查看: 14600|回复: 5
大家帮我看看程序是哪里错了
发表于 2015-5-2 07:25:45 | 显示全部楼层 |阅读模式
这个控制16*16点阵字符滚动的程序哪里错误了?
#include <Arduino.h>
//IO配置
#define LEDARRAY_D 2
#define LEDARRAY_C 3
#define LEDARRAY_B 4
#define LEDARRAY_A 5
#define LEDARRAY_G 6
#define LEDARRAY_DI 7
#define LEDARRAY_CLK 8
#define LEDARRAY_LAT 9
#define led 13
#define Num_Word 1                                //液晶能显示的汉字个数
unsigned char Display_Buffer[2];
unsigned char Display_Swap_Buffer[Num_Word][32]={0};                                        //显示缓冲区
bool Shift_Bit = 0;
bool Flag_Shift = 0;
unsigned char Timer0_Count = 0;
unsigned char temp = 0x80;
unsigned char Shift_Count = 0;
unsigned char Display_Word_Count = 0;
#define Num_Of_Word 6
const unsigned char Word[Num_Of_Word][32] =
0xFF,0xF8,0x07,0x77,0x74,0x75,0x75,0x75,0x75,0x04,0x75,0x7F,0xFF,0xFF,0xFF,0xFF
0xFF,0x01,0xFB,0xFB,0x1B,0xDB,0xDB,0xDB,0xDB,0x1B,0xDB,0xFB,0xFB,0xDB,0xEB,0xF7,/*"呵",0*/
0xFF,0x01,0xFB,0xFB,0x1B,0xDB,0xDB,0xDB,0xDB,0x1B,0xDB,0xFB,0xFB,0xDB,0xEB,0xF7,/*"呵",1*/
0xFF,0x01,0xFB,0xFB,0x1B,0xDB,0xDB,0xDB,0xDB,0x1B,0xDB,0xFB,0xFB,0xDB,0xEB,0xF7,/*"呵",2*/
0xFF,0x01,0xFB,0xFB,0x1B,0xDB,0xDB,0xDB,0xDB,0x1B,0xDB,0xFB,0xFB,0xDB,0xEB,0xF7,/*"呵",3*/
0xBF,0xDE,0xCE,0xDE,0xFE,0xFE,0x1D,0xDA,0xDE,0xDE,0xDF,0xDF,0xD7,0xCF,0xDC,0xF3,
0xFF,0x0F,0xEF,0xEF,0xEF,0xEF,0xF1,0x07,0xF7,0xF7,0x6F,0x6F,0x9F,0x6F,0xF1,0xFB,/*"设",4*/
0xBF,0xDF,0xCF,0xDF,0xFF,0x0C,0xEF,0xEF,0xEF,0xEF,0xEF,0xED,0xEB,0xE7,0xEF,0xFF,
0xDF,0xDF,0xDF,0xDF,0xDF,0x01,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,/*"计",5*/
        pinMode(LEDARRAY_D, OUTPUT);
        pinMode(LEDARRAY_C, OUTPUT);
        pinMode(LEDARRAY_B, OUTPUT);
        pinMode(LEDARRAY_A, OUTPUT);
        pinMode(LEDARRAY_G, OUTPUT);
        pinMode(LEDARRAY_DI, OUTPUT);
        pinMode(LEDARRAY_CLK, OUTPUT);
        pinMode(LEDARRAY_LAT, OUTPUT);
        Clear_Display();
        unsigned int i;
        for(i = 0 ; i < 30; i ++)                        //移动速度设定
                Display(Display_Swap_Buffer);
        Display_Word_Count = Shift_Count/16;                                //计算当前显示第几个字
        Calc_Shift();
        Shift_Count++;
        if(Shift_Count == (Num_Of_Word+1)*16 )                                //移动次数
                Shift_Count = 0;
//清空缓冲区
void Clear_Display()
        unsigned char i,j;
        for(j = 0 ; j < Num_Word; j++)
                for(i = 0 ; i < 32 ;i++)
                        Display_Swap_Buffer[j] = 0xff;                                //0=显示  1=不显示
//计算移动数据,存在在缓冲器
void Calc_Shift()
        unsigned char i;
        for(i = 0;i < 16;i++)
                if((Display_Swap_Buffer[0][16+i]&0x80) == 0)        //前8位        移位
                        Display_Swap_Buffer[0] = (Display_Swap_Buffer[0] << 1)&0xfe;                         //最低位清零
                        Display_Swap_Buffer[0] = (Display_Swap_Buffer[0] << 1)|0x01;                        //最低位置一
                if(Shift_Count%16 < 8 && Display_Word_Count < Num_Of_Word)
                        Shift_Bit = Word[Display_Word_Count]&temp;
                else if(Shift_Count%16 < 16 && Display_Word_Count < Num_Of_Word)
                        Shift_Bit = Word[Display_Word_Count][16+i]&temp;
                        Shift_Bit = 1;                                                //把字移出缓冲区
                if( Shift_Bit == 0)        //后8位移位
                        Display_Swap_Buffer[0][16+i] = (Display_Swap_Buffer[0][16+i] << 1)&0xfe;                 //最低位清零
                        Shift_Bit =        1;
                        Display_Swap_Buffer[0][16+i] = (Display_Swap_Buffer[0][16+i] << 1)|0x01;                //最低位置一
        temp = (temp>>1)&0x7f;
        if(temp == 0x00)
                temp = 0x80;
//num为字数  dat[][32]为字模的名称
void Display(unsigned char dat[][32])
        unsigned char i;
        for( i = 0 ; i < 16 ; i++ )
                digitalWrite(LEDARRAY_G, HIGH);                //更新数据时候关闭显示。等更新完数据,打开138显示行。防止重影。
                Display_Buffer[0] = dat[0];
                Display_Buffer[1] = dat[0][i+16];
                Send(Display_Buffer[1]);
                Send(Display_Buffer[0]);
                digitalWrite(LEDARRAY_LAT, HIGH);                                        //锁存数据
                delayMicroseconds(1);
                digitalWrite(LEDARRAY_LAT, LOW);
                Scan_Line(i);                                                //选择第i行
                digitalWrite(LEDARRAY_G, LOW);
                delayMicroseconds(300);;                //延时一段时间,让LED亮起来。
//扫描某一行
void Scan_Line( unsigned char m)
        switch(m)
                case 0:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
                case 1:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
                case 2:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
                case 3:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
                case 4:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
                case 5:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
                case 6:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
                case 7:
                        digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
                case 8:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
                case 9:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
                case 10:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
                case 11:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
                case 12:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
                case 13:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
                case 14:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
                case 15:
                        digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
                default : break;
//发送数据
void Send( unsigned char dat)
        unsigned char i;
        digitalWrite(LEDARRAY_CLK, LOW);
        delayMicroseconds(1);;
        for( i = 0 ; i < 8 ; i++ )
                if( dat&0x01 )
                        digitalWrite(LEDARRAY_DI, HIGH);
                        digitalWrite(LEDARRAY_DI, LOW);
                digitalWrite(LEDARRAY_CLK, HIGH);                                //上升沿发送数据
                dat >>= 1;
发表于 2015-5-2 09:33:47 | 显示全部楼层
              少了;及}
发表于 2015-5-2 11:22:26 | 显示全部楼层
参考一下下面的代码吧:
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
发表于 2015-5-2 13:31:35 | 显示全部楼层
少了几个 , 逗号
发表于 2015-5-2 18:20:26 | 显示全部楼层
你多了一个逗号 ,
仔细看
在最后面注释之前
发表于 2015-5-2 18:22:36 | 显示全部楼层
tsaiwn 发表于 2015-5-2 18:20
你多了一个逗号 ,
仔细看
其他人都乱讲
我说的才对
GMT+8, 2026-7-26 23:32 , Processed in 0.036960 second(s), 22 queries .
