查看: 12607|回复: 0
新手求助
发表于 2015-7-25 10:24:20 | 显示全部楼层 |阅读模式
我买了攀藤PM2.5传感器,现在想让检测到的PM2.5,PM10的值显示在OLED上,可是我弄的代码显示不了,麻烦各位大神帮帮忙,跪谢大神!
#include <Wire.h>
#include <SSD1306.h>
#define OLED_CLK 9
#define OLED_MOSI 8
#define OLED_RESET 7
#define OLED_DC 6
SSD1306 oled(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, -1);
//#include <WCLHPM25.h>
Test on Uno R3.
M3C   UnoR3
TX <---> 0(Rx)
        static unsigned char ucRxBuffer[250];
        static unsigned char ucRxCnt = 0;
        long  pmcf10=0;
        long  pmcf25=0;
        long  pmcf100=0;
        long  pmat10=0;
        long  pmat25=0;
        long  pmat100=0;
        long  pmcount03=0;
        long  pmcount05=0;
        long  pmcount10=0;
        long  pmcount25=0;
        long  pmcount50=0;
        long  pmcount100=0;
   oled.ssd1306_init(SSD1306_SWITCHCAPVCC);
  oled.clear();
  oled.display();
  //int received data. Data was received in serialEvent;
   while (Serial.available())
    CopeSerialData(Serial.read());
  Serial.println("@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@");
  delay(5000);
char CopeSerialData(unsigned char ucData)
        long  pmcf10=0;
        long  pmcf25=0;
        long  pmcf100=0;
        long  pmat10=0;
        long  pmat25=0;
        long  pmat100=0;
        long  pmcount03=0;
        long  pmcount05=0;
        long  pmcount10=0;
        long  pmcount25=0;
        long  pmcount50=0;
        long  pmcount100=0;
        ucRxBuffer[ucRxCnt++]=ucData;
        if (ucRxBuffer[0]!=0x42&&ucRxBuffer[1]!=0x4D)
                ucRxCnt=0;
             return ucRxCnt;
        if (ucRxCnt<32) {return ucRxCnt;}
          for (int i=0;i<32;i++)
  {Serial.print(ucRxBuffer[i]);Serial.print("  ");}
  Serial.println("");
  pmcf10=(float)ucRxBuffer[4]*256+(float)ucRxBuffer[5];Serial.print("PM1.0_CF1:");Serial.print(pmcf10);Serial.print("   ");
  pmcf25=(float)ucRxBuffer[6]*256+(float)ucRxBuffer[7];Serial.print("PM2.5_CF1:");Serial.print(pmcf25);Serial.print("   ");
  pmcf100=(float)ucRxBuffer[8]*256+(float)ucRxBuffer[9];Serial.print("PM10_CF1:");Serial.print(pmcf100);Serial.println("   ");
  pmat10=(float)ucRxBuffer[10]*256+(float)ucRxBuffer[11];  Serial.print("PM1.0_AT:");Serial.print(pmat10);Serial.print("   ");
  pmat25=(float)ucRxBuffer[12]*256+(float)ucRxBuffer[13];  Serial.print("PM2.5_AT:");Serial.print(pmat25);Serial.print("   ");
  pmat100=(float)ucRxBuffer[14]*256+(float)ucRxBuffer[15];  Serial.print("PM10_AT:");Serial.print(pmat100);Serial.println("   ");
  pmcount03=(float)ucRxBuffer[16]*256+(float)ucRxBuffer[17];  Serial.print("PMcount0.3:");Serial.print(pmcount03);Serial.print("   ");
  pmcount05=(float)ucRxBuffer[18]*256+(float)ucRxBuffer[19];  Serial.print("PMcount0.5:");Serial.print(pmcount05);Serial.print("   ");
  pmcount10=(float)ucRxBuffer[20]*256+(float)ucRxBuffer[21];  Serial.print("PMcount1.0:");Serial.print(pmcount10);Serial.println("   ");
  pmcount25=(float)ucRxBuffer[22]*256+(float)ucRxBuffer[23];  Serial.print("PMcount2.5:");Serial.print(pmcount25);Serial.print("   ");
  pmcount50=(float)ucRxBuffer[24]*256+(float)ucRxBuffer[25];  Serial.print("PMcount5.0:");Serial.print(pmcount50);Serial.print("   ");
  pmcount100=(float)ucRxBuffer[26]*256+(float)ucRxBuffer[27];  Serial.print("PMcount10:");Serial.print(pmcount100);Serial.println("   ");
Serial.println(" *****************************************************************  ");
        ucRxCnt=0;
        return ucRxCnt;
  char temp[5];
  dtostrf(pmcount25,5,2,temp);
  strcat(temp,"PM2.5");
  oled.clear();
  oled.drawstring(22,4,temp);
  oled.display();
GMT+8, 2026-7-28 06:17 , Processed in 0.033455 second(s), 18 queries .
