查看: 14322|回复: 0
arduino nano程序上传不进去
发表于 2015-6-15 21:23:25 | 显示全部楼层 |阅读模式
板子是Nano V3.0,IDE是1.6.4,WIN7旗舰版操作系统。安装IDE时驱动直接安装成功了,设备管理器里面没有未知设备,端口那一栏下面接Nano的时候出现USB Serial Port(COM10),感觉有点奇怪,但点进去更新驱动报告已经是最新驱动。
接下来上传程序的时候工具栏里面的板子、处理器、端口都是选对的,编程器选的默认的AVRISP mkII,烧录程序的时候报错:(手动Reset试过,外扩设备也暂时拔了,都没有用QAQ)
Arduino:1.6.4 (Windows 7), 板:"Arduino Nano, ATmega328"构建选项已变更,全部重新构建Sketch uses 6,010 bytes (19%) of program storage space. Maximum is 30,720 bytes.全局变量使用了293字节,(14%)的动态内存,余留1,755字节局部变量。最大为2,048字节。avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x06avrdude: stk500_recv(): programmer is not respondingavrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x06上传出错。查看页面 http://www.arduino.cc/en/Guide/Troubleshooting#upload 获取建议
GMT+8, 2026-7-27 01:15 , Processed in 0.032785 second(s), 18 queries .
