查看: 14785|回复: 0
arduino菜鸟求助
发表于 2015-5-9 17:04:45 | 显示全部楼层 |阅读模式
哪位大神能不能帮忙把这程序修改一下,让如果测得颜色是红色的话就让数字输出8端口为高电平,如果是蓝色就让8口为低电平。(程序是在http://www.geek-workshop.com/forum.php?mod=viewthread&tid=805上看见的),十分感谢!
#include <TimerOne.h>
#define S0 6 // Please notice the Pin's define
#define S1 5
#define S2 4
#define S3 3
#define OUT 2
int g_count = 0; // count the frequecy
int g_array[3]; // store the RGB value
int g_flag = 0; // filter of RGB queue
float g_SF[3]; // save the RGB Scale factor
// Init TSC230 and setting Frequency.
void TSC_Init()
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(OUT, INPUT);
digitalWrite(S0, LOW); // OUTPUT FREQUENCY SCALING 2%
digitalWrite(S1, HIGH);
// Select the filter color
void TSC_FilterColor(int Level01, int Level02)
if(Level01 != 0)
Level01 = HIGH;
if(Level02 != 0)
Level02 = HIGH;
digitalWrite(S2, Level01);
digitalWrite(S3, Level02);
void TSC_Count()
g_count ++ ;
void TSC_Callback()
switch(g_flag)
case 0:
Serial.println("->WB Start");
TSC_WB(LOW, LOW); //Filter without Red
case 1:
Serial.print("->Frequency R=");
Serial.println(g_count);
g_array[0] = g_count;
TSC_WB(HIGH, HIGH); //Filter without Green
case 2:
Serial.print("->Frequency G=");
g_array[1] = g_count;
TSC_WB(LOW, HIGH); //Filter without Blue
case 3:
Serial.print("->Frequency B=");
Serial.println("->WB End");
g_array[2] = g_count;
TSC_WB(HIGH, LOW); //Clear(no filter)
default:
g_count = 0;
void TSC_WB(int Level0, int Level1) //White Balance
g_count = 0;
g_flag ++;
TSC_FilterColor(Level0, Level1);
Timer1.setPeriod(1000000); // set 1s period
TSC_Init();
Timer1.initialize(); // defaulte is 1s
Timer1.attachInterrupt(TSC_Callback);
attachInterrupt(0, TSC_Count, RISING);
delay(4000);
for(int i=0; i<3; i++)
Serial.println(g_array[i]);
g_SF[0] = 255.0/ g_array[0]; //R Scale factor
g_SF[1] = 255.0/ g_array[1] ; //G Scale factor
g_SF[2] = 255.0/ g_array[2] ; //B Scale factor
Serial.println(g_SF[0]);
Serial.println(g_SF[1]);
Serial.println(g_SF[2]);
g_flag = 0;
Serial.println(int(g_array[i] * g_SF[i]));
delay(4000);
GMT+8, 2026-6-17 09:03 , Processed in 0.038660 second(s), 18 queries .
