查看: 6679|回复: 8
这是mwc的i2c gps程序,谁能帮我看看哪里有错误吗
发表于 2015-8-2 16:56:33 | 显示全部楼层 |阅读模式
* I2CGPS  - Inteligent GPS and NAV module for MultiWii by EOSBandi
* V2.2
* This program implements position hold and navigational functions for MultiWii by offloading caclulations and gps parsing
* into a secondary arduino processor connected to the MultiWii via i2c.
* Once activated it outputs desired banking in a lat/lon coordinate system, which can be easily rotated into the copter's frame of reference.
* Navigation and Position hold routines and PI/PID libraries are based on code and ideas from the Arducopter team:
* Jason Short,Randy Mackay, Pat Hickey, Jose Julio, Jani Hirvinen
* Andrew Tridgell, Justin Beech, Adam Rivera, Jean-Louis Naudin, Roberto Navoni
* Status blink code from Guru_florida
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* any later version. see <http://www.gnu.org/licenses/>
* This library is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
* General Public License for more details.
#define VERSION 22                                                         //Software version for cross checking
#include "WireMW.h"
#include "PIDCtrl.h"
#include "PICtrl.h"
#include "LeadFilter.h"
#include "registers.h"                                                    //Register definitions
#include "config.h"
#define REG_MAP_SIZE       sizeof(i2c_dataset)       //size of register map
#define MAX_SENT_BYTES     0x0C                      //maximum amount of data that I could receive from a master device (register, plus 11 byte waypoint data)
#define UBLOX_INIT
#define LAT  0
#define LON  1
// Which command I got from the host ? in GPSMode variable
#define GPSMODE_NONAV 0        // no navigation
#define GPSMODE_HOLD  1        // pos hold
#define GPSMODE_WP    2        // wp navigation
// Navigation state machine states (nav_mode)
#define NAV_MODE_NONE              0
#define NAV_MODE_POSHOLD           1
#define NAV_MODE_WP                2
// Convert deg*100 to radians
#define RADX100                    0.000174532925
//Blink feedback, by guru_florida
#define BLINK_INTERVAL  90
// Set up gps lag
#if defined(UBLOX)
#define GPS_LAG 0.5f                        //UBLOX GPS has a smaller lag than MTK and other
#else
#define GPS_LAG 1.0f                                //We assumes that MTK GPS has a 1 sec lag
#endif
#if defined(INIT_MTK_GPS)
#define MTK_SET_BINARY          "$PGCMD,16,0,0,0,0,0*6A\r\n"
#define MTK_SET_NMEA            "$PGCMD,16,1,1,1,1,1*6B\r\n"
#define MTK_SET_NMEA_SENTENCES  "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n"
#define MTK_OUTPUT_4HZ          "$PMTK220,250*29\r\n"
#define MTK_OUTPUT_5HZ          "$PMTK220,200*2C\r\n"
#define MTK_OUTPUT_10HZ         "$PMTK220,100*2F\r\n"
#define MTK_NAVTHRES_OFF        "$PMTK397,0*23\r\n" // Set Nav Threshold (the minimum speed the GPS must be moving to update the position) to 0 m/s
#define SBAS_ON                 "$PMTK313,1*2E\r\n"
#define WAAS_ON                 "$PMTK301,2*2E\r\n"
#define SBAS_TEST_MODE                         "$PMTK319,0*25\r\n"        //Enable test use of sbas satelite in test mode (usually PRN124 is in test mode)
#endif
typedef struct {
  uint8_t    new_data: 1;
  uint8_t    gps2dfix: 1;
  uint8_t    gps3dfix: 1;
  uint8_t    wp_reached: 1;
  uint8_t    numsats: 4;
} STATUS_REGISTER;
typedef struct {
  uint8_t command: 4;
  uint8_t     wp: 4;
} COMMAND_REGISTER;
typedef struct {
  uint8_t     active_wp: 4;
  uint8_t     pervious_wp: 4;
} WAYPOINT_REGISTER;
typedef struct {
  long      lat;            //degree*10 000 000
  long      lon;            //degree*10 000 000
} GPS_COORDINATES;
typedef struct {
  GPS_COORDINATES position;    //GPS coordinate of the waypoint
  uint16_t        altitude;    //altitude of the waypoint in meters (altitude is relative to the startup altitude)
  uint8_t         flags;       //to be defined
} WAYPOINT;
typedef struct {
  //Status and command registers
  STATUS_REGISTER       status;                   // 0x00  status register
  COMMAND_REGISTER      command;                  // 0x01  command register
  WAYPOINT_REGISTER     wp_register;              // 0x02  waypoint register (current, previus)
  uint8_t               sw_version;               // 0x03  Version of the I2C_GPS sw
  uint8_t               res3;                     // 0x04  reserved for future use
  uint8_t               res4;                     // 0x05  reserved for future use
  uint8_t                     res5;                     // 0x06  reserved for future use
  //GPS & navigation data
  GPS_COORDINATES       gps_loc;                  // current location (8 byte) lat,lon
  int16_t                nav_lat;                  // The desired bank towards North (Positive) or South (Negative)      1 deg = 100 max 30deg (3000)
  int16_t                nav_lon;                  // The desired bank towards East (Positive) or West (Negative)        1 deg = 100 max 30deg (3000)
  uint32_t              wp_distance;              // distance to active coordinates  (calculated) in cm
  int16_t               wp_target_bearing;        // direction to active coordinates (calculated)   1deg = 10 / -1800 - 1800
  int16_t               nav_bearing;              // crosstrack corrected navigational bearing 1deg = 10
  int16_t               home_to_copter_bearing;   // 1deg = 10
  uint16_t              distance_to_home;         // distance to home in cm
  uint16_t              ground_speed;             // ground speed from gps m/s*100
  int16_t               altitude;                 // gps altitude
  uint16_t                ground_course;                  // GPS ground course
  uint16_t              res6;                     // reserved for future use
  uint32_t                time;                          // UTC Time from GPS
  //Parameters
  uint8_t                nav_crosstrack_gain;      // Crosstrack gain *100 (1 - 0.01 , 100 - 1)
  uint8_t                nav_speed_min;                  // minimum speed for navigation cm/s
  uint16_t                nav_speed_max;                  // maxiumum speed for navigation cm/s
  uint16_t                nav_bank_max;                  // maximum banking 1deg = 100, 30deg = 3000
  uint16_t                wp_radius;                  // waypoint radius, if we within this radius, then we considered that the wp is reached in cm
  uint8_t               nav_flags;                // navigational flags to be defined
  //PID values
  uint8_t              poshold_p;                  // *100
  uint8_t              poshold_i;                  // *100
  uint8_t              poshold_imax;              // *1
  uint8_t              poshold_rate_p;            // *10
  uint8_t              poshold_rate_i;                      // *100
  uint8_t              poshold_rate_d;                  // *1000
  uint8_t              poshold_rate_imax;          // *1
  uint8_t              nav_p;                          // *10
  uint8_t              nav_i;                          // *100
  uint8_t              nav_d;                          // *1000
  uint8_t              nav_imax;                  // *1
  WAYPOINT              gps_wp[16];               // 16 waypoints, WP#0 is RTH position
  uint16_t                sonar_distance;
} I2C_REGISTERS;
static I2C_REGISTERS   i2c_dataset;
static GPS_COORDINATES _target;                    //internal target location register
static uint8_t         receivedCommands[MAX_SENT_BYTES];
static uint8_t         new_command;                        //new command received (!=0)
// Variables and controllers
//PID controllers
PICtrl        pi_poshold_lat(POSHOLD_P, POSHOLD_I, POSHOLD_IMAX * 100);
PICtrl        pi_poshold_lon(POSHOLD_P, POSHOLD_I, POSHOLD_IMAX * 100);
PIDCtrl        pid_poshold_rate_lat(POSHOLD_RATE_P, POSHOLD_RATE_I, POSHOLD_RATE_D, POSHOLD_RATE_IMAX * 100);
PIDCtrl        pid_poshold_rate_lon(POSHOLD_RATE_P, POSHOLD_RATE_I, POSHOLD_RATE_D, POSHOLD_RATE_IMAX * 100);
PIDCtrl        pid_nav_lat(NAV_P, NAV_I, NAV_D, NAV_IMAX * 100);
PIDCtrl        pid_nav_lon(NAV_P, NAV_I, NAV_D, NAV_IMAX * 100);
LeadFilter xLeadFilter;      // Long GPS lag filter
LeadFilter yLeadFilter;      // Lat  GPS lag filter
// used to track the elapsed time between GPS reads
static uint32_t                 nav_loopTimer;
// Delta Time in milliseconds for navigation computations, updated with every good GPS read
static float                         dTnav;
//Actual navigation mode, this needed since we swith to poshold ence arrived at home
static int8_t  nav_mode = NAV_MODE_NONE;            //Navigation mode
static int16_t x_actual_speed = 0;
static int16_t y_actual_speed = 0;
static int32_t last_longitude = 0;
static int32_t last_latitude  = 0;
static int16_t x_rate_d;
static int16_t y_rate_d;
// this is used to offset the shrinking longitude as we go towards the poles
static float        GPS_scaleLonDown;
static float        GPS_scaleLonUp;
// The difference between the desired rate of travel and the actual rate of travel
// updated after GPS read - 5-10hz
static int16_t   x_rate_error;
static int16_t   y_rate_error;
static int32_t         long_error, lat_error;
static int16_t        nav_lat;
static int16_t        nav_lon;
//Used for rotation calculations for GPS nav vector
static float sin_yaw_y;
static float cos_yaw_x;
//Currently used WP
static int32_t  GPS_WP_latitude, GPS_WP_longitude;
static uint16_t GPS_WP_altitude;
static uint8_t  GPS_WP_flags;
//Actual position for calculations
static int32_t  GPS_latitude, GPS_longitude;
// Location & Navigation
// This is the angle from the copter to the "next_WP" location in degrees * 100
static int32_t        target_bearing;
// with the addition of Crosstrack error in degrees * 100
static int32_t        nav_bearing;
// saves the bearing at takeof (1deg = 1) used to rotate to takeoff direction when arrives at home
static int16_t  nav_takeoff_bearing;
// Crosstrack
// deg * 100, The original angle to the next_WP when the next_WP was set
// Also used to check when we pass a WP
static int32_t         original_target_bearing;
// The amount of angle correction applied to target_bearing to bring the copter back on its optimum path
static int16_t        crosstrack_error;
// The location of the copter in relation to home, updated every GPS read (1deg - 100)
static int32_t        home_to_copter_bearing;
// distance between plane and home in cm
static int32_t        home_distance;
// distance between plane and next_WP in cm
static int32_t        wp_distance;
// used for slow speed wind up when start navigation;
static int16_t waypoint_speed_gov;
// this is the navigation mode what is commanded
static uint8_t GPSMode = GPSMODE_NONAV;
// Blink code variables
static uint32_t lastframe_time = 0;
static uint32_t _statusled_timer = 0;
static int8_t _statusled_blinks = 0;
static boolean _statusled_state = 0;
// Sonar variables
static uint32_t _sonar_timer = 0;
// moving average filter variables
static uint8_t GPS_filter_index = 0;
static int32_t GPS_filter[2][GPS_FILTER_VECTOR_LENGTH];
static int32_t GPS_filter_sum[2];
static int32_t GPS_read[2];
static int32_t GPS_filtered[2];
static int32_t GPS_degree[2];    //the lat lon degree without any decimals (lat/10 000 000)
static int32_t GPS_lead_latitude, GPS_lead_longitude;
// It's ok to calculate this once per waypoint setting, since it changes a little within the reach of a multicopter
void GPS_calc_longitude_scaling(int32_t lat)
  float rads                         = (abs((float)lat) / 10000000.0) * 0.0174532925;
  GPS_scaleLonDown                 = cos(rads);
  GPS_scaleLonUp                         = 1.0f / cos(rads);
// Sets the waypoint to navigate, reset neccessary variables and calculate initial values
// Waypoint 16 is a virtual waypoint, it's a pos hold
void GPS_set_next_wp(uint8_t wp_number)
  if (wp_number > 16) {
    return;  //Do nothing with a wrong WP number
  if (wp_number <= 15 ) {
    GPS_WP_latitude  = i2c_dataset.gps_wp[wp_number].position.lat;
    GPS_WP_longitude = i2c_dataset.gps_wp[wp_number].position.lon;
    GPS_WP_altitude  = i2c_dataset.gps_wp[wp_number].altitude;
    GPS_WP_flags     = i2c_dataset.gps_wp[wp_number].flags;
    i2c_dataset.status.wp_reached = 0;
  } else {
    GPS_WP_latitude  = GPS_latitude;
    GPS_WP_longitude = GPS_longitude;
    GPS_WP_altitude  = 0;
    GPS_WP_flags     = 0;
    i2c_dataset.status.wp_reached = 1;        //With poshold we assume that the wp is reached
  GPS_calc_longitude_scaling(GPS_WP_latitude);
  wp_distance = GPS_distance_cm(GPS_latitude, GPS_longitude, GPS_WP_latitude, GPS_WP_longitude);
  target_bearing = GPS_bearing(GPS_latitude, GPS_longitude, GPS_WP_latitude, GPS_WP_longitude);
  nav_bearing = target_bearing;
  GPS_calc_location_error(GPS_WP_latitude, GPS_WP_longitude, GPS_latitude, GPS_longitude);
  original_target_bearing = target_bearing;
  waypoint_speed_gov = i2c_dataset.nav_speed_min;
// Check if we missed the destination somehow
static bool check_missed_wp()
  int32_t temp;
  temp = target_bearing - original_target_bearing;
  temp = wrap_18000(temp);
  return (labs(temp) > 9000);        // we passed the waypoint by 100 degrees
// Get distance between two points in cm
uint32_t GPS_distance_cm(int32_t lat1, int32_t lon1, int32_t lat2, int32_t lon2) {
  float dLat = (lat2 - lat1);                                    // difference of latitude in 1/10 000 000 degrees
  float dLon = (float)(lon2 - lon1) * GPS_scaleLonDown;
  float dist = sqrt(sq(dLat) + sq(dLon)) * 1.113195;
  return dist;
// get bearing from pos1 to pos2, returns an 1deg = 100 precision
int32_t GPS_bearing(int32_t lat1, int32_t lon1, int32_t lat2, int32_t lon2)
  float off_x = (float)lon2 - lon1;
  float off_y = ((float)(lat2 - lat1)) * GPS_scaleLonUp;
  float bearing =        9000.0f + atan2(-off_y, off_x) * 5729.57795f;      //Convert the output redians to 100xdeg
  if (bearing < 0) bearing += 36000;
  return bearing;
// Calculate our current speed vector from gps position data
static void GPS_calc_velocity( int32_t gps_latitude, int32_t gps_longitude) {
  static int16_t x_speed_old = 0;
  static int16_t y_speed_old = 0;
  // y_GPS_speed positve = Up
  // x_GPS_speed positve = Right
  // initialise last_longitude and last_latitude
  if ( last_longitude == 0 && last_latitude == 0 ) {
    last_longitude = gps_longitude;
    last_latitude = gps_latitude;
  float tmp = 1.0 / dTnav;
  x_actual_speed         = (float)(gps_longitude - last_longitude) *  GPS_scaleLonDown * tmp;
  y_actual_speed        = (float)(gps_latitude  - last_latitude)  * tmp;
#if !defined(GPS_LEAD_FILTER)
  x_actual_speed        = (x_actual_speed + x_speed_old) / 2;
  y_actual_speed        = (y_actual_speed + y_speed_old) / 2;
  x_speed_old         = x_actual_speed;
  y_speed_old         = y_actual_speed;
#endif
#if defined(GPS_LEAD_FILTER)
  GPS_lead_longitude = xLeadFilter.get_position(gps_longitude, x_actual_speed, GPS_LAG);
  GPS_lead_latitude  = yLeadFilter.get_position(gps_latitude, y_actual_speed, GPS_LAG);
#endif
// Calculate a location error between two gps coordinates
// Becuase we are using lat and lon to do our distance errors here's a quick chart:
//        100         = 1m
//        1000         = 11m         = 36 feet
//        1800         = 19.80m = 60 feet
//        3000         = 33m
//        10000         = 111m
static void GPS_calc_location_error( int32_t target_lat, int32_t target_lng, int32_t gps_lat, int32_t gps_lng )
  // X Error
  long_error        = (float)(target_lng - gps_lng) * GPS_scaleLonDown;
  // Y Error
  lat_error        = target_lat - gps_lat;
// Calculate nav_lat and nav_lon from the x and y error and the speed
static void GPS_calc_poshold(int x_error, int y_error)
  int32_t p, i, d;
  int32_t output;
  int32_t x_target_speed, y_target_speed;
  // East / West
  x_target_speed         = pi_poshold_lon.get_p(x_error);                        // calculate desired speed from lon error
  x_rate_error        = x_target_speed - x_actual_speed;                        // calc the speed error
  p                                = pid_poshold_rate_lon.get_p(x_rate_error);
  i                                = pid_poshold_rate_lon.get_i(x_rate_error + x_error, dTnav);
  d                                = pid_poshold_rate_lon.get_d(x_error, dTnav);
  d               = constrain(d, -2000, 2000);
  // get rid of noise
  if ( (i2c_dataset.nav_flags & I2C_NAV_FLAG_LOW_SPEED_D_FILTER) && (abs(x_actual_speed) < 50)) {
    d = 0;
  output                        = p + i + d;
  nav_lon                        = constrain(output, -NAV_BANK_MAX, NAV_BANK_MAX);
  // North / South
  y_target_speed         = pi_poshold_lat.get_p(y_error);                        // calculate desired speed from lat error
  y_rate_error        = y_target_speed - y_actual_speed;
  p                                = pid_poshold_rate_lat.get_p(y_rate_error);
  i                                = pid_poshold_rate_lat.get_i(y_rate_error + y_error, dTnav);
  d                                = pid_poshold_rate_lat.get_d(y_error, dTnav);
  // get rid of noise
  if ( (i2c_dataset.nav_flags & I2C_NAV_FLAG_LOW_SPEED_D_FILTER) && (abs(y_actual_speed) < 50)) {
    d = 0;
  output                        = p + i + d;
  nav_lat                        = constrain(output, -NAV_BANK_MAX, NAV_BANK_MAX);
  // copy over I term to Nav_Rate -- if we change from poshold to RTH this will keep the wind compensation
  pid_nav_lon.set_integrator(pid_poshold_rate_lon.get_integrator());
  pid_nav_lat.set_integrator(pid_poshold_rate_lat.get_integrator());
// Calculate the desired nav_lat and nav_lon for distance flying such as RTH
static void GPS_calc_nav_rate(int max_speed)
  // push us towards the original track
  GPS_update_crosstrack();
  // nav_bearing includes crosstrack
  float temp                 = (9000l - nav_bearing) * RADX100;
  // East / West
  x_rate_error                 = (cos(temp) * max_speed) - x_actual_speed;
  x_rate_error                 = constrain(x_rate_error, -1000, 1000);
  nav_lon                        = pid_nav_lon.get_pid(x_rate_error, dTnav);
  nav_lon                        = constrain(nav_lon, -NAV_BANK_MAX, NAV_BANK_MAX);
  // North / South
  y_rate_error                 = (sin(temp) * max_speed) - y_actual_speed;
  y_rate_error                  = constrain(y_rate_error, -1000, 1000);        // added a rate error limit to keep pitching down to a minimum
  nav_lat                        = pid_nav_lat.get_pid(y_rate_error, dTnav);
  nav_lat                        = constrain(nav_lat, -NAV_BANK_MAX, NAV_BANK_MAX);
  // copy over I term to poshold_rate - So when arriving and entering to poshold we will have the wind compensation
  pid_poshold_rate_lon.set_integrator(pid_nav_lon.get_integrator());
  pid_poshold_rate_lat.set_integrator(pid_nav_lat.get_integrator());
// Calculating cross track error, this tries to keep the copter on a direct line
// when flying to a waypoint.
static void GPS_update_crosstrack(void)
  if (abs(wrap_18000(target_bearing - original_target_bearing)) < 4500) {         // If we are too far off or too close we don't do track following
    float temp = (target_bearing - original_target_bearing) * RADX100;
    crosstrack_error = sin(temp) * (wp_distance * (float)((float)i2c_dataset.nav_crosstrack_gain / 100.0f));         // Meters we are off track line
    nav_bearing = target_bearing + constrain(crosstrack_error, -3000, 3000);
    nav_bearing = wrap_36000(nav_bearing);
  } else {
// Determine desired speed when navigating towards a waypoint, also implement slow
// speed rampup when starting a navigation
//        |< WP Radius
//        0  1   2   3   4   5   6   7   8m
//                  100  |  200          300          400cm/s
//                   |< we should slow to 1.5 m/s as we hit the target
static int16_t GPS_calc_desired_speed(int16_t max_speed, bool _slow)
  // max_speed is default 400 or 4m/s
  if (_slow) {
    max_speed                 = min(max_speed, wp_distance / 2);
    max_speed                 = max(max_speed, 0);
  } else {
    max_speed                 = min(max_speed, wp_distance);
    max_speed                 = max(max_speed, i2c_dataset.nav_speed_min);        // go at least 100cm/s
  // limit the ramp up of the speed
  // waypoint_speed_gov is reset to NAV_MIN_SPEED at each new WP command
  if (max_speed > waypoint_speed_gov) {
    waypoint_speed_gov += (int)(100.0 * dTnav); // increase at .5/ms
    max_speed = waypoint_speed_gov;
  return max_speed;
// Resets all GPS nev parameters and clears up the PID controllers. Prepares for a restarted poshold/navigation
void GPS_reset_nav()
  pi_poshold_lat.reset_I();
  pi_poshold_lon.reset_I();
  pid_poshold_rate_lon.reset_I();
  pid_poshold_rate_lat.reset_I();
  pid_nav_lon.reset_I();
  pid_nav_lat.reset_I();
  nav_lon = 0;
  nav_lat = 0;
// Update i2c_dataset from navigation output
void GPS_update_i2c_dataset()
  i2c_dataset.nav_lat           = nav_lat;
  i2c_dataset.nav_lon           = nav_lon;
  i2c_dataset.wp_distance       = wp_distance;
  i2c_dataset.wp_target_bearing = target_bearing;
  i2c_dataset.nav_bearing       = nav_bearing;
// Utilities
int32_t wrap_18000(int32_t error)
  if (error > 18000)        error -= 36000;
  if (error < -18000)        error += 36000;
  return error;
int32_t wrap_36000(int32_t angle)
  if (angle > 36000)        angle -= 36000;
  if (angle < 0)                angle += 36000;
  return angle;
#if defined(NMEA)
/* The latitude or longitude is coded this way in NMEA frames
  dddmm.mmmm   coded as degrees + minutes + minute decimal
  This function converts this format in a unique unsigned long where 1 degree = 10 000 000
  I increased the precision here, even if we think that the gps is not precise enough, with 10e5 precision it has 76cm resolution
  with 10e7 it's around 1 cm now. Increasing it further is irrelevant, since even 1cm resolution is unrealistic, however increased
  resolution also increased precision of nav calculations
#define DIGIT_TO_VAL(_x)        (_x - '0')
uint32_t GPS_coord_to_degrees(char* s)
  char *p, *q;
  uint8_t deg = 0, min = 0;
  unsigned int frac_min = 0;
  // scan for decimal point or end of field
  for (p = s; isdigit(*p); p++)
  q = s;
  // convert degrees
  while ((p - q) > 2) {
    if (deg)
      deg *= 10;
    deg += DIGIT_TO_VAL(*q++);
  // convert minutes
  while (p > q) {
    if (min)
      min *= 10;
    min += DIGIT_TO_VAL(*q++);
  // convert fractional minutes
  // expect up to four digits, result is in
  // ten-thousandths of a minute
  if (*p == '.') {
    q = p + 1;
    for (int i = 0; i < 4; i++) {
      frac_min *= 10;
      if (isdigit(*q))
        frac_min += *q++ - '0';
  return deg * 10000000UL + (min * 1000000UL + frac_min * 100UL) / 6;
/* This is am expandable implementation of a GPS frame decoding
   This should work with most of modern GPS devices configured to output NMEA frames.
   It assumes there are some NMEA GGA, GSA and RMC frames to decode on the serial bus
   Using the following data :
   GGA
     - time
     - latitude
     - longitude
     - GPS fix
     - GPS num sat (5 is enough to be +/- reliable)
     - GPS alt
   GSA
     - 3D fix (it could be left out since we have a 3D fix if we have more than 4 sats
   RMC
     - GPS speed over ground, it will be handy for wind compensation (future)
#define NO_FRAME    0
#define GPGGA_FRAME 1
#define GPGSA_FRAME 2
#define GPRMC_FRAME 3
bool GPS_NMEA_newFrame(char c) {
  uint8_t frameOK = 0;
  static uint8_t param = 0, offset = 0, parity = 0;
  static char string[15];
  static uint8_t checksum_param, gps_frame = NO_FRAME;
  switch (c) {
    case '$': param = 0; offset = 0; parity = 0;
    case ',':
    case '*':  string[offset] = 0;
      if (param == 0) { //frame identification
        if (string[0] == 'G' && string[1] == 'P' && string[2] == 'G' && string[3] == 'G' && string[4] == 'A') gps_frame = GPGGA_FRAME;
        if (string[0] == 'G' && string[1] == 'P' && string[2] == 'G' && string[3] == 'S' && string[4] == 'A') gps_frame = GPGSA_FRAME;
        if (string[0] == 'G' && string[1] == 'P' && string[2] == 'R' && string[3] == 'M' && string[4] == 'C') gps_frame = GPRMC_FRAME;
      switch (gps_frame)
        //************* GPGGA FRAME parsing
        case GPGGA_FRAME:
          switch (param)
            case 1: i2c_dataset.time = (atof(string) * 1000);    //up to .000 s precision not needed really but the data is there anyway
            //case 2: i2c_dataset.gps_loc.lat = GPS_coord_to_degrees(string);
            case 2: GPS_read[LAT] = GPS_coord_to_degrees(string);
            //case 3: if (string[0] == 'S') i2c_dataset.gps_loc.lat = -i2c_dataset.gps_loc.lat;
            case 3: if (string[0] == 'S') GPS_read[LAT] = -GPS_read[LAT];
            //case 4: i2c_dataset.gps_loc.lon = GPS_coord_to_degrees(string);
            case 4: GPS_read[LON] = GPS_coord_to_degrees(string);
            //case 5: if (string[0] == 'W') i2c_dataset.gps_loc.lon = -i2c_dataset.gps_loc.lon;
            case 5: if (string[0] == 'W') GPS_read[LON] = -GPS_read[LON];
            case 6: i2c_dataset.status.gps2dfix = string[0]  > '0';
            case 7: i2c_dataset.status.numsats = atoi(string);
            case 9: i2c_dataset.altitude = atoi(string);
        //************* GPGSA FRAME parsing
        case GPGSA_FRAME:
          switch (param)
            case 2: i2c_dataset.status.gps3dfix = string[0] == '3';
        case GPRMC_FRAME:
          switch (param)
            case 7: i2c_dataset.ground_speed = (atof(string) * 0.5144444) * 10;  //convert to m/s*100
            case 8: i2c_dataset.ground_course = (atof(string) * 10);                                //Convert to degrees *10 (.1 precision)
      param++; offset = 0;
      if (c == '*') checksum_param = 1;
      else parity ^= c;
    case '\r':
    case '\n':
      if (checksum_param) { //parity checksum
        uint8_t checksum = 16 * ((string[0] >= 'A') ? string[0] - 'A' + 10 : string[0] - '0') + ((string[1] >= 'A') ? string[1] - 'A' + 10 : string[1] - '0');
        if (checksum == parity) frameOK = 1;
      checksum_param = 0;
    default:
      if (offset < 15) string[offset++] = c;
      if (!checksum_param) parity ^= c;
  return frameOK && (gps_frame == GPGGA_FRAME);
#endif
#if defined(UBLOX)
struct ubx_header {
  uint8_t preamble1;
  uint8_t preamble2;
  uint8_t msg_class;
  uint8_t msg_id;
  uint16_t length;
struct ubx_nav_posllh {
  uint32_t        time;                                // GPS msToW
  int32_t                longitude;
  int32_t                latitude;
  int32_t                altitude_ellipsoid;
  int32_t                altitude_msl;
  uint32_t        horizontal_accuracy;
  uint32_t        vertical_accuracy;
struct ubx_nav_status {
  uint8_t                fix_type;
  uint8_t                fix_status;
  uint8_t                differential_status;
  uint8_t                res;
  uint32_t        time_to_first_fix;
  uint32_t        uptime;                                // milliseconds
struct ubx_nav_solution {
  uint32_t        time;
  int32_t                time_nsec;
  int16_t                week;
  uint8_t                fix_type;
  uint8_t                fix_status;
  int32_t                ecef_x;
  int32_t                ecef_y;
  int32_t                ecef_z;
  uint32_t        position_accuracy_3d;
  int32_t                ecef_x_velocity;
  int32_t                ecef_y_velocity;
  int32_t                ecef_z_velocity;
  uint32_t        speed_accuracy;
  uint16_t        position_DOP;
  uint8_t                res;
  uint8_t                satellites;
  uint32_t        res2;
struct ubx_nav_velned {
  int32_t                ned_north;
  int32_t                ned_east;
  int32_t                ned_down;
  uint32_t        speed_3d;
  uint32_t        speed_2d;
  int32_t                heading_2d;
  uint32_t        heading_accuracy;
enum ubs_protocol_bytes {
  PREAMBLE1 = 0xb5,
  PREAMBLE2 = 0x62,
  CLASS_NAV = 0x01,
  CLASS_ACK = 0x05,
  CLASS_CFG = 0x06,
  MSG_ACK_NACK = 0x00,
  MSG_ACK_ACK = 0x01,
  MSG_POSLLH = 0x2,
  MSG_STATUS = 0x3,
  MSG_SOL = 0x6,
  MSG_VELNED = 0x12,
  MSG_CFG_PRT = 0x00,
  MSG_CFG_RATE = 0x08,
  MSG_CFG_SET_RATE = 0x01,
  MSG_CFG_NAV_SETTINGS = 0x24
enum ubs_nav_fix_type {
  FIX_NONE = 0,
  FIX_DEAD_RECKONING = 1,
  FIX_2D = 2,
  FIX_3D = 3,
  FIX_GPS_DEAD_RECKONING = 4,
  FIX_TIME = 5
enum ubx_nav_status_bits {
  NAV_STATUS_FIX_VALID = 1
// Packet checksum accumulators
static uint8_t                _ck_a;
static uint8_t                _ck_b;
// State machine state
static uint8_t                _step;
static uint8_t                _msg_id;
static uint16_t        _payload_length;
static uint16_t        _payload_counter;
static bool        next_fix;
static uint8_t     _class;
// do we have new position information?
static bool                _new_position;
// do we have new speed information?
static bool                _new_speed;
static uint8_t            _disable_counter;
// Receive buffer
static union {
  ubx_nav_posllh                posllh;
  ubx_nav_status                status;
  ubx_nav_solution        solution;
  ubx_nav_velned                velned;
  uint8_t        bytes[];
} _buffer;
void _update_checksum(uint8_t *data, uint8_t len, uint8_t &ck_a, uint8_t &ck_b)
  while (len--) {
    ck_a += *data;
    ck_b += ck_a;
    data++;
bool GPS_UBLOX_newFrame(uint8_t data)
  bool parsed = false;
  switch (_step) {
    case 1:
      if (PREAMBLE2 == data) {
        _step++;
      _step = 0;
    case 0:
      if (PREAMBLE1 == data) _step++;
    case 2:
      _step++;
      _class = data;
      _ck_b = _ck_a = data;                        // reset the checksum accumulators
    case 3:
      _step++;
      _ck_b += (_ck_a += data);                        // checksum byte
      _msg_id = data;
    case 4:
      _step++;
      _payload_length = data;                                // payload length low byte
    case 5:
      _step++;
      _payload_length += (uint16_t)(data << 8);
      if (_payload_length > 512) {
        _payload_length = 0;
        _step = 0;
      _payload_counter = 0;                                // prepare to receive payload
    case 6:
      if (_payload_counter < sizeof(_buffer)) {
        _buffer.bytes[_payload_counter] = data;
      if (++_payload_counter == _payload_length)
        _step++;
    case 7:
      _step++;
      if (_ck_a != data) _step = 0;                                                // bad checksum
    case 8:
      _step = 0;
      if (_ck_b != data)  break;                                                         // bad checksum
      if (UBLOX_parse_gps())  {
        parsed = true;
  } //end switch
  return parsed;
bool UBLOX_parse_gps(void)
  switch (_msg_id) {
    case MSG_POSLLH:
      i2c_dataset.time                = _buffer.posllh.time;
      GPS_read[LON]                        = _buffer.posllh.longitude;
      GPS_read[LAT]                        = _buffer.posllh.latitude;
      i2c_dataset.altitude                  = _buffer.posllh.altitude_msl / 10 / 100;     //alt in m
      i2c_dataset.status.gps3dfix        = next_fix;
      _new_position = true;
    case MSG_STATUS:
      next_fix        = (_buffer.status.fix_status & NAV_STATUS_FIX_VALID) && (_buffer.status.fix_type == FIX_3D);
      if (!next_fix) i2c_dataset.status.gps3dfix = false;
    case MSG_SOL:
      next_fix        = (_buffer.solution.fix_status & NAV_STATUS_FIX_VALID) && (_buffer.solution.fix_type == FIX_3D);
      i2c_dataset.status.numsats        = _buffer.solution.satellites;
      //GPS_hdop                = _buffer.solution.position_DOP;
      //debug[3] = GPS_hdop;
    case MSG_VELNED:
      //speed_3d        = _buffer.velned.speed_3d;                                // cm/s
      i2c_dataset.ground_speed = _buffer.velned.speed_2d;                                // cm/s
      i2c_dataset.ground_course = (uint16_t)(_buffer.velned.heading_2d / 10000);        // Heading 2D deg * 100000 rescaled to deg * 10
      _new_speed = true;
    default:
      return false;
  // we only return true when we get new position and speed data
  // this ensures we don't use stale data
  if (_new_position && _new_speed) {
    _new_speed = _new_position = false;
    return true;
  return false;
#endif //UBLOX
#if defined(MTK_BINARY16) || defined(MTK_BINARY19)
struct diyd_mtk_msg {
  int32_t                latitude;
  int32_t                longitude;
  int32_t                altitude;
  int32_t                ground_speed;
  int32_t                ground_course;
  uint8_t                satellites;
  uint8_t                fix_type;
  uint32_t        utc_date;
  uint32_t        utc_time;
  uint16_t        hdop;
// #pragma pack(pop)
enum diyd_mtk_fix_type {
  FIX_NONE = 1,
  FIX_2D = 2,
  FIX_3D = 3,
  FIX_2D_SBAS = 6,
  FIX_3D_SBAS = 7
enum diyd_mtk_protocol_bytes {
  PREAMBLE1 = 0xd0,
  PREAMBLE2 = 0xdd,
#endif
#if defined(MTK_BINARY19)
  PREAMBLE1 = 0xd1,
  PREAMBLE2 = 0xdd,
#endif
uint8_t         _ck_a;
uint8_t         _ck_b;
uint8_t         _step;
uint8_t                _payload_counter;
// Time from UNIX Epoch offset
long                _time_offset;
bool                _offset_calculated;
// Receive buffer
union {
  diyd_mtk_msg        msg;
  uint8_t                        bytes[];
} _buffer;
inline long _swapl(const void *bytes)
  const uint8_t        *b = (const uint8_t *)bytes;
  union {
    long        v;
    uint8_t b[4];
  } u;
  u.b[0] = b[3];
  u.b[1] = b[2];
  u.b[2] = b[1];
  u.b[3] = b[0];
  return (u.v);
bool GPS_MTK_newFrame(uint8_t data)
restart:
  switch (_step) {
    // Message preamble, class, ID detection
    // If we fail to match any of the expected bytes, we
    // reset the state machine and re-consider the failed
    // byte as the first byte of the preamble.  This
    // improves our chances of recovering from a mismatch
    // and makes it less likely that we will be fooled by
    // the preamble appearing as data in some other message.
    case 0:
        _step++;
    case 1:
        _step++;
      _step = 0;
      goto restart;
    case 2:
      if (sizeof(_buffer) == data) {
        _step++;
      } else {
        _step = 0;                                                        // reset and wait for a message of the right class
        goto restart;
    // Receive message data
    case 3:
      _buffer.bytes[_payload_counter++] = data;
      if (_payload_counter == sizeof(_buffer))
        _step++;
    // Checksum and message processing
    case 4:
      _step++;
      if (_ck_a != data) {
        _step = 0;
    case 5:
      _step = 0;
      if (_ck_b != data) {
      i2c_dataset.status.gps3dfix                         = ((_buffer.msg.fix_type == FIX_3D) || (_buffer.msg.fix_type == FIX_3D_SBAS));
      GPS_read[LAT]                = _buffer.msg.latitude * 10;        // XXX doc says *10e7 but device says otherwise
      GPS_read[LON]                = _buffer.msg.longitude * 10;        // XXX doc says *10e7 but device says otherwise
#endif
      GPS_read[LAT]                = _buffer.msg.latitude;        // XXX doc says *10e7 but device says otherwise
      GPS_read[LON]                = _buffer.msg.longitude;        // XXX doc says *10e7 but device says otherwise
#endif
      i2c_dataset.altitude                = _buffer.msg.altitude / 100;
      i2c_dataset.ground_speed                        = _buffer.msg.ground_speed;
      i2c_dataset.ground_course                = _buffer.msg.ground_course;
      i2c_dataset.status.numsats                        = _buffer.msg.satellites;
      //GPS_hdop                        = _buffer.msg.hdop;
      parsed = true;
      //GPS_Present = 1;
  return parsed;
#endif //MTK
// I2C handlers
// Handler for requesting data
void requestEvent()
  if (receivedCommands[0] >= I2C_GPS_GROUND_SPEED) i2c_dataset.status.new_data = 0;        //Accessing gps data, switch new_data_flag;
  //Write data from the requested data register position
  Wire.write((uint8_t *)&i2c_dataset + receivedCommands[0], 32);                 //Write up to 32 byte, since master is responsible for reading and sending NACK
  //32 byte limit is in the Wire library, we have to live with it unless writing our own wire library
//Handler for receiving data
void receiveEvent(int bytesReceived)
  uint8_t  *ptr;
  for (int a = 0; a < bytesReceived; a++) {
    if (a < MAX_SENT_BYTES) {
      receivedCommands[a] = Wire.read();
    } else {
      Wire.read();  // if we receive more data then allowed just throw it away
  if (receivedCommands[0] == I2C_GPS_COMMAND) {
    new_command = receivedCommands[1];  //Just one byte, ignore all others
    return;
  if (bytesReceived == 1 && (receivedCommands[0] < REG_MAP_SIZE)) {
    return;  //read command from a given register
  if (bytesReceived == 1 && (receivedCommands[0] >= REG_MAP_SIZE)) {                //Addressing over the reg_map fallback to first byte
    receivedCommands[0] = 0x00;
    return;
  //More than 1 byte was received, so there is definitely some data to write into a register
  //Check for writeable registers and discard data is it's not writeable
  if ((receivedCommands[0] >= I2C_GPS_CROSSTRACK_GAIN) && (receivedCommands[0] <= REG_MAP_SIZE)) { //Writeable registers above I2C_GPS_WP0
    ptr = (uint8_t *)&i2c_dataset + receivedCommands[0];
    for (int a = 1; a < bytesReceived; a++) {
      *ptr++ = receivedCommands[a];
void blink_sonar_update()
  uint32_t now = millis();
#if defined(SONAR) && !defined(MAXBOTIX_PWM)
  if (_sonar_timer < now) //update sonar readings every 50ms
    _sonar_timer = now + 50;
    Sonar_update();
#endif
  if (_statusled_timer < now) {
    if (lastframe_time + 5000 < now) {
      // no gps communication
      _statusled_state = !_statusled_state;
      digitalWrite(13, _statusled_state ? HIGH : LOW);   // set the LED off
      _statusled_timer = now + 1000;
      return;
    if (_statusled_blinks == 0) {
      if (i2c_dataset.status.gps3dfix == 1)
        _statusled_blinks = 3;
      else if (i2c_dataset.status.gps2dfix == 1)
        _statusled_blinks = 2;
        _statusled_blinks = 1;
    if (_statusled_state) {
      _statusled_blinks--;
      _statusled_state = false;
      _statusled_timer = now + ((_statusled_blinks > 0) ? BLINK_INTERVAL : 1000);
      digitalWrite(13, LOW);   // set the LED off
    } else {
      _statusled_state = true;
      _statusled_timer = now + BLINK_INTERVAL;
      digitalWrite(13, HIGH);   // set the LED on
// GPS initialisation
uint32_t init_speed[5] = {9600, 19200, 38400, 57600, 115200};
#if defined(UBLOX)
const byte prog_char_UBLOX_INIT[] PROGMEM = {                          // PROGMEM array must be outside any function !!!
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0xF0, 0x05, 0x00, 0xFF, 0x19,                  //disable all default NMEA messages
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0xF0, 0x03, 0x00, 0xFD, 0x15,
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0xF0, 0x01, 0x00, 0xFB, 0x11,
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0xF0, 0x00, 0x00, 0xFA, 0x0F,
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0xF0, 0x02, 0x00, 0xFC, 0x13,
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0xF0, 0x04, 0x00, 0xFE, 0x17,
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0x01, 0x02, 0x01, 0x0E, 0x47,                  //set POSLLH MSG rate
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0x01, 0x03, 0x01, 0x0F, 0x49,                  //set STATUS MSG rate
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0x01, 0x06, 0x01, 0x12, 0x4F,                  //set SOL MSG rate
  0xB5, 0x62, 0x06, 0x01, 0x03, 0x00, 0x01, 0x12, 0x01, 0x1E, 0x67,                  //set VELNED MSG rate
  0xB5, 0x62, 0x06, 0x16, 0x08, 0x00, 0x03, 0x07, 0x03, 0x00, 0x51, 0x08, 0x00, 0x00, 0x8A, 0x41, //set WAAS to EGNOS
  0xB5, 0x62, 0x06, 0x08, 0x06, 0x00, 0xC8, 0x00, 0x01, 0x00, 0x01, 0x00, 0xDE, 0x6A //set rate to 5Hz
#endif
void GPS_SerialInit() {
  Serial.begin(GPS_SERIAL_SPEED);
  delay(1000);
#if defined(UBLOX)
  //Set speed
  for (uint8_t i = 0; i < 5; i++) {
    Serial.begin(init_speed);          // switch UART speed for sending SET BAUDRATE command (NMEA mode)
#if (GPS_SERIAL_SPEED==19200)
    Serial.write(PSTR("$PUBX,41,1,0003,0001,19200,0*23\r\n"));     // 19200 baud - minimal speed for 5Hz update rate
#endif
#if (GPS_SERIAL_SPEED==38400)
    Serial.write(PSTR("$PUBX,41,1,0003,0001,38400,0*26\r\n"));     // 38400 baud
#endif
#if (GPS_SERIAL_SPEED==57600)
    Serial.write(PSTR("$PUBX,41,1,0003,0001,57600,0*2D\r\n"));     // 57600 baud
#endif
#if (GPS_SERIAL_SPEED==115200)
    Serial.write(PSTR("$PUBX,41,1,0003,0001,115200,0*1E\r\n"));    // 115200 baud
#endif
    delay(300);                //Wait for init
  delay(200);
  for ( uint8_t i = 0; i < sizeof(UBLOX_INIT); i++;) {                    // send configuration data in UBX protocol
    Serial.write(pgm_read_byte(UBLOX_INIT + i));
    //delay(5); //simulating a 38400baud pace (or less), otherwise commands are not accepted by the device.
#elif defined(INIT_MTK_GPS)                            // MTK GPS setup
    Serial.write("$PMTK251,19200*22\r\n");     // 19200 baud - minimal speed for 5Hz update rate
#endif
    Serial.write("$PMTK251,38400*27\r\n");     // 38400 baud
#endif
    Serial.write("$PMTK251,57600*2C\r\n");     // 57600 baud
#endif
    Serial.write("$PMTK251,115200*1F\r\n");    // 115200 baud
#endif
    delay(300);
  // at this point we have GPS working at selected (via #define GPS_BAUD) baudrate
  Serial.write(MTK_NAVTHRES_OFF);
  delay(100);
  Serial.write(SBAS_ON);
  delay(100);
  Serial.write(WAAS_ON);
  delay(100);
  Serial.write(SBAS_TEST_MODE);
  delay(100);
  Serial.write(MTK_OUTPUT_5HZ);           // 5 Hz update rate
  delay(100);
#if defined(NMEA)
  Serial.write(MTK_SET_NMEA_SENTENCES); // only GGA and RMC sentence
#endif
#if defined(MTK_BINARY19) || defined(MTK_BINARY16)
  Serial.write(MTK_SET_BINARY);
#endif
#endif
#if defined(SONAR)
volatile uint32_t Sonar_starTime = 0;
volatile uint32_t Sonar_echoTime = 0;
volatile uint16_t Sonar_waiting_echo = 0;
void Sonar_init()
  // Pin change interrupt control register - enables interrupt vectors
  PCICR  |= (1 << PCIE1); // Port C
  // Pin change mask registers decide which pins are enabled as triggers
  PCMSK1 |= (1 << PCINT10); // pin 2 PC2
  DDRC |= 0x08; //triggerpin PC3 as output
#if !defined(MAXBOTIX_PWM)
  Sonar_update();
#endif
ISR(PCINT1_vect) {
  //uint8_t pin = PINC;
  if (PINC & 1 << PCINT10) {   //indicates if the bit 0 of the arduino port [B0-B7] is at a high state
    Sonar_starTime = micros();
    //i2c_dataset.sonar_distance = -1;
  else {
    Sonar_echoTime = micros() - Sonar_starTime; // Echo time in microseconds
    if (Sonar_echoTime <= 700 * 58) {   // valid distance
      i2c_dataset.sonar_distance = Sonar_echoTime / 58;
      // No valid data
  //Sonar_waiting_echo = 0;
void Sonar_update()
  if (Sonar_waiting_echo == 0)
    // Send 2ms LOW pulse to ensure we get a nice clean pulse
    PORTC &= ~(0x08);//PC3 low
    delayMicroseconds(2);
    // send 10 microsecond pulse
    PORTC |= (0x08);//PC3 high
    // wait 10 microseconds before turning off
    delayMicroseconds(10);
    // stop sending the pulse
    Sonar_waiting_echo = 1;
#endif
#endif
// Setup
  uint8_t i;
  //Init Sonar
#if defined(SONAR)
  Sonar_init();
#endif
  //Init GPS
  GPS_SerialInit();
  //Init i2c_dataset;
  uint8_t *ptr = (uint8_t *)&i2c_dataset;
  for (i = 0; i < sizeof(i2c_dataset); i++) {
    *ptr = 0;
    ptr++;
  //Set up default parameters
  i2c_dataset.sw_version          = VERSION;
  i2c_dataset.nav_crosstrack_gain = 100; // Crosstrack gain = 1
  i2c_dataset.nav_speed_min       = 100; // cm/s
  i2c_dataset.nav_speed_max       = 400; // cm/s
  i2c_dataset.nav_bank_max        = 3000; // 30deg
  i2c_dataset.wp_radius           = 200;   //cm -> 2m
  i2c_dataset.poshold_p           = POSHOLD_P * 100;
  i2c_dataset.poshold_i           = POSHOLD_I * 100;
  i2c_dataset.poshold_imax        = POSHOLD_IMAX;
  i2c_dataset.poshold_rate_p      = POSHOLD_RATE_P * 10;
  i2c_dataset.poshold_rate_i      = POSHOLD_RATE_I * 100;
  i2c_dataset.poshold_rate_d      = POSHOLD_RATE_D * 1000;
  i2c_dataset.poshold_rate_imax   = POSHOLD_RATE_IMAX;
  i2c_dataset.nav_p               = NAV_P * 10;
  i2c_dataset.nav_i               = NAV_I * 100;
  i2c_dataset.nav_d               = NAV_D * 1000;
  i2c_dataset.nav_imax            = NAV_IMAX;
  i2c_dataset.nav_flags           = 0x80 + 0x40;      // GPS filter and low speed filters are on
  //Start I2C communication routines
  Wire.begin(I2C_ADDRESS);               // DO NOT FORGET TO COMPILE WITH 400KHz!!! else change TWBR Speed to 100khz on Host !!! Address 0x40 write 0x41 read
  Wire.onRequest(requestEvent);          // Set up event handlers
  Wire.onReceive(receiveEvent);
/******************************************************* Main loop ************************************************/
  static uint8_t GPS_fix_home;
  static uint8_t _command_wp;
  static uint8_t _command;
  static uint32_t _watchdog_timer = 0;
  uint8_t axis;
  uint16_t fraction3[2];
  #pragma region while serial available
  while (Serial.available()) {
#if defined(NMEA)
    if (GPS_NMEA_newFrame(Serial.read())) {
#endif
#if defined(UBLOX)
      if (GPS_UBLOX_newFrame(Serial.read())) {
#endif
        if (GPS_MTK_newFrame(Serial.read())) {
#endif
          // We have a valid GGA frame and we have lat and lon in GPS_read_lat and GPS_read_lon, apply moving average filter
          // this is a little bit tricky since the 1e7/deg precision easily overflow a long, so we apply the filter to the fractions
          // only, and strip the full degrees part. This means that we have to disable the filter if we are very close to a degree line
          #pragma region GPS FILTER
          if (i2c_dataset.nav_flags & I2C_NAV_FLAG_GPS_FILTER) {      //is filtering switched on ?
            GPS_filter_index = ++GPS_filter_index % GPS_FILTER_VECTOR_LENGTH;
            for (axis = 0; axis < 2; axis++) {
              GPS_degree[axis] = GPS_read[axis] / 10000000;  // get the degree to assure the sum fits to the int32_t
              // How close we are to a degree line ? its the first three digits from the fractions of degree
              //Check if we are close to a degree line, if yes, disable averaging,
              fraction3[axis] = (GPS_read[axis] - GPS_degree[axis] * 10000000) / 10000;
              GPS_filter_sum[axis] -= GPS_filter[axis][GPS_filter_index];
              GPS_filter[axis][GPS_filter_index] = GPS_read[axis] - (GPS_degree[axis] * 10000000);
              GPS_filter_sum[axis] += GPS_filter[axis][GPS_filter_index];
              GPS_filtered[axis] = GPS_filter_sum[axis] / GPS_FILTER_VECTOR_LENGTH + (GPS_degree[axis] * 10000000);
            if ( nav_mode == NAV_MODE_POSHOLD) {      //we use gps averaging only in poshold mode...
              if ( fraction3[LAT] > 1 && fraction3[LAT] < 999 ) i2c_dataset.gps_loc.lat = GPS_filtered[LAT]; else i2c_dataset.gps_loc.lat = GPS_read[LAT];
              if ( fraction3[LON] > 1 && fraction3[LON] < 999 ) i2c_dataset.gps_loc.lon = GPS_filtered[LON]; else i2c_dataset.gps_loc.lon = GPS_read[LON];
            } else {
          } else { // ignore filtering since it switced off in the nav_flags
          #pragma endregion
          if (i2c_dataset.status.gps3dfix == 1 && i2c_dataset.status.numsats >= 5) {
            lastframe_time = millis();
            //copy the gps coordinates to variables used for calculations
            GPS_latitude = i2c_dataset.gps_loc.lat;
            GPS_longitude = i2c_dataset.gps_loc.lon;
            // It's just for safety since home position must be set from the host
            if (GPS_fix_home == 0) {
              GPS_fix_home = 1;
              i2c_dataset.gps_wp[0].position.lat = GPS_latitude;
              i2c_dataset.gps_wp[0].position.lon = GPS_longitude;
              GPS_calc_longitude_scaling(GPS_latitude);  //need an initial value for distance and bearing calc
            //dTnav calculation
            //Time for calculating x,y speed and navigation pids
            dTnav = (float)(millis() - nav_loopTimer) / 1000.0;
            nav_loopTimer = millis();
            // prevent runup from bad GPS
            dTnav = min(dTnav, 1.0);
            _watchdog_timer = millis();  //Reset watchdog timer
            //calculate distance and bearings for gui and other stuff continously this is independent from navigation
            i2c_dataset.distance_to_home = GPS_distance_cm(GPS_latitude, GPS_longitude, i2c_dataset.gps_wp[0].position.lat, i2c_dataset.gps_wp[0].position.lon);
            i2c_dataset.home_to_copter_bearing = GPS_bearing(i2c_dataset.gps_wp[0].position.lat, i2c_dataset.gps_wp[0].position.lon, GPS_latitude, GPS_longitude);
            //calculate the current velocity based on gps coordinates continously to get a valid speed at the moment when we start navigating
            GPS_calc_velocity(GPS_latitude, GPS_longitude);
            if (GPSMode != 0) {   //ok we are navigating
              //do gps nav calculations here
              wp_distance = GPS_distance_cm(GPS_lead_latitude, GPS_lead_longitude, GPS_WP_latitude, GPS_WP_longitude);
              target_bearing = GPS_bearing(GPS_lead_latitude, GPS_lead_longitude, GPS_WP_latitude, GPS_WP_longitude);
              GPS_calc_location_error(GPS_WP_latitude, GPS_WP_longitude, GPS_lead_latitude, GPS_lead_longitude);
#else
#endif
              switch (nav_mode) {
                case NAV_MODE_POSHOLD:
                  //Desired output is in nav_lat and nav_lon where 1deg inclination is 100
                  GPS_calc_poshold(long_error, lat_error);
                case NAV_MODE_WP:
                  int16_t speed = GPS_calc_desired_speed(i2c_dataset.nav_speed_max, true);      //slow navigation
                  // use error as the desired rate towards the target
                  GPS_calc_nav_rate(speed);
                  // Are we there yet ?(within 2 meters of the destination)
                  if ((wp_distance <= i2c_dataset.wp_radius) || check_missed_wp()) {        //if yes switch to poshold mode
                    nav_mode = NAV_MODE_POSHOLD;
                    //set reached flag
              } //switch nav mode
            } // if GPSmode!=0
            // update i2c dataset from nav
            GPS_update_i2c_dataset();
          } else {      // we does not have 3d fix or numsats less than 5 , stop navigation
            nav_lat = 0;
            nav_lon = 0;
            wp_distance = 0;
            i2c_dataset.distance_to_home = 0;
            i2c_dataset.home_to_copter_bearing = 0;
          // have new data at this point anyway
          i2c_dataset.status.new_data = 1;
        } // new frame
      } //while
      #pragma endregion
      blink_sonar_update();
      //check watchdog timer, after 1200ms without valid packet, assume that gps communication is lost.
      if (_watchdog_timer != 0)
        if (_watchdog_timer + 1200 < millis())
          i2c_dataset.status.gps2dfix = 0;
          i2c_dataset.status.gps3dfix = 0;
          i2c_dataset.status.numsats = 0;
          i2c_dataset.gps_loc.lat = 0;
          i2c_dataset.gps_loc.lon = 0;
          nav_lat = 0;
          nav_lon = 0;
      //Check for new incoming command on I2C
      if (new_command != 0) {
        _command = new_command;                                                   //save command byte for processing
        new_command = 0;                                                          //clear it
        _command_wp = (_command & 0xF0) >> 4;                                     //mask 4 MSB bits and shift down
        _command = _command & 0x0F;                                               //empty 4MSB bits
        switch (_command) {
          case I2C_GPS_COMMAND_POSHOLD:
            GPS_set_next_wp(16);                                                //wp16 is a virtual one, means current location
            GPSMode = GPSMODE_HOLD;
            i2c_dataset.status.new_data = 0;                                    //invalidate current dataset
          case I2C_GPS_COMMAND_START_NAV:
            GPS_set_next_wp(_command_wp);
            GPSMode = GPSMODE_WP;
            nav_mode = NAV_MODE_WP;
          case I2C_GPS_COMMAND_SET_WP:
            i2c_dataset.gps_wp[_command_wp].position.lat = GPS_latitude;
            i2c_dataset.gps_wp[_command_wp].position.lon = GPS_longitude;
          case I2C_GPS_COMMAND_UPDATE_PIDS:
            pi_poshold_lat.kP((float)i2c_dataset.poshold_p / 100.0f);
            pi_poshold_lon.kP((float)i2c_dataset.poshold_p / 100.0f);
            pi_poshold_lat.kI((float)i2c_dataset.poshold_i / 100.0f);
            pi_poshold_lon.kI((float)i2c_dataset.poshold_i / 100.0f);
            pi_poshold_lat.imax(i2c_dataset.poshold_imax * 100);
            pi_poshold_lon.imax(i2c_dataset.poshold_imax * 100);
            pid_poshold_rate_lat.kP((float)i2c_dataset.poshold_rate_p / 10.0f);
            pid_poshold_rate_lon.kP((float)i2c_dataset.poshold_rate_p / 10.0f);
            pid_poshold_rate_lat.kI((float)i2c_dataset.poshold_rate_i / 100.0f);
            pid_poshold_rate_lon.kI((float)i2c_dataset.poshold_rate_i / 100.0f);
            pid_poshold_rate_lat.kD((float)i2c_dataset.poshold_rate_d / 1000.0f);
            pid_poshold_rate_lon.kD((float)i2c_dataset.poshold_rate_d / 1000.0f);
            pid_poshold_rate_lat.imax(i2c_dataset.poshold_rate_imax * 100);
            pid_poshold_rate_lon.imax(i2c_dataset.poshold_rate_imax * 100);
            pid_nav_lat.kP((float)i2c_dataset.nav_p / 10.0f);
            pid_nav_lon.kP((float)i2c_dataset.nav_p / 10.0f);
            pid_nav_lat.kI((float)i2c_dataset.nav_i / 100.0f);
            pid_nav_lon.kI((float)i2c_dataset.nav_i / 100.0f);
            pid_nav_lat.kD((float)i2c_dataset.nav_d / 1000.0f);
            pid_nav_lon.kD((float)i2c_dataset.nav_d / 1000.0f);
            pid_nav_lat.imax(i2c_dataset.nav_imax * 100);
            pid_nav_lon.imax(i2c_dataset.nav_imax * 100);
          case I2C_GPS_COMMAND_STOP_NAV:
            GPS_reset_nav();
        } //switch
完整的库文件
 楼主| 发表于 2015-8-2 16:59:39 | 显示全部楼层
今天一直在测试Mwc的固件,发现有好多地方的代码都有问题,谁能和我一起探讨一下吗。
 楼主| 发表于 2015-8-2 17:03:08 | 显示全部楼层
这是其中一个错误,我想了很久都找不出这个错误怎么解决
发表于 2015-8-2 20:08:13 | 显示全部楼层
#define UBLOX_INIT
想想 sizeof(UBLOX_INIT) 會變成什麼.
发表于 2015-8-2 21:09:32 | 显示全部楼层
多了个分号
 楼主| 发表于 2015-8-3 10:53:05 | 显示全部楼层
不加就提示UBIOX_INIT未声明呀
 楼主| 发表于 2015-8-3 10:54:17 | 显示全部楼层
我编译的时候最后面不加分号也不行
发表于 2015-8-4 17:10:11 | 显示全部楼层
1.06版的编译器能认识PROGMEM,到了1.6就不认识了。
把1240行  prog_char UBLOX_INIT[] PROGMEM = {
改成 char UBLOX_INIT[]  = {
或者使用低版本的1.06版的
发表于 2015-8-5 14:58:40 | 显示全部楼层
jack_chen 发表于 2015-8-3 10:53
不加就提示UBIOX_INIT未声明呀
不是要你刪走, 刪走了當然是 未聲明喇.
只是說給你知, 你的那個錯誤是怎樣引起的.  當然, 之後的分號亦會產生另一個錯誤.
要解決問題, 先要知道問題的成因吧.
先檢查一下程式中 UBLOX_INIT 及 UBLOX 的作用.
#define 時用了 UBLOX_INIT, 但檢測時變成 #if defined(UBLOX), 之後建立變數時又多了個 "_", 測試時又用 sizeof(UBLOX_INIT).  不是很混亂了嗎?   先想想那裡應該用 UBLOX_INIT, 那裡應該用 UBLOX 吧.
GMT+8, 2026-6-18 10:24 , Processed in 0.038549 second(s), 20 queries .
