查看: 11452|回复: 0
发一个教科书莫尔斯电码程序献丑。附数组问题一枚。
发表于 2015-6-3 19:45:48 | 显示全部楼层 |阅读模式
第三行 char* letters[]这一段,会使用但有点不明就里。
letters[k]是指向第k个字符串的指针,比如说letters[0]指向".-\0",letters[4]指向".\0"
letters[k],k从0到25就是一个数组,数组元素就是上面所说的指针。
如此说来的话,这个数组是不是可以定义成 char letters[26][4]呢,如果这样应该怎么写?是不是比直接用 char * letters[]要浪费存储空间?
附:字符串数组
string str1 = "hello";
char *str1 = "hello"
char str1[6] = "hello";
以上都正确?
const int ledPin = 2;
const int buzzPin = 3;
char* letters[]={
  ".-", "-...", "-.-.", "-..", ".", "..-.", "--.", //ABCDEFG
  "....", "..", ".---", "-.-", ".-..", "--", "-.", //HIJKLMN
  "---", ".--.", "--.-", ".-.", "...", "-", //OPQRST
  "..-", "...-", ".--", "-..-", "-.--", "--.." //UVWXYZ
char* numbers[]={
  "-----",".----","..---","...--","....-", //01234
  ".....","-....","--...","---..","----." //56789
int dotDelay = 50;
  pinMode(ledPin,OUTPUT);
  pinMode(buzzPin,OUTPUT);
  char ch;
  if (Serial.available())
    ch = Serial.read();
    if (ch>='a' && ch<='z')
      flashSequence(letters[ch-'a']);
    else if (ch>='A' && ch<='Z')
      flashSequence(letters[ch-'A']);
    else if (ch>='0' && ch<='9')
      flashSequence(numbers[ch-'0']);
    else if (ch == ' ')
      delay(dotDelay * 4);
    else if (ch == '+')
      dotDelay+=10;
      Serial.print("dotDelay is");
      Serial.println(dotDelay);
    else if (ch == '-')
      dotDelay-=10;
      dotDelay = (dotDelay>0)?dotDelay:10;
void flashSequence(char* sequence)
  int i = 0;
  while (sequence[i] != NULL)
    flashDotOrDash(sequence[i]);
    i++;
  delay(dotDelay * 3);
void flashDotOrDash(char dotOrDash)
  digitalWrite(ledPin,HIGH);
  digitalWrite(buzzPin,HIGH);
  if (dotOrDash == '.')
    delay(dotDelay);
  digitalWrite(ledPin,LOW);
  digitalWrite(buzzPin,LOW);
  delay(dotDelay);
GMT+8, 2026-7-27 00:38 , Processed in 0.035817 second(s), 17 queries .
