前面介绍了USB键盘的使用,这里介绍一下USB鼠标的调用。根据【参考1】的文章进行实验,这次我们的目标是:获得鼠标移动按键信息,串口输出之。
首先运行一下之前的取得描述符的工具抓取一下描述符:
Descriptor of HP Mouse
Start
Device addressed... Requesting device descriptor.
Device descriptor:
Descriptor Length: 12
USB version: 2.0
Class: 00 Use class information in the Interface Descriptor
Subclass: 00
Protocol: 00
Max.packet size: 08
Vendor ID: 046D
Product ID: C077
Revision ID: 6700
Mfg.string index: 01 Length: 18 Contents: Logitech
Prod.string index: 02 Length: 36 Contents: USB Optical Mouse
Serial number index: 00
Number of conf.: 01
Configuration number 0
Total configuration length: 34 bytes
Configuration descriptor:
Total length: 0022
Number of interfaces: 01
Configuration value: 01
Configuration string: 00
Attributes: A0 Remote Wakeup
Max.power: 31 98ma
Interface descriptor:
Interface number: 00
Alternate setting: 00
Endpoints: 01
Class: 03 HID (Human Interface Device)
Subclass: 01
Protocol: 02
Interface string: 00
HID descriptor:
Descriptor length: 09 9 bytes
HID version: 1.11
Country Code: 0 Not Supported
Class Descriptors: 1
Class Descriptor Type: 22 Report
Class Descriptor Length:67 bytes
HID report descriptor:
Length: 1 Type: Global Tag: Usage Page Generic Desktop Controls Data: 01
Length: 1 Type: Local Tag: Usage Data: 02
Length: 1 Type: Main Tag: Collection Application (mouse, keyboard) Data: 01
Length: 1 Type: Local Tag: Usage Data: 01
Length: 1 Type: Main Tag: Collection Physical (group of axes) Data: 00
Length: 1 Type: Global Tag: Usage Page Button Data: 09
Length: 1 Type: Local Tag: Usage Minimum Data: 01
Length: 1 Type: Local Tag: Usage Maximum Data: 08
Length: 1 Type: Global Tag: Logical Minimum Data: 00
Length: 1 Type: Global Tag: Logical Maximum Data: 01
Length: 1 Type: Global Tag: Report Size Data: 01
Length: 1 Type: Global Tag: Report Count Data: 08
Length: 1 Type: Main Tag: Input Data,Variable,Absolute………
Length: 2 Type: Global Tag: Logical Minimum Data: 01 Data: F8
Length: 2 Type: Global Tag: Logical Maximum Data: FF Data: 07
Length: 1 Type: Global Tag: Report Size Data: 0C
Length: 1 Type: Global Tag: Report Count Data: 02
Length: 1 Type: Local Tag: Usage Data: 30
Length: 1 Type: Local Tag: Usage Data: 31
Length: 1 Type: Main Tag: Input Data,Variable,Relative………
Length: 1 Type: Global Tag: Logical Minimum Data: 81
Length: 1 Type: Global Tag: Logical Maximum Data: 7F
Length: 1 Type: Global Tag: Report Size Data: 08
Length: 1 Type: Global Tag: Report Count Data: 01
Length: 1 Type: Local Tag: Usage Data: 38
Length: 1 Type: Global Tag: Usage Page Consumer Data: 0C
Length: 2 Type: Local Tag: Usage Data: 38 Data: 02
Length: 0 Type: Main Tag: End Collection
Endpoint descriptor:
Endpoint address: 01 Direction: IN
Attributes: 03 Transfer type: Interrupt
Max.packet size: 0006
Polling interval: 0A 10 ms
根据上面的结果,计算长度应该是1x8+Cx2+8x1=40 bits= 5 bytes ,修改【参考1】的代码如下:
- #include "Max3421e.h"
- #include "Usb.h"
- #define DEVADDR 1
- #define CONFVALUE 1
- void setup();
- void loop();
- MAX3421E Max;
- USB Usb;
- void setup()
- Serial.begin( 115200 );
- Serial.println("Start");
- Max.powerOn();
- delay( 200 );
- void loop()
- byte rcode;
- Max.Task();
- Usb.Task();
- if( Usb.getUsbTaskState() == USB_STATE_CONFIGURING ) {
- mouse0_init();
- }//if( Usb.getUsbTaskState() == USB_STATE_CONFIGURING...
- if( Usb.getUsbTaskState() == USB_STATE_RUNNING ) { //poll the keyboard
- rcode = mouse0_poll();
- if( rcode ) {
- Serial.print("Mouse Poll Error: ");
- Serial.println( rcode, HEX );
- }//if( rcode...
- }//if( Usb.getUsbTaskState() == USB_STATE_RUNNING...
- /* Initialize mouse */
- void mouse0_init( void )
- byte rcode = 0; //return code
- Usb.setDevTableEntry( 1, Usb.getDevTableEntry( 0,0 ) ); //copy device 0 endpoint information to device 1
- /* Configure device */
- rcode = Usb.setConf( DEVADDR, 0, CONFVALUE );
- if( rcode ) {
- Serial.print("Error configuring mouse. Return code : ");
- while(1); //stop
- }//if( rcode...
- Usb.setUsbTaskState( USB_STATE_RUNNING );
- return;
- /* Poll mouse using Get Report and print result */
- byte mouse0_poll( void )
- byte rcode,i;
- char buf[ 4 ] = { 0 }; //mouse buffer
- static char old_buf[ 4 ] = { 0 }; //last poll
- /* poll mouse */
- rcode = Usb.getReport( DEVADDR, 0, 4, 0, 1, 0, buf );
- if( rcode ) { //error
- return( rcode );
- for( i = 0; i < 4; i++) { //check for new information
- if( buf[ i ] != old_buf[ i ] ) { //new info in buffer
- break;
- if( i == 4 ) {
- return( 0 ); //all bytes are the same
- /* print buffer */
- if( buf[ 0 ] & 0x01 ) {
- Serial.print("Button1 pressed ");
- if( buf[ 0 ] & 0x02 ) {
- Serial.print("Button2 pressed ");
- if( buf[ 0 ] & 0x04 ) {
- Serial.print("Button3 pressed ");
- Serial.println("");
- Serial.print("X-axis: ");
- Serial.println( buf[ 1 ], DEC);
- Serial.print("Y-axis: ");
- Serial.println( buf[ 2 ], DEC);
- Serial.print("Wheel: ");
- Serial.println( buf[ 3 ], DEC);
- for( i = 0; i < 4; i++ ) {
- old_buf[ i ] = buf[ i ]; //copy buffer
- return( rcode );
运行结果
完整代码下载
看起来按键和X Y都已经正确,但是 wheel 并不正常。再仔细研究代码,取出来的信息长度和描述符中的不一致。就是说,程序虽然能够运行也能够取到变化的值,但是解读有误。
再进一步研读 Descriptor
Length: 2 Type: Global Tag: Logical Minimum Data: 01 Data: F8 //最小 F801 = 1111 1000 0000 0001 = -2047
Length: 2 Type: Global Tag: Logical Maximum Data: FF Data: 07//最大 07FF = 0000 0111 1111 1111 = 2047
Length: 1 Type: Global Tag: Report Size Data: 0C //这里指出了上面数值的大小是 12位
Length: 1 Type: Local Tag: Usage Data: 30 // X
Length: 1 Type: Local Tag: Usage Data: 31 // Y
应该是意味着2个12bits长度的数值,对应X Y 分配如下,其中 X[B] 和Y[B]应该是最高的符号位
根据这个改写程序,按照上面的表格取值再拼接起来,特别需要注意的是,我发现Arduino在不同尺寸的数据转换上似乎有一些bug,我只能把值放在 unsigned long int中然后才能进行拼接和输出的动作。
- x=((libuf[2] & 0xF)<<8)+(libuf[1] & 0xFF );
- if (x & 0x800) {
- Serial.print("-");
- x = ((~x) & 0x7FF) +1;
- Serial.println(x, HEX);
- y=(((libuf[2]>>4) & 0xF) +((libuf[3] & 0xFF )<<4));
- if (y & 0x800) {
- y = ((~y) & 0x7FF) +1;
- Serial.println(y, HEX);
最终,程序可以正常执行。
工作正常的程序如下:
- #include "Usb.h"
- #define DEVADDR 1
- void setup();
- void loop();
- MAX3421E Max;
- USB Usb;
- void setup()
- Max.powerOn();
- delay( 200 );
- void loop()
- byte rcode;
- Max.Task();
- Usb.Task();
- mouse0_init();
- if( rcode ) {
- }//if( rcode...
- if( rcode ) {
- while(1); //stop
- }//if( rcode...
- return;
- byte rcode,i;
- char buf[ 5 ] = { 0 }; //mouse buffer
- static char old_buf[ sizeof(buf) ] = { 0 }; //last poll
- unsigned long int libuf[ sizeof(buf) ];
- unsigned long int x;
- unsigned long int y;
- /* poll mouse */
- rcode = Usb.getReport( DEVADDR, 0, sizeof(buf), 0, 1, 0, buf );
- return( rcode );
- for( i = 0; i < sizeof(buf); i++) { //check for new information
- break;
- if( i == sizeof(buf)) {
- for( i = 0; i < sizeof(buf); i++ ) {
- libuf[ i] = buf[i];
- //Serial.print(libuf[0],HEX); Serial.print(" ");
- //Serial.print(libuf[1],HEX); Serial.print(" ");
- //Serial.print(libuf[2],HEX); Serial.print(" ");
- //Serial.print(libuf[3],HEX); Serial.print(" ");
- //Serial.println("");
- if (x & 0x800) {
- if (y & 0x800) {
- Serial.println(buf [4] & 0xFF, HEX);
- return( rcode );
完整代码下载:
补遗:在运行中,我还发现了一个奇怪的问题,鼠标向一个方向移动,会出现最大值。意思是:比如,向右一直移动鼠标,输出达到 7FF 之后,继续右移,输出值会维持在 7FF 而不会变化。没有找到直接描述这个问题的资料,不过有一些类似的介绍【参考2】,上面提到USB鼠标在送出数据的时候,会有两种方式,一种是Relative ,一种是Absolute。差别在于,比如前者输出 (1,1),意思是告诉系统鼠标移动了(1,1);而后者如果输出 (1,1)则是告诉系统,鼠标移动到(1,1)。看起来,我这个鼠标描述符中提到的是Relative,但是实际输出是 Absolute。
于此可以形成对照的是 Wheel,每次滚动之后,很快会再次输出一个 0 的位置,下次再给出新的滚动值。
至于Windows 下,根据资料,系统会自动根据鼠标信息计算出一个大概范围方便使用(比如,屏幕是 1024x768,鼠标是Relative -100到+100的话,如果不做优化,从左上到右下需要做几次才行)。而我用的这个鼠标,声明自己是Relative,但是实际上发出Absolute,只是因为自己的范围很大(-7FF到+7FF),所以也不会有什么感觉。
上述只是猜测,是目前已知的最合理的解释而已。使用逻辑分析仪分析USB鼠标信息得到的结果相同。
逻辑分析仪抓取的结果,Windows使用 Interrupt 方式来和鼠标通讯
下面展示一下USB逻辑分析仪抓到的启动时的一些信息,首先是 Overview
