查看: 15925|回复: 1
在AccelStepper库中如何实现两个步进电机同步工作
发表于 2015-8-4 12:52:31 | 显示全部楼层 |阅读模式
[pre lang="arduino" line="1" file="Accel_MultiStepper"]// Shows how to run three Steppers at once with varying speeds
// Requires the Adafruit_Motorshield v2 library
//   https://github.com/adafruit/Adafruit_Motor_Shield_V2_Library
// And AccelStepper with AFMotor support
//   https://github.com/adafruit/AccelStepper
// This tutorial is for Adafruit Motorshield v2 only!
// Will not work with v1 shields
#include <AccelStepper.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
Adafruit_MotorShield AFMSbot(0x61); // Rightmost jumper closed
Adafruit_MotorShield AFMStop(0x60); // Default address, no jumpers
// Connect two steppers with 200 steps per revolution (1.8 degree)
// to the top shield
Adafruit_StepperMotor *myStepper1 = AFMStop.getStepper(400, 1);
Adafruit_StepperMotor *myStepper2 = AFMStop.getStepper(400, 2);
// Connect one stepper with 200 steps per revolution (1.8 degree)
// to the bottom shield
Adafruit_StepperMotor *myStepper3 = AFMSbot.getStepper(400, 2);
// you can change these to DOUBLE or INTERLEAVE or MICROSTEP!
// wrappers for the first motor!
void forwardstep1() {
  myStepper1->onestep(FORWARD, DOUBLE);
void backwardstep1() {
  myStepper1->onestep(BACKWARD, DOUBLE);
// wrappers for the second motor!
void forwardstep2() {
  myStepper2->onestep(FORWARD, DOUBLE);
void backwardstep2() {
  myStepper2->onestep(BACKWARD, DOUBLE);
// wrappers for the third motor!
void forwardstep3() {
  myStepper3->onestep(FORWARD, INTERLEAVE);
void backwardstep3() {
  myStepper3->onestep(BACKWARD, INTERLEAVE);
// Now we'll wrap the 3 steppers in an AccelStepper object
AccelStepper stepper1(forwardstep1, backwardstep1);
AccelStepper stepper2(forwardstep2, backwardstep2);
AccelStepper stepper3(forwardstep3, backwardstep3);
  AFMSbot.begin(); // Start the bottom shield
  AFMStop.begin(); // Start the top shield
  stepper1.setMaxSpeed(200.0);
  stepper1.setAcceleration(100.0);
  stepper1.moveTo(600);
  delay(1000);
  stepper2.setMaxSpeed(200.0);
  stepper2.setAcceleration(100.0);
  stepper2.moveTo(600);
  stepper3.setMaxSpeed(300.0);
  stepper3.setAcceleration(100.0);
  stepper3.moveTo(100);
    // Change direction at the limits
   if (stepper1.distanceToGo() == 0)
    stepper1.moveTo(400);
    if (stepper1.currentPosition() == 400)
      stepper1.moveTo(200);
   if (stepper2.distanceToGo() == 0)
    stepper2.moveTo(400);
    if (stepper2.currentPosition() == 400)
      stepper2.moveTo(200);
    stepper1.run();
    stepper2.run();
//    stepper3.run();
[/code]
请问,在这个程序中,如何来实现stepper2电机比stepper1电机延迟启动5秒钟啊。我试过加入delay()命令在其中多个地方,都达不到效果。(意思就是当stepper1号电机启动5秒钟之后,stepper2号电机开始启动,然后根据我的设定进入无限循环模式)。
 楼主| 发表于 2015-8-6 16:56:18 | 显示全部楼层
自己顶一下,求助大神们,或者有没有其它更好的解决方案?
谢谢了……
GMT+8, 2026-7-27 13:10 , Processed in 0.064184 second(s), 18 queries .
