#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int val;
char buffer[4];
lcd.begin(16,2);
if(Serial.available()>0){
char buffer[]={0};
Serial.readBytes(buffer, 4);
Serial.print("buffer: ");
Serial.println(buffer);
val=atoi(buffer);
Serial.print("val: ");
Serial.println(val);
if(val<10){
lcd.setCursor(0,0);
lcd.print("Front obstacle");
if(val>10){
lcd.setCursor(0,0);
lcd.print(" ");
这是代码,读取到的数据是buffer,三位数以内的,控制LCD显示屏的显示,请问问题出在哪里? |
