查看: 10619|回复: 0
倒车雷达
发表于 2015-7-30 11:37:23 | 显示全部楼层 |阅读模式
const int TrigPin = 2;
const int EchoPin = 3;
float cm;
pinMode(TrigPin, OUTPUT);
pinMode(EchoPin, INPUT);
pinMode(4,OUTPUT);
digitalWrite(TrigPin, LOW); //低高低电平发一个短时间脉冲去TrigPin
delayMicroseconds(2);
digitalWrite(TrigPin, HIGH);
delayMicroseconds(10);
cm = pulseIn(EchoPin, HIGH) / 58.0; //将回波时间换算成cm
cm = (int(cm * 100.0)) / 100.0; //保留两位小数
Serial.print(cm);
Serial.print("cm");
Serial.println();
if(cm>100.0)
digitalWrite(4,HIGH);
delay(100);
digitalWrite(4,LOW);
delay(1000);
if(cm>20.0 && cm<100.0)
delay(100);
delay(1000-(100-cm)*12.5);
if(cm<20.0)
GMT+8, 2026-6-18 05:39 , Processed in 0.039473 second(s), 16 queries .
