查看: 9650|回复: 3
关于可调试灯光程序的问题
发表于 2015-3-31 14:04:42 | 显示全部楼层 |阅读模式
const int analogPin = A0;
const int ledCount = 10;
int ledPins[] = {
  2, 3, 4, 5, 6, 7,8,9,10,11 };
  for (int thisLed = 0; thisLed < ledCount; thisLed++) {
    pinMode(ledPins[thisLed], OUTPUT);
  int sensorReading = analogRead(analogPin);
  int ledLevel = map(sensorReading, 0, 1023, 0, ledCount);
    if (thisLed < ledLevel) {
      digitalWrite(ledPins[thisLed], HIGH);
      Serial.println(sensorReading);
    else {
      digitalWrite(ledPins[thisLed], LOW);
以上语句及变量在该程序中的具体含义,求解
以上程序仅仅只是通过改变电流大小来控制各个小灯的简单程序,但本人有几处地方不是太明确,求助
 楼主| 发表于 2015-3-31 14:06:00 | 显示全部楼层
const int analogPin = A0;   // the pin that the potentiometer is attached to
const int ledCount = 10;   // the number of LEDs in the bar graph
int ledPins[] = {
  2, 3, 4, 5, 6, 7,8,9,10,11 };   // an array of pin numbers to which LEDs are attached
  // loop over the pin array and set them all to output:
  // read the potentiometer:
  // map the result to a range from 0 to the number of LEDs:
  // loop over the LED array:
    // if the array element's index is less than ledLevel,
    // turn the pin for this element on:
    // turn off all pins higher than the ledLevel:
    else {
发表于 2015-3-31 18:53:23 | 显示全部楼层
ledCount表示所用的led有幾顆,與後面的ledPins[]數量對應
map(sensorReading, 0, 1023, 0, ledCount)這句是等比例縮放sensorReading
analogRead()的範圍0~1023,要轉換成0~ledCount,也就是0~10
 楼主| 发表于 2015-4-1 13:18:12 | 显示全部楼层
非常感谢,懂了,谢谢帮忙{:soso_e179:}{:soso_e100:}
GMT+8, 2026-7-26 20:47 , Processed in 0.033807 second(s), 18 queries .
