查看: 26820|回复: 9
帮忙看一下,MPU6050这样融合后的数据是否可以做平衡车了?
发表于 2012-7-24 16:54:09 | 显示全部楼层 |阅读模式
完全不懂卡尔曼,就用所谓的一阶互补,源程序先贴上:(其中的K值取多少,我也不懂原理和计算)
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define Gry_offset 161  //static deviation of the x-axis
#define Gyr_Gain 0.0763 // =1/131
#define ACC_Gain 0.000061 // =1/16384
#define pi 3.1415926
#define K 0.715  //互补滤波权重取值
float angleG;
float A;
unsigned long timer = 0;
unsigned long preTime = 0;
    Wire.begin();
    Serial.begin(38400);
    accelgyro.initialize();
    delay(500);
    unsigned long now = millis();                           // 当前时间(ms)
    float dt = (now - preTime) / 1000.0;                    // 微分时间(s)
    preTime = now;
    // these methods (and a few others) are also available
    //accelgyro.getAcceleration(&ax, &ay, &az);
    float Y_Accelerometer = ay * ACC_Gain;   // 获取向前的加速度
    float Z_Accelerometer = az * ACC_Gain;   // 获取向下的加速度
    float angleA = atan(Y_Accelerometer / Z_Accelerometer) * 180 / pi;
    float omega =  Gyr_Gain * ( gx +  Gry_offset);
    float A =  K / (K + dt);
    angleG = A * (angleG + omega * dt) + (1-A) * angleA;
    Serial.print(angleA, 6);
    Serial.print(",");
    Serial.print(angleG,6);
    Serial.print("\n");
    delay(10);
静态时的数据如下:
1.962590,1.517662
1.562366,1.532969
1.593743,1.525755
1.491260,1.538712
1.611358,1.539084
1.591573,1.523348
1.499220,1.520789
1.542325,1.501054
1.651118,1.486202
1.848107,1.487913
1.793320,1.447107
1.780802,1.434657
1.591140,1.427784
2.093552,1.433617
1.780723,1.418282
2.170431,1.452794
2.056911,1.430457
1.991959,1.375236
1.915277,1.395300
2.013110,1.410308
2.108475,1.433622
2.062564,1.463360
动态下曲线感觉也不错!不会贴图,再给点数据吧(敲击桌子时的):
4.597043,-1.081621
1.549426,-1.033189
-0.046595,-0.683347
0.426747,-0.818596
1.649786,-0.912630
3.280285,-0.741279
1.147905,-0.712550
-0.708813,-0.782673
-0.569814,-0.197119
-7.030243,-0.973573
0.032966,-1.350268
2.945956,-1.322242
-1.735231,-1.159333
0.861879,-1.134137
3.091095,-1.442734
1.323532,-1.244867
1.827124,-0.942808
10.706529,-2.613306
14.784671,-2.214338
-0.499738,-1.116414
-0.814508,-1.026801
6.542530,-1.810651
2.181357,-1.512274
发表于 2012-7-24 21:21:55 | 显示全部楼层
学习了.....
发表于 2012-7-25 10:01:18 | 显示全部楼层
卡尔曼 博大精深,学习了!
 楼主| 发表于 2012-7-25 10:50:47 | 显示全部楼层
互补滤波权权重取值应该也是动态的,我不知道原理,希望有路过的高手指点一下!!!
目前的情况是,剧烈晃动以后,angleG值(滤波后的角度值)还是有滞后,我已经将K值取0.715了。。。。。
发表于 2012-7-25 12:30:01 | 显示全部楼层
将DT   那             /5000   发散的更快?
发表于 2012-8-5 03:58:17 | 显示全部楼层
自己网上找找 Kalman的代码 能找到的都是一个人写的 我们自己在平衡车上用的参数 就是一下一组可以尝试看看滤波效果
0.001   0.003  0.5   0.01
发表于 2012-8-5 09:16:31 | 显示全部楼层
牛人玩到后来都是数学。。。。。
发表于 2012-8-6 13:04:23 | 显示全部楼层
LZ怎么这么多号的?
发表于 2012-12-19 11:01:26 | 显示全部楼层
学习中……………………
发表于 2013-6-15 19:38:20 | 显示全部楼层
lz angleA代表什么啊?是不是车的倾斜角度?如果是的话,我怎么感觉这个计算是错的啊, float angleA = atan(Y_Accelerometer / Z_Accelerometer) * 180 / pi;我觉得是float angleA = atan(Z_Accelerometer / Y_Accelerometer) * 180 / pi;不知道是不是哪里想错了。
GMT+8, 2026-7-27 02:14 , Processed in 0.037389 second(s), 24 queries .
