(1000);
    lcd.clear();
    lcd.setCursor(0, 1);
    for (int i=0;i<=255;i++)
     tone(Beep,i);
  noTone(Beep);
Serial.println("No Fire");
delay(2000);}
{case'q':
key=2;
noTone(Beep);
lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
break;}}
}//pass
//-----------------Relay_Mode--------------------//
void Relay()
{Serial.println("Relay_Mode");
while(key<1)
    if(Serial.available())
    {delay(100);
         case'1':
         digitalWrite(6,HIGH);
         Serial.println("jidian1 open");
         case'2':
        digitalWrite(6,LOW);
          Serial.println("jidian1 close");
           case'3':
         digitalWrite(10,HIGH);
         Serial.println("jidian2 open");
         case'4':
        digitalWrite(10,LOW);
          Serial.println("jidian2 close");
          case'q':
          key=2;
          break;}}}}//pass
  //-------------------WD_Mode-----------------------------//
void WD()
lcd.clear();
lcd.setCursor(4,0);
lcd.print("WD_Mode");
lcd.print("Enter");
delay(500);
lcd.clear();
Serial.println("WD_Mode");
while(key<1)
val1=analogRead(wd);
temperature = (val1*0.0048828125*1000);
lcd.clear();
lcd.print("Temperature");
lcd.setCursor(0, 1) ;
lcd.print((long)temperature / 10);
lcd.print(".");
lcd.print( (long)temperature % 10);
lcd.print((char)223);
lcd.print("C");
delay(2000);
lcd.clear();
b=analogRead(4);
/*dat=(float)b*0.0048828125*1000;*/
temperature = (b*0.0048828125*1000);
Serial.print("Tep");
Serial.print((long)temperature / 10);
Serial.print(".");
Serial.print( (long)temperature % 10);
Serial.println("C");
delay(500);
/*if (wd>=100)
{digitalWrite(8,HIGH);}
else{digitalWrite(8,LOW);} */
{case'q':
key=2;
lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
break;} }
//---------------------Led_Mode-----------------------//
void Led_Mode()
lcd.clear();
lcd.setCursor(4,0);
lcd.print("Led_Mode");
lcd.print("Enter");
  delay(500);
  lcd.clear();
Serial.println("Led_Mode");
while(key<1)
{    if(Serial.available())
    {delay(100);
       case'1':
      case'2':
       case'q':
       key=2;
       lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
       break;}
//----------------------Led_PWM_Mode-----------------------//
void Led_PWM()
  lcd.clear();
  lcd.setCursor(2, 0);
  lcd.print("Led_PWM");
  lcd.print("Enter");
  delay(500);
  lcd.clear();
  Serial.println("Led_PWM");
  while(key < 1)
            if (Serial.available())
                delay(100);
                    case'1':
                    value=value+20;
                    if (Serial.read()=='+')
                    analogWrite(9,value);
                    case'3':
                    value=value-20;
                    if (Serial.read()=='-')
                    case'max':
                    analogWrite(9,255);
                    case'min':
                    analogWrite(9,0);
                    case'q':
                    key=2;
                    lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
                    break;}
//----------------------Led_Breath_Mode---------------//
void Led_Breath()
  lcd.clear();
  lcd.print("Led_Breath");
  lcd.print("Enter");
  delay(500);
  lcd.clear();
  Serial.println("Led_Breath");
while(key < 1)
    /* case'1':*/
     for(int x=0;x<=255;x++)
       {analogWrite(9,x);
       delay(10);}
      /* break;
       case'2':
       for(int x=255;x>=0;x--)
       {analogWrite(9,x);
       delay(10);}
      /* case'all':
       analogWrite(9,x);
       delay(100);
       analogWrite(9,x);
       break;*/
       case'q':
       key=2;
       lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
       break;}
//----------------------Led_Receive_Mode---------------------//
void Led_Receive()
  lcd.clear();
  lcd.print("Led_Receive_Mode");
  lcd.print("Enter");
  lcd.clear();
  delay(500);
  Serial.println("Led_Receive_Mode");
  while(key<1)
        delay(100);
           case'1':
           delay(1000);
           case'q':
           key=2;
           lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
//------------------------Servo_Mode----------------------//
/*void servo()
  lcd.clear();
  lcd.print("Servo_Mode");
  lcd.print("Enter");
  delay(500);
  lcd.clear();
  Serial.println("Servo_Mode");
while(key<1)
  delay(100);
{case'1':
  for(pos=0;pos<180;pos+=1)
  {myservo.write(pos);
  delay(15);}
  case'2':
  for(pos=180;pos>=1;pos-=1)
{ myservo.write(pos);
  delay(15);}
  case'q':
  key=2;
  lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
  break;}
//-----------------------CBS_Mode--------------------------//
/*void CBS()
  lcd.clear();
  lcd.setCursor(1, 0);
  lcd.print("CBS_Mode");
  lcd.print("Enter");
  delay(500);
  lcd.clear();
  Serial.println("CBS_Mode");
  while(key<1)
    {delay(100);
         case'1':
       Wire.beginTransmission(4);
       Wire.write("CBS");
      Wire.write(y);
      Wire.endTransmission();
   y++;
     if(y==2)
    y=0;
     delay(500);
     Wire.requestFrom(4,1);
     while(Wire.available()==1)
    lcd.clear();
    lcd.print("CBS Receive Well");
    Serial.println("CBS Receive Well");
    delay(1000);
    lcd.clear();
  delay(1000);
  case'q':
  key=2;
  lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
  break;}
//-----------------------Pass_set_Mode----------------------//
void Pass_set()
  lcd.clear();
  lcd.print("Pass_set_Mode");
  lcd.print("Set Code1 4 Numb");
  delay(500);
  lcd.clear();
  Serial.println("Pass_set_Mode");
  while(key<1)
  { if(Pass==0)
      {if(Serial.available())
       {delay(100);
       if (Serial.available() > 0)
                     for(int i = 0;i<4;i++)
                        Pass1_buf = Serial.read();
                    lcd.clear();
                    lcd.print("Now goto 6 Mode");
                    lcd.setCursor(4, 1);
                    lcd.print("Get It");
                    Pass= 1;
{case'q':
key=2;
lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
break;}
//-----------------------Pass_words_Mode----------------------//
void Pass_words()
      lcd.clear();
      lcd.print("Enter Pass_words");
      delay(500);
      lcd.clear();
      while(key < 1)
          if(Pass == 1)
                 delay(100);
                       Pass2_buf = Serial.read();
                     lcd.clear();
                     lcd.setCursor(4, 0);
                     lcd.print("cheak");
                     lcd.setCursor(2, 1);
                     lcd.print("Enter Again");
                    delay(500);
                   lcd.clear();
                    if ( Pass1_buf[0] == Pass2_buf[0] && Pass1_buf[1] == Pass2_buf[1] &&
                       Pass1_buf[2] == Pass2_buf[2] && Pass1_buf[3] == Pass2_buf[3]  )
                       lcd.clear();
                       lcd.print(" / to Exit ");
                       lcd.setCursor(7, 1);
                       lcd.print("OK");
                       delay(500);
                       lcd.clear();
                      Serial.println("OK");
{case'q':
key=2;
lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
break;}
//---------------Write_Mode--------------------//
/*void Write()
{ lcd.clear();
  lcd.print("Write_Mode");
  lcd.print("Write Anything");
  delay(500);
  lcd.clear();
  while(key < 1)
        delay(100);
        lcd.clear();
        while (Serial.available() > 0)
          lcd.write(Serial.read());
   case'q':
key=2;
lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
break;}
//---------------------analog_Read_Mode--------------//
void analog_Read()
  lcd.clear();
  lcd.setCursor(3, 0);
  lcd.print("Serial_analog");
  lcd.print("Enter");
  delay(500);
  lcd.clear();
  while(key<1)
  int    sensorValue = analogRead(0);
  int  sensorValue1 = analogRead(4);
  int     sensorValue2= analogRead(5);
  Serial.print("sensorHY = " );
     Serial.println(sensorValue );
     delay(1000);
     Serial.print("sensorWD= " );
     Serial.println(sensorValue1  );
     delay(1000);
     Serial.print("sensorGM = " );
     Serial.println(sensorValue2 );
     delay(1000);
     delay(1000);
         case 'q':
           key = 2;
           lcd.clear();
lcd.print("back");
delay(500);
lcd.clear();
//-------------------BlueTooth_Mode-----------------//
void BlueTooth_Mode()
if(Serial.available()>0)
{/*lcd.clear();
lcd.print("SET Mode");
lcd.print("= KEYES team =");
delay(500);
lcd.clear();*/
Serial.println("BlueTooth_Mode");
key = 0;}
while(key<1){
   case'1':
      GM();
Serial.println("GM");
      case'2':
      HY();
Serial.println("HY");
      case'3':
      WD();
Serial.println("WD");
      case'4':
      Led_Mode();
     /* case'5':
      Led_PWM();
      case'6':
      Led_Breath();
      case'7':
      Led_Receive();
Serial.println("Led_Receive");
      break;*/
      case'8':
      Pass_set();
Serial.println("Pass_set");
      case'9':
      Pass_words();;
Serial.println(" Pass_words");
      /*case'a':
      Write();
Serial.println("Write");
      break;*/
      case'b':
      analog_Read();
Serial.println("analog_Read");
      /*case'c':
      servo();
Serial.println("servo");
    break;*/
    case'c':
    free();
    Serial.println("free");
    case'd':
    Relay();
    Serial.println("Relay");
    /*case'e':
    IR();
     Serial.println("IR");*/
    case'q':
    key=2;
    break;}
//-------------------------------free_Mode----------------------//
void free()
  while(key<1)
{if (
analogRead(5)<=50)
     {digitalWrite(9,HIGH);}
     else {digitalWrite(9,LOW);}
     /*if (analogRead(0)>=20)
     {for (int i=200;i<=800;i++)
     tone(Beep,i);
  else{
noTone(Beep);}
if (analogRead(4)>=600)
else{digitalWrite(9,LOW);}*/
case'q':
key=2;
break;}
//--------------------------------loop--------------------------------//
   z=0;
  while(digitalRead(7)>0)
    delay(100);
    z=(z+1);
  if ((((z%2))==(1)))
    delay(1000);
    free();
  if ((((z%2))==(0)))
  {Serial.println("BlueTooth_Mode");
  delay(1000);
    BlueTooth_Mode();
//--------------------------------END----------------------------------//
ps:程序有点乱,出自高中生之手,希望理解,谢谢
有几个问题想问下给位大神:
1、液晶无法显示,我是用4位的,如果是单一程序(如温显)可以显示,但是多了开始就乱码,后来就无法显示;
2、LM35温传烧了,我用热敏代替,请问有计算公式不;
3、主从机问题,我还写了个从机程序,但与蓝牙冲突,I2C表示正在学,一时用不了,软传还是会与蓝牙冲突,怎么办(或是我软传没学好,能给个详细程序没);
4、蓝牙与红外会冲突没,如有,怎么解决;
5、按键判断奇偶会出现一个问题 :不按时会判断0(整除);按一下判断余一(正常),但松开后又判断为0,怎么解决,或者用计数?最好有详细程序;
6、为什么用蓝牙串口接收温度数据会出现问号(显示问号)
还有些问题还会及时发再发,我从现在到两点都在线,希望各位大神帮个忙,感激不尽,好人一生平安!!!
下面是从机程序(未完程)
#include <IRremote00.h>
#include <ctype.h>
#include <Wire.h>
/*#include <Servo.h>
Servo myservo;*/
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results  results;
long on1  = 0x00FFA25D;
long off1 = 0x00FFE01F;
long on2 = 0x00FF629D;
long off2 = 0x00FFA857;
long on3 = 0x00FFE21D;
long off3 = 0x00FF906F;
long on4 = 0x00FF22DD;
long off4 = 0x00FF6897;
long on5 = 0x00FF02FD;
long off5 = 0x00FF9867;
long on6 = 0x00FFC23D;
long off6 = 0x00FFB047;
int pos=0;
int key=0;
int sy=3;
  pinMode(12,OUTPUT);
  pinMode(2,OUTPUT);  // 定义LED为输出引脚
  Serial.begin(9600);          //开启串口通信,并设定波特率为9600
  irrecv.enableIRIn();
pinMode(sy,OUTPUT);
  /*myservo.attach(3);*/
  //启动红外解码
void irdisplay(unsigned long value)
  switch(value){
  case 0xFFA25D:
    Serial.println("POWER");
    digitalWrite(12, HIGH);
  case 0xFF629D:
    Serial.println("Mode");
    digitalWrite(12, LOW);
  case 0xFFE21D:
    Serial.println("MUTE");
    digitalWrite(2,HIGH);
  case 0xFF22DD:
    Serial.println("PLAY/PAUSE");
    digitalWrite(2,LOW);
  case 0xFF02FD:
    Serial.println("PREV");
  case 0XFFC23D:
    Serial.println("NEXT");
  case 0xFFE01F:
    Serial.println("EQ");
    /*for(pos=0;pos<180;pos+=1)
     delay(15);
IR_Receiver();
case 0xFFA857:
Serial.println("-");
/*for(pos=180;pos>=1;pos-=1)
  delay(15);}*/
     SY();
  case 0xFF906F:
    Serial.println("+");
    YW();
  case 0xFF6897:
    Serial.println("0");
    /*CBS();*/
case 0xFF9867:
    Serial.println("BACK");
  /*case 0xFFB04F:
    Serial.println("U/SD");
  case 0xFF30CF:
    Serial.println("1");
  case 0xFF18E7:
    Serial.println("2");
  case 0xFF7A85:
    Serial.println("3");
  case 0xFF10EF:
    Serial.println("4");
  case 0xFF38C7:
    Serial.println("5");
  case 0xFF5AA5:
    Serial.println("6");
  case 0xFF42BD:
    Serial.println("7");
  case 0xFF4AB5:
    Serial.println("8");
  case 0xFF52AD:
    Serial.println("9");
    break;*/
//--------------------------------CBS_Mode---------------
/*void ()
   Serial.print("CBS");
Serial.print("Enter");
int value;
while (key<1)
//---------------------------------SY_Mode------------------
void SY()
  Serial.print("SY");
  int value;
while(key<1)
  if (sy==LOW)
  { digitalWrite(12,HIGH);
  else {digitalWrite(12,LOW);
digitalWrite(2,LOW);}
switch(value)
{ case 0xFF52AD:
    key=2;
//--------------------------------YW_Mode-----------------------------
void YW()
{ Serial.print("YW");
int value;
while(key<1)
  {if (analogRead(0)>=300)
    Serial.println("danger");
     delay(15);}*/}
  delay(15);}*/}
  switch (value)
  { case 0xFF52AD:
    key=2;
//--------------------------IR_Receiver _Mode---------------------
void IR_Receiver()
  if (irrecv.decode(&results))  {
    Serial.print("irCode: ");
    Serial.print(results.value,HEX);
    delay(100);
    Serial.print(",  bits: ");
    Serial.println(results.bits);
    irrecv.resume();
//----------------------------loop----------------------------------
    irdisplay(results.value);
    irrecv.resume();
发表于 2015-3-27 21:57:54 | 显示全部楼层
调试不出来的时候推翻了重新一个个的写
发表于 2015-3-27 22:12:22 | 显示全部楼层
无图无真相
 楼主| 发表于 2015-3-27 23:07:41 来自手机 | 显示全部楼层
抱歉,图有限制
 楼主| 发表于 2015-3-27 23:08:32 来自手机 | 显示全部楼层
等下再试试
 楼主| 发表于 2015-3-27 23:09:53 来自手机 | 显示全部楼层
等下再试试
发表于 2015-3-28 18:11:23 | 显示全部楼层
第二个问题:金属热电阻的电阻值和温度一般可以用以下的近似关系式表示,即
                           Rt=Rt0[1+α(t-t0)]
   式中,Rt为温度t时的阻值;Rt0为温度t0(通常t0=0℃)时对应电阻值;α为温度系数。
发表于 2015-3-28 18:11:56 | 显示全部楼层
第二个问题:半导体热敏电阻的阻值和温度关系为
                          Rt=AeB/t
    中Rt为温度为t时的阻值;A、B取决于半导体材料的结构的常数。
发表于 2015-3-28 18:13:57 | 显示全部楼层
有个LCD的库,装上,编程更简单l
发表于 2015-3-28 18:14:46 | 显示全部楼层
高中生,前途无限。可程序太乱了。
 楼主| 发表于 2015-3-30 18:39:50 | 显示全部楼层
谢谢夸奖,比赛完了,结果不错。谢谢支持
 楼主| 发表于 2015-3-30 18:41:23 | 显示全部楼层
suoma 发表于 2015-3-28 18:14
高中生,前途无限。可程序太乱了。
谢谢夸奖,比赛完了,结果不错,进国赛了。谢谢支持,
 楼主| 发表于 2015-3-30 18:41:43 | 显示全部楼层
现在在写论文,
 楼主| 发表于 2015-3-30 18:42:30 | 显示全部楼层
                           R ...
谢谢,我已经做了实验,测定好了(比赛后)。。。。。
 楼主| 发表于 2015-3-30 18:43:01 | 显示全部楼层
suoma 发表于 2015-3-28 18:13
有个LCD的库,装上,编程更简单l
可不可以介绍一下,谢谢
GMT+8, 2026-7-26 16:38 , Processed in 0.044750 second(s), 21 queries .
