材料:
1.DHT11
2.LCD1602
3.LCD1602 转接板
4.Arduino UNO
5.Arduino 传感器扩展版
那个Arduino UNO 我当初挑类个便宜的山寨货买,结果发来和正版的长得一样 O(∩_∩)O吓死我了,,,,
代码如下:
- double Fahrenheit(double celsius)
- return 1.8 * celsius + 32;
- } //摄氏温度度转化为华氏温度
- double Kelvin(double celsius)
- return celsius + 273.15;
- } //摄氏温度转化为开氏温度
- // 露点(点在此温度时,空气饱和并产生露珠)
- // 参考: [url=http://wahiduddin.net/calc/density_algorithms.htm]http://wahiduddin.net/calc/density_algorithms.htm[/url]
- double dewPoint(double celsius, double humidity)
- double A0= 373.15/(273.15 + celsius);
- double SUM = -7.90298 * (A0-1);
- SUM += 5.02808 * log10(A0);
- SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
- SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
- SUM += log10(1013.246);
- double VP = pow(10, SUM-3) * humidity;
- double T = log(VP/0.61078); // temp var
- return (241.88 * T) / (17.558-T);
- // 快速计算露点,速度是5倍dewPoint()
- // 参考: [url=http://en.wikipedia.org/wiki/Dew_point]http://en.wikipedia.org/wiki/Dew_point[/url]
- double dewPointFast(double celsius, double humidity)
- double a = 17.271;
- double b = 237.7;
- double temp = (a * celsius) / (b + celsius) + log(humidity/100);
- double Td = (b * temp) / (a - temp);
- return Td;
- #include <dht11.h>
- #include <Wire.h>
- #include <LiquidCrystal_I2C.h>
- LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
- dht11 DHT11;
- #define DHT11PIN 2
- void setup()
- lcd.init(); // initialize the lcd
- lcd.backlight();
- lcd.print("Waiting...");
- Serial.begin(9600);
- void loop()
- int chk = DHT11.read(DHT11PIN);
- switch (chk)
- case DHTLIB_OK:
- lcd.setCursor(0, 0);
- lcd.print("Temp:");
- lcd.print((float)DHT11.temperature,2);
- lcd.write(0xDF);
- lcd.print("C");
- lcd.setCursor(0, 1);
- lcd.print("Humidity:");
- lcd.print((float)DHT11.humidity,2);
- lcd.print("%");
- break;
- case DHTLIB_ERROR_CHECKSUM:
- lcd.clear();
- lcd.print("Checksum error");
- delay(1000);
- lcd.clear();
- break;
- case DHTLIB_ERROR_TIMEOUT:
- lcd.clear();
- lcd.print("Time out error");
- delay(1000);
- lcd.clear();
- break;
- default:
- lcd.clear();
- lcd.print("Unknown error");
- delay(1000);
- lcd.clear();
- break;
- delay(1000);
复制代码 |
