查看: 11155|回复: 2
小白求助
发表于 2015-5-23 15:19:38 | 显示全部楼层 |阅读模式
#define DHT11_PIN 5      // DHT11  连接UNO 模拟端口PIN 5
#include<LiquidCrystal.h>
byte read_dht11_dat()
        byte i = 0;
        byte result=0;
        for(i=0; i< 8; i++){
                while(!(PINC & _BV(DHT11_PIN)));  // wait for 50us
                delayMicroseconds(30);
                if(PINC & _BV(DHT11_PIN))
                        result |=(1<<(7-i));
              while((PINC & _BV(DHT11_PIN)));  // wait '1' finish
        return result;
LiquidCrystal lcd(12,11,5,4,3,2);
  Serial.begin(19200);
  lcd.begin(20,2);
   DDRC |= _BV(DHT11_PIN);
   PORTC |= _BV(DHT11_PIN);
        byte dht11_dat[5];
        byte dht11_in;
        byte i;
        // start condition
        // 1. pull-down i/o pin from 18ms
        PORTC &= ~_BV(DHT11_PIN);
        delay(18);
        delayMicroseconds(40);
        DDRC &= ~_BV(DHT11_PIN);
        dht11_in = PINC & _BV(DHT11_PIN);
        if(dht11_in){
                Serial.println("dht11 start condition 1 not met");
                return;
        delayMicroseconds(80);
        if(!dht11_in){
                Serial.println("dht11 start condition 2 not met");
                return;
        // now ready for data reception
        for (i=0; i<5; i++)
                dht11_dat[i] = read_dht11_dat();
        byte dht11_check_sum = dht11_dat[0]+dht11_dat[1]+dht11_dat[2]+dht11_dat[3];
        // check check_sum
        if(dht11_dat[4]!= dht11_check_sum)
                Serial.println("DHT11 checksum error");
          lcd.setCursor(0,0);
         lcd.print("H = ");
         lcd.print(dht11_dat[0], DEC);
         lcd.print(".");
         lcd.print(dht11_dat[1], DEC);
         lcd.print("%  ");
         lcd.setCursor(0,1);
         lcd.print("t = ");
         lcd.print(dht11_dat[2], DEC);
         lcd.print(".");
         lcd.print(dht11_dat[3], DEC);
         lcd.print("C  ");
        delay(200);
为何程序对了,上传之后   屏幕不显示啊
 楼主| 发表于 2015-5-23 15:21:22 | 显示全部楼层
lcd2004的屏幕
发表于 2015-5-23 17:04:02 | 显示全部楼层
同楼上
嗯,应该是LED的问题
GMT+8, 2026-7-26 19:17 , Processed in 0.038347 second(s), 19 queries .
