查看: 9590|回复: 2
GY-511 LSM303DLH使用求救!
发表于 2015-4-12 22:19:46 | 显示全部楼层 |阅读模式
GY-511把LSM303的Vcc3.3, Gnd, SCL, SDA, INT1, INT2, DRDY引出,其中SCL, SDA利用Vin进行电压转换
我将Vcc3.3, Gnd, SCL, SDA与Arduino uno的相应端口连接, Vin连接Arduino板子上5V电源,INT1,INT2,DRDY悬空。
现在问题来了,我用wire向LSM303控制寄存器写数, 木反映, endTransimition返回2,难道还是电气连接有问题?
另外,不用示波器怎么才能知道Arduino板子TWI通信没问题。
以下代码:
#ifndef LSM303_h
#define LSM303_h
#include <Arduino.h> // for byte data type
// device types
#define LSM303DLH_DEVICE   0
#define LSM303DLM_DEVICE   1
#define LSM303DLHC_DEVICE  2
#define LSM303_DEVICE_AUTO 3
// SA0_A states
#define LSM303_SA0_A_LOW  0
#define LSM303_SA0_A_HIGH 1
#define LSM303_SA0_A_AUTO 2
// register addresses
#define LSM303_CTRL_REG1_A       0x20
#define LSM303_CTRL_REG2_A       0x21
#define LSM303_CTRL_REG3_A       0x22
#define LSM303_CTRL_REG4_A       0x23
#define LSM303_CTRL_REG5_A       0x24
#define LSM303_CTRL_REG6_A       0x25 // DLHC only
#define LSM303_HP_FILTER_RESET_A 0x25 // DLH, DLM only
#define LSM303_REFERENCE_A       0x26
#define LSM303_STATUS_REG_A      0x27
#define LSM303_OUT_X_L_A         0x28
#define LSM303_OUT_X_H_A         0x29
#define LSM303_OUT_Y_L_A         0x2A
#define LSM303_OUT_Y_H_A         0x2B
#define LSM303_OUT_Z_L_A         0x2C
#define LSM303_OUT_Z_H_A         0x2D
#define LSM303_FIFO_CTRL_REG_A   0x2E // DLHC only
#define LSM303_FIFO_SRC_REG_A    0x2F // DLHC only
#define LSM303_INT1_CFG_A        0x30
#define LSM303_INT1_SRC_A        0x31
#define LSM303_INT1_THS_A        0x32
#define LSM303_INT1_DURATION_A   0x33
#define LSM303_INT2_CFG_A        0x34
#define LSM303_INT2_SRC_A        0x35
#define LSM303_INT2_THS_A        0x36
#define LSM303_INT2_DURATION_A   0x37
#define LSM303_CLICK_CFG_A       0x38 // DLHC only
#define LSM303_CLICK_SRC_A       0x39 // DLHC only
#define LSM303_CLICK_THS_A       0x3A // DLHC only
#define LSM303_TIME_LIMIT_A      0x3B // DLHC only
#define LSM303_TIME_LATENCY_A    0x3C // DLHC only
#define LSM303_TIME_WINDOW_A     0x3D // DLHC only
#define LSM303_CRA_REG_M         0x00
#define LSM303_CRB_REG_M         0x01
#define LSM303_MR_REG_M          0x02
#define LSM303_OUT_X_H_M         0x03
#define LSM303_OUT_X_L_M         0x04
#define LSM303_OUT_Y_H_M         -1   // The addresses of the Y and Z magnetometer output registers
#define LSM303_OUT_Y_L_M         -2   // are reversed on the DLM and DLHC relative to the DLH.
#define LSM303_OUT_Z_H_M         -3   // These four defines have dummy values so the library can
#define LSM303_OUT_Z_L_M         -4   // determine the correct address based on the device type.
#define LSM303_SR_REG_M          0x09
#define LSM303_IRA_REG_M         0x0A
#define LSM303_IRB_REG_M         0x0B
#define LSM303_IRC_REG_M         0x0C
#define LSM303_WHO_AM_I_M        0x0F // DLM only
#define LSM303_TEMP_OUT_H_M      0x31 // DLHC only
#define LSM303_TEMP_OUT_L_M      0x32 // DLHC only
#define LSM303DLH_OUT_Y_H_M      0x05
#define LSM303DLH_OUT_Y_L_M      0x06
#define LSM303DLH_OUT_Z_H_M      0x07
#define LSM303DLH_OUT_Z_L_M      0x08
#define LSM303DLM_OUT_Z_H_M      0x05
#define LSM303DLM_OUT_Z_L_M      0x06
#define LSM303DLM_OUT_Y_H_M      0x07
#define LSM303DLM_OUT_Y_L_M      0x08
#define LSM303DLHC_OUT_Z_H_M     0x05
#define LSM303DLHC_OUT_Z_L_M     0x06
#define LSM303DLHC_OUT_Y_H_M     0x07
#define LSM303DLHC_OUT_Y_L_M     0x08
class LSM303
  public:
    typedef struct vector
      float x, y, z;
    } vector;
    vector a; // accelerometer readings
    vector m; // magnetometer readings
    vector m_max; // maximum magnetometer values, used for calibration
    vector m_min; // minimum magnetometer values, used for calibration
    byte last_status; // status of last I2C transmission
    // HEX  = BIN          RANGE    GAIN X/Y/Z        GAIN Z
    //                               DLH (DLM/DLHC)    DLH (DLM/DLHC)
    // 0x20 = 0b00100000   ±1.3     1055 (1100)        950 (980) (default)
    // 0x40 = 0b01000000   ±1.9      795  (855)        710 (760)
    // 0x60 = 0b01100000   ±2.5      635  (670)        570 (600)
    // 0x80 = 0b10000000   ±4.0      430  (450)        385 (400)
    // 0xA0 = 0b10100000   ±4.7      375  (400)        335 (355)
    // 0xC0 = 0b11000000   ±5.6      320  (330)        285 (295)
    // 0xE0 = 0b11100000   ±8.1      230  (230)        205 (205)
    enum magGain { magGain_13 = 0x20, magGain_19 = 0x40, magGain_25 = 0x60, magGain_40 = 0x80,
                   magGain_47 = 0xA0, magGain_56 = 0xC0, magGain_81 = 0xE0 };
    LSM303(void);
    void init(byte device = LSM303_DEVICE_AUTO, byte sa0_a = LSM303_SA0_A_AUTO);
    byte getDeviceType(void) { return _device; }
    void enableDefault(void);
    void writeAccReg(byte reg, byte value);
    byte readAccReg(byte reg);
    void writeMagReg(byte reg, byte value);
    byte readMagReg(int reg);
    void setMagGain(magGain value);
    void readAcc(void);
    void readMag(void);
    void read(void);
    void setTimeout(unsigned int timeout);
    unsigned int getTimeout(void);
    bool timeoutOccurred(void);
    int heading(void);
    int heading(vector from);
    // vector functions
    static void vector_cross(const vector *a, const vector *b, vector *out);
    static float vector_dot(const vector *a,const vector *b);
    static void vector_normalize(vector *a);
  private:
    byte _device; // chip type (DLH, DLM, or DLHC)
    byte acc_address;
    unsigned int io_timeout;
    bool did_timeout;
    byte detectSA0_A(void);
#endif
#include "./LSM303.h"
#include <Wire.h>
#include <math.h>
// Defines ////////////////////////////////////////////////////////////////
// The Arduino two-wire interface uses a 7-bit number for the address,
// and sets the last bit correctly based on reads and writes
#define MAG_ADDRESS            (0x3C >> 1)
#define ACC_ADDRESS_SA0_A_LOW  (0x30 >> 1)
#define ACC_ADDRESS_SA0_A_HIGH (0x32 >> 1)
// Constructors ////////////////////////////////////////////////////////////////
LSM303:SM303(void)
  // These are just some values for a particular unit; it is recommended that
  // a calibration be done for your particular unit.
  m_max.x = +540; m_max.y = +500; m_max.z = 180;
  m_min.x = -520; m_min.y = -570; m_min.z = -770;
  _device = LSM303_DEVICE_AUTO;
  acc_address = ACC_ADDRESS_SA0_A_LOW;
  io_timeout = 0;  // 0 = no timeout
  did_timeout = false;
// Public Methods //////////////////////////////////////////////////////////////
bool LSM303::timeoutOccurred()
  return did_timeout;
void LSM303::setTimeout(unsigned int timeout)
  io_timeout = timeout;
unsigned int LSM303::getTimeout()
  return io_timeout;
void LSM303::init(byte device, byte sa0_a)
  _device = device;
        Serial.print("device");
        Serial.print("sa0_a");
  switch (_device)
    case LSM303DLH_DEVICE:
    case LSM303DLM_DEVICE:
      if (sa0_a == LSM303_SA0_A_LOW)
      else if (sa0_a == LSM303_SA0_A_HIGH)
        acc_address = ACC_ADDRESS_SA0_A_HIGH;
        acc_address = (detectSA0_A() == LSM303_SA0_A_HIGH) ? ACC_ADDRESS_SA0_A_HIGH : ACC_ADDRESS_SA0_A_LOW;
    case LSM303DLHC_DEVICE:
    default:
        Serial.print("Init here?");
      // try to auto-detect device
      if (detectSA0_A() == LSM303_SA0_A_HIGH)
        // if device responds on 0011001b (SA0_A is high), assume DLHC
        _device = LSM303DLHC_DEVICE;
        Serial.print("Init here...1");
        // otherwise, assume DLH or DLM (pulled low by default on Pololu boards); query magnetometer WHO_AM_I to differentiate these two
        _device = (readMagReg(LSM303_WHO_AM_I_M) == 0x3C) ? LSM303DLM_DEVICE : LSM303DLH_DEVICE;
        Serial.print("Init here...2");
// Turns on the LSM303's accelerometer and magnetometers and places them in normal
// mode.
void LSM303::enableDefault(void)
  // Enable Accelerometer
  // 0x27 = 0b00100111
  // Normal power mode, all axes enabled
  writeAccReg(LSM303_CTRL_REG1_A, 0x27);
  // Enable Magnetometer
  // 0x00 = 0b00000000
  // Continuous conversion mode
  writeMagReg(LSM303_MR_REG_M, 0x00);
// Writes an accelerometer register
void LSM303::writeAccReg(byte reg, byte value)
  Wire.beginTransmission(acc_address);
  Wire.write(reg);
  Wire.write(value);
  last_status = Wire.endTransmission();
  Serial.print("writeAdd=");
  Serial.println(reg, HEX);
  Serial.print("last_status = ");
  Serial.println(last_status);
// Reads an accelerometer register
byte LSM303::readAccReg(byte reg)
  byte value;
  Wire.write(reg);
  Wire.requestFrom(acc_address, (byte)1);
  value = Wire.read();
  return value;
// Writes a magnetometer register
void LSM303::writeMagReg(byte reg, byte value)
  Wire.beginTransmission(MAG_ADDRESS);
  Wire.write(reg);
  Wire.write(value);
// Reads a magnetometer register
byte LSM303::readMagReg(int reg)
  byte value;
  // if dummy register address (magnetometer Y/Z), use device type to determine actual address
  if (reg < 0)
    switch (reg)
      case LSM303_OUT_Y_H_M:
        reg = (_device == LSM303DLH_DEVICE) ? LSM303DLH_OUT_Y_H_M : LSM303DLM_OUT_Y_H_M;
      case LSM303_OUT_Y_L_M:
        reg = (_device == LSM303DLH_DEVICE) ? LSM303DLH_OUT_Y_L_M : LSM303DLM_OUT_Y_L_M;
      case LSM303_OUT_Z_H_M:
        reg = (_device == LSM303DLH_DEVICE) ? LSM303DLH_OUT_Z_H_M : LSM303DLM_OUT_Z_H_M;
      case LSM303_OUT_Z_L_M:
        reg = (_device == LSM303DLH_DEVICE) ? LSM303DLH_OUT_Z_L_M : LSM303DLM_OUT_Z_L_M;
  Wire.write(reg);
  Wire.requestFrom(MAG_ADDRESS, 1);
  return value;
void LSM303::setMagGain(magGain value)
  Wire.write(LSM303_CRB_REG_M);
  Wire.write((byte) value);
// Reads the 3 accelerometer channels and stores them in vector a
void LSM303::readAcc(void)
  // assert the MSB of the address to get the accelerometer
  // to do slave-transmit subaddress updating.
  Wire.write(LSM303_OUT_X_L_A | (1 << 7));
  Wire.requestFrom(acc_address, (byte)6);
  unsigned int millis_start = millis();
  while (Wire.available() < 6) {
    if (io_timeout > 0 && ((unsigned int)millis() - millis_start) > io_timeout) {
      did_timeout = true;
      return;
  byte xla = Wire.read();
  byte xha = Wire.read();
  byte yla = Wire.read();
  byte yha = Wire.read();
  byte zla = Wire.read();
  byte zha = Wire.read();
  // combine high and low bytes, then shift right to discard lowest 4 bits (which are meaningless)
  // GCC performs an arithmetic right shift for signed negative numbers, but this code will not work
  // if you port it to a compiler that does a logical right shift instead.
  a.x = ((int16_t)(xha << 8 | xla)) >> 4;
  a.y = ((int16_t)(yha << 8 | yla)) >> 4;
  a.z = ((int16_t)(zha << 8 | zla)) >> 4;
// Reads the 3 magnetometer channels and stores them in vector m
void LSM303::readMag(void)
  Wire.write(LSM303_OUT_X_H_M);
  Wire.requestFrom(MAG_ADDRESS, 6);
      did_timeout = true;
      return;
  byte xhm = Wire.read();
  byte xlm = Wire.read();
  byte yhm, ylm, zhm, zlm;
  if (_device == LSM303DLH_DEVICE)
    // DLH: register address for Y comes before Z
    yhm = Wire.read();
    ylm = Wire.read();
    zhm = Wire.read();
    zlm = Wire.read();
    // DLM, DLHC: register address for Z comes before Y
    zhm = Wire.read();
    zlm = Wire.read();
    yhm = Wire.read();
    ylm = Wire.read();
  m.x = (int16_t)(xhm << 8 | xlm);
  m.y = (int16_t)(yhm << 8 | ylm);
  m.z = (int16_t)(zhm << 8 | zlm);
// Reads all 6 channels of the LSM303 and stores them in the object variables
void LSM303::read(void)
  readAcc();
  readMag();
// Returns the number of degrees from the -Y axis that it
// is pointing.
int LSM303::heading(void)
  return heading((vector){0,-1,0});
// Returns the number of degrees from the From vector projected into
// the horizontal plane is away from north.
// Description of heading algorithm:
// Shift and scale the magnetic reading based on calibration data to
// to find the North vector. Use the acceleration readings to
// determine the Down vector. The cross product of North and Down
// vectors is East. The vectors East and North form a basis for the
// horizontal plane. The From vector is projected into the horizontal
// plane and the angle between the projected vector and north is
// returned.
int LSM303::heading(vector from)
    // shift and scale
    m.x = (m.x - m_min.x) / (m_max.x - m_min.x) * 2 - 1.0;
    m.y = (m.y - m_min.y) / (m_max.y - m_min.y) * 2 - 1.0;
    m.z = (m.z - m_min.z) / (m_max.z - m_min.z) * 2 - 1.0;
    vector temp_a = a;
    // normalize
    vector_normalize(&temp_a);
    //vector_normalize(&m);
    // compute E and N
    vector E;
    vector N;
    vector_cross(&m, &temp_a, &E);
    vector_normalize(&E);
    vector_cross(&temp_a, &E, &N);
    // compute heading
    int heading = round(atan2(vector_dot(&E, &from), vector_dot(&N, &from)) * 180 / M_PI);
    if (heading < 0) heading += 360;
  return heading;
void LSM303::vector_cross(const vector *a,const vector *b, vector *out)
  out->x = a->y*b->z - a->z*b->y;
  out->y = a->z*b->x - a->x*b->z;
  out->z = a->x*b->y - a->y*b->x;
float LSM303::vector_dot(const vector *a,const vector *b)
  return a->x*b->x+a->y*b->y+a->z*b->z;
void LSM303::vector_normalize(vector *a)
  float mag = sqrt(vector_dot(a,a));
  a->x /= mag;
  a->y /= mag;
  a->z /= mag;
// Private Methods //////////////////////////////////////////////////////////////
byte LSM303::detectSA0_A(void)
  Wire.beginTransmission(ACC_ADDRESS_SA0_A_LOW);
  Wire.write(LSM303_CTRL_REG1_A);
    Serial.print("last_status=");                                                               ///////这里返回就是2了
    Serial.print(last_status);
  Wire.requestFrom(ACC_ADDRESS_SA0_A_LOW, 1);
  if (Wire.available())
    Serial.print("     Wire.available");
    Wire.read();
    return LSM303_SA0_A_LOW;
    Serial.print("Wire.unavailable");
    return LSM303_SA0_A_HIGH;
#include <Wire.h>
LSM303 compass;
LSM303::vector running_min = {2047, 2047, 2047}, running_max = {-2048, -2048, -2048};
  Wire.begin();
  compass.init();
  compass.enableDefault();
  Serial.print("setupover...");
  Serial.print(".");
//  compass.read();
//  running_min.x = min(running_min.x, compass.m.x);
//  running_min.y = min(running_min.y, compass.m.y);
//  running_min.z = min(running_min.z, compass.m.z);
//  running_max.x = max(running_max.x, compass.m.x);
//  running_max.y = max(running_max.y, compass.m.y);
//  running_max.z = max(running_max.z, compass.m.z);
//  Serial.print("M min ");
//  Serial.print("X: ");
//  Serial.print((int)running_min.x);
//  Serial.print(" Y: ");
//  Serial.print((int)running_min.y);
//  Serial.print(" Z: ");
//  Serial.print((int)running_min.z);
//  Serial.print(" M max ");
//  Serial.print((int)running_max.x);
//  Serial.print((int)running_max.y);
//  Serial.println((int)running_max.z);
  delay(1000);
发表于 2015-4-13 15:15:30 | 显示全部楼层
TWI通信,不知道是否有指示灯?
 楼主| 发表于 2015-4-14 06:27:55 来自手机 | 显示全部楼层
没有灯,这样接twi需要上拉电阻吗?
GMT+8, 2026-6-19 02:00 , Processed in 0.036144 second(s), 19 queries .
