查看: 12061|回复: 4
程序运行报错
发表于 2015-3-31 23:25:40 | 显示全部楼层 |阅读模式
byte val;
int ledpin=13;
  pinMode(ledpin,OUTPUT);
  if(Serial.available())
   val=Serial.read();
   if(val=='r')
    digitalWrite(ledpin,HIGH);
    delay((500);
    digitalWrite(ledpin,LOW);
    delay(500);
    Serial.println("keyes");
运行后是这样的错误
Arduino: 1.6.1 (Windows 7), Board: "Arduino Uno"
Build options changed, rebuilding all
BlueTooth_controal.ino:16:5: error: stray '\' in program
BlueTooth_controal.ino:18:5: error: stray '\' in program
BlueTooth_controal.ino: In function 'void loop()':
BlueTooth_controal.ino:16:25: error: expected ')' before 'uff0cHIGH'
BlueTooth_controal.ino:16:34: error: too few arguments to function 'void digitalWrite(uint8_t, uint8_t)'
In file included from BlueTooth_controal.ino:2:0:
E:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:126:6: note: declared here
void digitalWrite(uint8_t, uint8_t);
BlueTooth_controal.ino:17:16: error: expected ')' before ';' token
BlueTooth_controal.ino:18:25: error: expected ')' before 'uff0cLOW'
BlueTooth_controal.ino:18:33: error: too few arguments to function 'void digitalWrite(uint8_t, uint8_t)'
Error compiling.
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
求解
发表于 2015-3-31 23:56:35 | 显示全部楼层
首先, 你要明白運行跟 compile 的分明.  你並非在運行後出問題.
其次, 你要明白中文輸入時, 全形跟半形的分別.  程式中字串/字符/註解中可以加入全形的文字, 但其他地方只可以有半形的.  小心看看你的標點符號吧.
 楼主| 发表于 2015-4-1 12:03:35 | 显示全部楼层
谢谢你的指点
 楼主| 发表于 2015-4-1 12:07:53 | 显示全部楼层
OpenJumper Examples
DHT11 Moudle
www.openjumper.com
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
  Serial.println("\n");
  // 读取传感器数据
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Read sensor: ");
  // 检测数据是否正常接收
  switch (chk)
    case DHTLIB_OK:
                Serial.println("OK");
    case DHTLIB_ERROR_CHECHSUM:
                Serial.println("Checksum error");
    case DHTLIB_ERROR_TIMEOUT:
                Serial.println("Time out error");
    default:
                Serial.println("Unknown error");
  // 输出湿度与温度信息
Serial.print("Humidity (%): ");
  Serial.println(DHT11.humidity);
  Serial.print("Temperature (oC): ");
  Serial.println(DHT11.temperature);
  delay(1000);
编译报错:
temperature_and_Humidity_check1.ino: In function 'void loop()':
temperature_and_Humidity_check1.ino:29:10: error: 'DHTLIB_ERROR_CHECHSUM' was not declared in this scope
Error compiling.
这是我按《arduino 程序设计基础第二版》的案例敲进去的,卟知道怎么改,能帮看看吗?
发表于 2015-4-1 21:48:40 | 显示全部楼层
hgmyaoming 发表于 2015-4-1 12:07
OpenJumper Examples
DHT11 Moudle
        注意全形,半形
GMT+8, 2026-7-26 20:09 , Processed in 0.034410 second(s), 19 queries .
