查看: 14050|回复: 7
求大神指导,编译通过,无法正常运行,求科普,貌似陷入死循环了
发表于 2015-8-14 16:19:17 | 显示全部楼层 |阅读模式
#include <Wire.h>
#include <MPU6050.h>
int dianji1=3;
int dianji2=5;
int dianji3=6;
int dianji4=9;
int BEEP=13;
MPU6050 mpu;
  Serial.begin(115200);
  Serial.println("Initialize MPU6050");
  while(!mpu.begin(MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G))
    Serial.println("Could not find a valid MPU6050 sensor, check wiring!");
    delay(500);
  checkSettings();
  pinMode(dianji1,OUTPUT);
  pinMode(dianji2,OUTPUT);
  pinMode(dianji3,OUTPUT);
  pinMode(dianji4,OUTPUT);
  pinMode(BEEP,OUTPUT);
  digitalWrite(dianji1,HIGH);
  delay(500);
void checkSettings()
  Serial.println();
  Serial.print(" * Sleep Mode:            ");
  Serial.println(mpu.getSleepEnabled() ? "Enabled" : "Disabled");
  Serial.print(" * Clock Source:          ");
  switch(mpu.getClockSource())
  case MPU6050_CLOCK_KEEP_RESET:
    Serial.println("Stops the clock and keeps the timing generator in reset");
  case MPU6050_CLOCK_EXTERNAL_19MHZ:
    Serial.println("PLL with external 19.2MHz reference");
  case MPU6050_CLOCK_EXTERNAL_32KHZ:
    Serial.println("PLL with external 32.768kHz reference");
  case MPU6050_CLOCK_PLL_ZGYRO:
    Serial.println("PLL with Z axis gyroscope reference");
  case MPU6050_CLOCK_PLL_YGYRO:
    Serial.println("PLL with Y axis gyroscope reference");
  case MPU6050_CLOCK_PLL_XGYRO:
    Serial.println("PLL with X axis gyroscope reference");
  case MPU6050_CLOCK_INTERNAL_8MHZ:
    Serial.println("Internal 8MHz oscillator");
  Serial.print(" * Accelerometer:         ");
  switch(mpu.getRange())
  case MPU6050_RANGE_16G:
    Serial.println("+/- 16 g");
  case MPU6050_RANGE_8G:
    Serial.println("+/- 8 g");
  case MPU6050_RANGE_4G:
    Serial.println("+/- 4 g");
  case MPU6050_RANGE_2G:
    Serial.println("+/- 2 g");
  Serial.print(" * Accelerometer offsets: ");
  Serial.print(mpu.getAccelOffsetX());
  Serial.print(" / ");
  Serial.print(mpu.getAccelOffsetY());
  Serial.println(mpu.getAccelOffsetZ());
  Serial.println();
  float jiaodu=0;
  Vector normAccel = mpu.readNormalizeAccel();
  jiaodu=acos(normAccel.ZAxis/8.8);
  delay(50);
LABEL1:
  if((acos(normAccel.ZAxis/8.8)-jiaodu)>0)
    if(-5<jiaodu)
      LABEL:
      digitalWrite(dianji3,HIGH);
      digitalWrite(dianji1,LOW);
      if(jiaodu>5)
        digitalWrite(dianji3,LOW);
        if(jiaodu>20)
          digitalWrite(BEEP,HIGH);
          goto LABEL1;
        goto LABEL;
    if(jiaodu<5)
      LABEL2:
      if(jiaodu<-5)
        if(jiaodu<-20)
          goto LABEL1;
        goto LABEL2;
发表于 2015-8-14 19:35:47 | 显示全部楼层
    delay(500);
发表于 2015-8-15 16:48:52 | 显示全部楼层
serial monitor 上看到什麼?
发表于 2015-8-15 18:15:40 | 显示全部楼层
先简要说一下你实现的功能
发表于 2015-8-15 18:16:36 | 显示全部楼层
很常见,程序没错误,但不是自己要的结果
 楼主| 发表于 2015-8-17 21:00:40 | 显示全部楼层
suoma 发表于 2015-8-15 18:16
很常见,程序没错误,但不是自己要的结果
就是这样的,因为实际动作和程序延时之间有问题,实现不了功能
发表于 2015-8-19 19:54:02 | 显示全部楼层
不知道实现什么功能?你仔细检查
 楼主| 发表于 2015-8-19 23:08:54 | 显示全部楼层
其实就是让电机在正负5度内加速,到达正负20度报警并刹车
GMT+8, 2026-7-27 05:32 , Processed in 0.039827 second(s), 21 queries .
