查看: 9930|回复: 1
编译失败求指教。下载国外的一个项目测试程序。
发表于 2015-6-21 13:36:09 | 显示全部楼层 |阅读模式
#define RawInput = 0
#define filteredInput = 1
#define ActiveInput 1
  Serial.begin(115200);  Init serial communication
  DDRB = 0B00000000;     All inputs (high impedance)
  DDRC = 0B00000000;     All inputs (high impedance)
  DDRD = 0B00000000;     All inputs (high impedance)
  DDRD = 10;
  ADC setup
  ADMUX =
  (0  REFS1)
  (1  REFS0)   AVcc ref with capacitor at AREF pin
  (0  ADLAR)   Keep right adjusted
  (0  MUX3)
  (0  MUX2)
  (0  MUX1)
  (1  MUX0);
  ADCSRA =
  (1  ADEN)   ADC enable
  (0  ADSC)   Dont start conversion now
  (0  ADATE)   Dont use auto trigger
  (1  ADIF)   Interrupt flag
  (1  ADIE)   Dont use interrupt
  (1  ADPS2)  ADC clock divider
  (0  ADPS1)
  (0  ADPS0);
  ADCSRB =
  (1  ACME)   Enable multiplexer
  (0  ADTS2)   Free running mpde
  (0  ADTS1)
  (0  ADTS0);
  AdcMux(ActiveInput);
  ADCSRA = (1  ADSC);  Start AD conversion;
  #define SAMPLES_TO_AVERAGE 10000 7500
  long averageCount =0;
  long count =0;
    #define SAMPLES_TO_PLOT 1000  500
  int readingArray[SAMPLES_TO_PLOT+2];
  long averageMode2 =0;
  int Average_count = 1000;
  int avgIterations =0;
  int ScanMode = 2;
ISR(ADC_vect) {
        uint8_t low, high;
        low  = ADCL;
        high = ADCH;
        averageMode2 += (high  8)  low; ADC;
                averageMode2 += ADC;
        averageMode2 += analogRead(1);
        avgIterations++;
        if (avgIterations == Average_count) {
        readingArray[count] = averageMode2  AVERAGE_COUNT_MODE2;
        count++;
        Serial.print(averageMode2);   AVERAGE_COUNT_MODE2);
        Serial.print(,);
        avgIterations = 0;
        averageMode2 =0;
        ADCSRA &= ~(1  ADIF);  Clear AD ready flag
        if (count == SAMPLES_TO_PLOT) {
        count =0;
          Serial.println(!);
void AdcMux(char muxNumber) {
ADMUX=0;
ADMUX &= ~(1  MUX3);  Set to 0
ADMUX &= ~(1  MUX2);  Set to 0
ADMUX &= ~(1  MUX1);  Set to 0
ADMUX &= ~(1  MUX0);  Set to 0
ADMUX = muxNumber;
char string_started = 0;
char serial_data[20];
int serial_index = 0;
void loop () {
  if (Serial.available()) {
   if (string_started == 1) {
       serial_data[serial_index++] = Serial.read();
       if (serial_data[serial_index-4] == 'F' && serial_data[serial_index-3] == 'H' && serial_data[serial_index-2] == 'S' && serial_data[serial_index-1] == 'S') {
             Average_count = 100;
             serial_index = 0;
             string_started=0;
      else if (serial_data[serial_index-4] == 'C' && serial_data[serial_index-3] == 'O' && serial_data[serial_index-2] == 'N' && serial_data[serial_index-1] == 'S') {
             serial_index = 0;
             string_started = 0;
      else if (serial_data[serial_index-3] == 'S' && serial_data[serial_index-2] == 'E' && serial_data[serial_index-1] == 'T') {
              Average_count = 0;
             for (int i = 0; i serial_index-3; i++) {
               Average_count = Average_count10 + (serial_data[i]-48);
             serial_index = 0;
             string_started = 0;
      if (serial_index = 20) {
         serial_index = 0;
         string_started = 0;
    else if (Serial.read() == '$') {
        string_started = 1;
发表于 2015-6-28 21:56:02 | 显示全部楼层
请发一下原文件的链接。
GMT+8, 2026-7-25 03:00 , Processed in 0.043138 second(s), 19 queries .
