kanshizhuo 发表于 2015-8-12 14:16
应该是你调节频率的问题,你试一试换过频率试试,不一定正确。
我把程序给你看看
int Pin0 = 4;
int Pin1 = 5;
int Pin2 = 6;
int Pin3 = 7;
int _step = 0;
char lkf;
boolean dir = true;//true为反转,false为正转
int stepperSpeed = 10;//电机转速,1ms一步
  pinMode(Pin0, OUTPUT);
  pinMode(Pin1, OUTPUT);
  pinMode(Pin2, OUTPUT);
  pinMode(Pin3, OUTPUT);
  run();
void run()
  switch(_step){
    case 0:
      digitalWrite(Pin0, LOW);
      digitalWrite(Pin1, LOW);
      digitalWrite(Pin2, LOW);
      digitalWrite(Pin3, HIGH);
    case 1:
      digitalWrite(Pin1, HIGH);
    case 2:
      digitalWrite(Pin3, LOW);
    case 3:
      digitalWrite(Pin2, HIGH);
    case 4:
    case 5:
      digitalWrite(Pin0, HIGH);
      case 6:
    case 7:
    default:
  if(dir){
    _step++;
  }else{
    _step--;
  if(_step>7){
    _step=0;
  if(_step<0){
    _step=7;
  delay(stepperSpeed);
