查看: 17715|回复: 12
哪位大侠看看串口问题
发表于 2015-9-5 21:50:02 | 显示全部楼层 |阅读模式
现在问题串口输出可以控制计数。串口设置输入进不来,
int incomingByte =  0;
int ledpin = 8; //定义数字接口13
int j=0;//初使化加数变量
int addKey =4;//定义按键为第4引脚
int buttonState = 0; //初使化按键暂存值,为了和addKey类型保持一致用int;
unsigned char showNumber[100][8] ={
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x01},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x02},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x03},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x04},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x05},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x06},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x07},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x08},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x09},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x0A},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x0B},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x0D},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x0E},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x0F},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x10},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x11},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x12},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x13},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x14},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x15},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x16},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x17},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x18},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x19},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x1A},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x1B},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x1D},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x1E},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x1F},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x20},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x21},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x22},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x23},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x24},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x25},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x26},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x27},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x28},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x29},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x2A},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x2B},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x2D},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x2E},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x2F},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x30},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x31},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x32},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x33},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x34},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x35},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x36},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x37},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x38},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x39},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x3A},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x3B},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x3D},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x3F},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x40},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x41},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x42},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x43},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x44},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x45},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x46},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x47},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x48},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x49},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x4A},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x4B},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x4D},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x4E},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x4F},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x50},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x51},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x52},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x53},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x54},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x55},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x56},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x57},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x58},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x59},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x5A},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x5B},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x5D},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x5E},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x5F},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x60},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x61},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x62},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x63},
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x64}};
//{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x65},
unsigned char HEXHEX0[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x00};
unsigned char HEXHEX1[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x01};
unsigned char HEXHEX2[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x02};
unsigned char HEXHEX3[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x03};
unsigned char HEXHEX4[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x04};
unsigned char HEXHEX5[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x05};
unsigned char HEXHEX6[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x06};
unsigned char HEXHEX7[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x07};
unsigned char HEXHEX8[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x08};
unsigned char HEXHEX9[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x09};
unsigned char HEXHEX10[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x0A};
int x = 0;
int CheckSum0 = 0;
int CheckSum1 = 0;
int CheckSum2 = 0;
int CheckSum3 = 0;
int CheckSum4 = 0;
int CheckSum5 = 0;
int CheckSum6 = 0;
int CheckSum7 = 0;
int CheckSum8 = 0;
int CheckSum9 = 0;
int CheckSum10 = 0;
  pinMode(ledpin, OUTPUT);
// Serial.flush();//初使化串口
pinMode(addKey,INPUT);//初使化物理按键输入
  if (Serial.available() > 0)
    incomingByte = Serial.read();
    Serial.print(incomingByte, HEX);
    if (HEXHEX0[x] == incomingByte){CheckSum0++;}
    if (HEXHEX1[x] == incomingByte){CheckSum1++;}
    if (HEXHEX2[x] == incomingByte){CheckSum2++;}
    if (HEXHEX3[x] == incomingByte){CheckSum3++;}
    if (HEXHEX4[x] == incomingByte){CheckSum4++;}
    if (HEXHEX5[x] == incomingByte){CheckSum5++;}
    if (HEXHEX6[x] == incomingByte){CheckSum6++;}
    if (HEXHEX7[x] == incomingByte){CheckSum7++;}
    if (HEXHEX8[x] == incomingByte){CheckSum8++;}
    if (HEXHEX9[x] == incomingByte){CheckSum9++;}
    if (HEXHEX10[x] == incomingByte){CheckSum10++;}
    x++;
    if (x == 9) {
      if (CheckSum0 == 9) {
        digitalWrite(ledpin, HIGH); //点亮数字13 口LED。
        delay(500);
      if (CheckSum1 == 9) {
        digitalWrite(ledpin, LOW); //熄灭数字13 口LED
        delay(500);
        if (CheckSum2 == 9) {
        delay(500);
      if (CheckSum3 == 9) {
        delay(500);
        if (CheckSum4 == 9) {
        delay(500);
      if (CheckSum5 == 9) {
        delay(500);
        if (CheckSum6 == 9) {
        delay(500);
      if (CheckSum7 == 9) {
        delay(500);
        if (CheckSum8 == 9) {
        delay(500);
      if (CheckSum9 == 9) {
        delay(500);
        if (CheckSum10 == 9) {
        delay(500);
      x = 0;
      CheckSum0 = 0;
      CheckSum1 = 0;
       CheckSum2 = 0;
      CheckSum3 = 0;
       CheckSum4 = 0;
      CheckSum5 = 0;
       CheckSum6 = 0;
      CheckSum7 = 0;
       CheckSum8 = 0;
      CheckSum9 = 0;
       CheckSum10 = 0;
   buttonState = digitalRead(addKey);//将第4脚的电平赋予按键变量
  if (buttonState == LOW)
   delay(10);
    if (buttonState == LOW)//机械式延时去抖
    j++;//按键后变量加1;
    while(!digitalRead(addKey));//等待松开按键结束,按键弹起算一次有效值
     switch(j)
case 1:
Serial.write(&showNumber[0][0],8);
case 2:
Serial.write(&showNumber[1][0],8);
case 3:
Serial.write(&showNumber[2][0],8);
case 4:
Serial.write(&showNumber[3][0],8);
case 5:
Serial.write(&showNumber[4][0],8);
case 6:
Serial.write(&showNumber[5][0],8);
case 7:
Serial.write(&showNumber[6][0],8);
case 8:
Serial.write(&showNumber[7][0],8);
case 9:
Serial.write(&showNumber[8][0],8);
case 10:
Serial.write(&showNumber[9][0],8);
case 11:
Serial.write(&showNumber[10][0],8);
case 12:
Serial.write(&showNumber[11][0],8);
case 13:
Serial.write(&showNumber[12][0],8);
case 14:
Serial.write(&showNumber[13][0],8);
case 15:
Serial.write(&showNumber[14][0],8);
case 16:
Serial.write(&showNumber[15][0],8);
case 17:
Serial.write(&showNumber[16][0],8);
case 18:
Serial.write(&showNumber[17][0],8);
case 19:
Serial.write(&showNumber[18][0],8);
case 20:
Serial.write(&showNumber[19][0],8);
case 21:
Serial.write(&showNumber[20][0],8);
case 22:
Serial.write(&showNumber[21][0],8);
case 23:
Serial.write(&showNumber[22][0],8);
case 24:
Serial.write(&showNumber[23][0],8);
case 25:
Serial.write(&showNumber[24][0],8);
case 26:
Serial.write(&showNumber[25][0],8);
case 27:
Serial.write(&showNumber[26][0],8);
case 28:
Serial.write(&showNumber[27][0],8);
case 29:
Serial.write(&showNumber[28][0],8);
case 30:
Serial.write(&showNumber[29][0],8);
case 31:
Serial.write(&showNumber[30][0],8);
case 32:
Serial.write(&showNumber[31][0],8);
case 33:
Serial.write(&showNumber[32][0],8);
case 34:
Serial.write(&showNumber[33][0],8);
case 35:
Serial.write(&showNumber[34][0],8);
case 36:
Serial.write(&showNumber[35][0],8);
case 37:
Serial.write(&showNumber[36][0],8);
case 38:
Serial.write(&showNumber[37][0],8);
case 39:
Serial.write(&showNumber[38][0],8);
case 40:
Serial.write(&showNumber[39][0],8);
case 41:
Serial.write(&showNumber[40][0],8);
case 42:
Serial.write(&showNumber[41][0],8);
case 43:
Serial.write(&showNumber[42][0],8);
case 44:
Serial.write(&showNumber[43][0],8);
case 45:
Serial.write(&showNumber[44][0],8);
case 46:
Serial.write(&showNumber[45][0],8);
case 47:
Serial.write(&showNumber[46][0],8);
case 48:
Serial.write(&showNumber[47][0],8);
case 49:
Serial.write(&showNumber[48][0],8);
case 50:
Serial.write(&showNumber[49][0],8);
case 51:
Serial.write(&showNumber[50][0],8);
case 52:
Serial.write(&showNumber[51][0],8);
case 53:
Serial.write(&showNumber[52][0],8);
case 54:
Serial.write(&showNumber[53][0],8);
case 55:
Serial.write(&showNumber[54][0],8);
case 56:
Serial.write(&showNumber[55][0],8);
case 57:
Serial.write(&showNumber[56][0],8);
case 58:
Serial.write(&showNumber[57][0],8);
case 59:
Serial.write(&showNumber[58][0],8);
case 60:
Serial.write(&showNumber[59][0],8);
case 61:
Serial.write(&showNumber[60][0],8);
case 62:
Serial.write(&showNumber[61][0],8);
case 63:
Serial.write(&showNumber[62][0],8);
case 64:
Serial.write(&showNumber[63][0],8);
case 65:
Serial.write(&showNumber[64][0],8);
case 66:
Serial.write(&showNumber[65][0],8);
case 67:
Serial.write(&showNumber[66][0],8);
case 68:
Serial.write(&showNumber[67][0],8);
case 69:
Serial.write(&showNumber[68][0],8);
case 70:
Serial.write(&showNumber[69][0],8);
case 71:
Serial.write(&showNumber[70][0],8);
case 72:
Serial.write(&showNumber[71][0],8);
case 73:
Serial.write(&showNumber[72][0],8);
case 74:
Serial.write(&showNumber[73][0],8);
case 75:
Serial.write(&showNumber[74][0],8);
case 76:
Serial.write(&showNumber[75][0],8);
case 77:
Serial.write(&showNumber[76][0],8);
case 78:
Serial.write(&showNumber[77][0],8);
case 79:
Serial.write(&showNumber[78][0],8);
case 80:
Serial.write(&showNumber[79][0],8);
case 81:
Serial.write(&showNumber[80][0],8);
case 82:
Serial.write(&showNumber[81][0],8);
case 83:
Serial.write(&showNumber[82][0],8);
case 84:
Serial.write(&showNumber[83][0],8);
case 85:
Serial.write(&showNumber[84][0],8);
case 86:
Serial.write(&showNumber[85][0],8);
case 87:
Serial.write(&showNumber[86][0],8);
case 88:
Serial.write(&showNumber[87][0],8);
case 89:
Serial.write(&showNumber[88][0],8);
case 90:
Serial.write(&showNumber[89][0],8);
case 91:
Serial.write(&showNumber[90][0],8);
case 92:
Serial.write(&showNumber[91][0],8);
case 93:
Serial.write(&showNumber[92][0],8);
case 94:
Serial.write(&showNumber[93][0],8);
case 95:
Serial.write(&showNumber[94][0],8);
case 96:
Serial.write(&showNumber[95][0],8);
case 97:
Serial.write(&showNumber[96][0],8);
case 98:
Serial.write(&showNumber[97][0],8);
case 99:
Serial.write(&showNumber[98][0],8);
case 100:
Serial.write(&showNumber[99][0],8);
j=0;
default:
发表于 2015-9-5 23:44:08 | 显示全部楼层
你的串口是怎樣接的?  程式上有點不統一似的.
  Serial.print(incomingByte, HEX);  <- 看似接了電腦
  Serial.write(&showNumber[??][0],8);  <- 看似接了其他裝置
要大家幫忙, 也清楚說明一下你是如何連接, 執行後出了什麼問題.
"串口设置输入进不来,"<- 你如何肯定是串口輸入进不来.
那個 switch(j) 的部份也太重複了, 只要 j 是 1-100 之間, 直接  Serial.write(&showNumber[j-1][0],8);  不就行了嗎?
輸入的部份也有重複而造成點亂, 整個程式, 應該可以減少 8 成以上.
发表于 2015-9-6 10:35:52 | 显示全部楼层
其實我比較好奇,內存沒滿嗎
发表于 2015-9-6 10:56:38 | 显示全部楼层
Be1ieve 发表于 2015-9-6 10:35
其實我比較好奇,內存沒滿嗎
目测刚用掉1K 应该还好吧
 楼主| 发表于 2015-9-6 12:10:21 | 显示全部楼层
rial.print(incomingByte, HEX);  读中显液晶屏16进制码  A5 5A 06  83 00 00 01 00 00  和我的那个 SeHEXHEX0---HEXHEX9比较输出。
if (Serial.available() > 0) incomingByte = Serial.read();读中显液晶屏16进制码  A5 5A 06  83 00 00 01 00 00没反应.led没有变化
   delay(10);
    j++;//按键后变量加1;
这个是计数液晶屏条数有变化。程序正常。是不是串口读写不能同时进行 。我也是个菜鸟程序不大懂。哪位大侠帮帮忙.
发表于 2015-9-6 13:27:36 | 显示全部楼层
这一个LOOP程序就有几百行,有些应该改成函数形式的,要调度什么的也方便点。
发表于 2015-9-6 18:47:01 | 显示全部楼层
你居然换了ID,又来问这个。。。。。
发表于 2015-9-6 21:40:59 | 显示全部楼层
李超然2365 发表于 2015-9-6 12:10
rial.print(incomingByte, HEX);  读中显液晶屏16进制码  A5 5A 06  83 00 00 01 00 00  和我的那个  ...
你引用了我的回覆, 但你的內容好像跟我問你的完全沒相關的..... 你是否引用錯了?
 楼主| 发表于 2015-9-6 22:09:56 | 显示全部楼层
没有。单片就串口发送16进制数到中显液晶屏显示条数。在液晶屏设定条数串口返回16进制数到单片机。
大侠指点一二。
发表于 2015-9-7 18:00:42 | 显示全部楼层
大 ...
你好像沒看到我在問什麼似的....我不是問你的程式在做什麼, 程式的內容我大致也明白.
而且, 你一直沒說清楚你進行了怎樣的測試, 結果出了什麼問題.
或者你確定一下, 你的 显液晶屏 要接收什麼格式, 你同時了兩種不同的格式去發送, 還是你想送到不同的地方:
你知道兩者的分別嗎?
我手上沒你的硬件, 只可以從程式上去猜, 沒有足夠的資料, 實在無能為力.
 楼主| 发表于 2015-9-7 21:42:34 | 显示全部楼层
而且, 你一直沒說清 ...
为什么添加这个程序上边的对比程序不管用了
   delay(10);
    j++;//按键后变量加1;
液晶屏串口程序
unsigned char HEXFD1[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x01};
unsigned char HEXFD2[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x02};
unsigned char HEXFD3[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x03};
unsigned char HEXFD4[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x04};
unsigned char HEXFD5[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x05};
unsigned char HEXFD6[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x06};
unsigned char HEXFD7[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x07};
unsigned char HEXFD8[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x08};
unsigned char HEXFD9[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x09};
unsigned char HEXFD10[9] = {0xA5, 0x5A, 0x06, 0x83, 0x00,0x00, 0x01,0x00, 0x0A};
int j=0;//初使化加数变量
unsigned char showNumber[10][8] ={
{0xA5,0x5A,0x05,0x82,0x00,0x10,0x00,0x0A}};
int x = 0;
int CheckSumX1 = 0;
int CheckSumX2 = 0;
int CheckSumX3 = 0;
int CheckSumX4 = 0;
int CheckSumX5 = 0;
int CheckSumX6 = 0;
int CheckSumX7 = 0;
int CheckSumX8 = 0;
int CheckSumX9 = 0;
int CheckSumX10 = 0;
  // Serial.write(hexdata,7);
    if (HEXFD1[x] == incomingByte) {
      CheckSumX1++;
    if (HEXFD2[x] == incomingByte) {
      CheckSumX2++;
     if (HEXFD3[x] == incomingByte) {
      CheckSumX3++;
    if (HEXFD4[x] == incomingByte) {
      CheckSumX4++;
     if (HEXFD5[x] == incomingByte) {
      CheckSumX5++;
    if (HEXFD6[x] == incomingByte) {
      CheckSumX6++;
     if (HEXFD7[x] == incomingByte) {
      CheckSumX7++;
    if (HEXFD8[x] == incomingByte) {
      CheckSumX8++;
     if (HEXFD9[x] == incomingByte) {
      CheckSumX9++;
    if (HEXFD10[x] == incomingByte) {
      CheckSumX10++;
    x++;
    if (x == 9) {
      if (CheckSumX5 == 9) {
        delay(5000);
      if (CheckSumX7 == 9) {
        delay(5000);
      x = 0;
      CheckSumX5 = 0;
      CheckSumX7 = 0;
   delay(10);
    j++;//按键后变量加1;
      switch(j)
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
j=0;
default:
 楼主| 发表于 2015-9-7 21:43:02 | 显示全部楼层
而且, 你一直沒說清 ...
   delay(10);
    j++;//按键后变量加1;
液晶屏串口程序
int j=0;//初使化加数变量
int x = 0;
int CheckSumX1 = 0;
int CheckSumX2 = 0;
int CheckSumX3 = 0;
int CheckSumX4 = 0;
int CheckSumX5 = 0;
int CheckSumX6 = 0;
int CheckSumX7 = 0;
int CheckSumX8 = 0;
int CheckSumX9 = 0;
      CheckSumX1++;
      CheckSumX2++;
      CheckSumX3++;
      CheckSumX4++;
      CheckSumX5++;
      CheckSumX6++;
      CheckSumX7++;
      CheckSumX8++;
      CheckSumX9++;
      CheckSumX10++;
    x++;
    if (x == 9) {
        delay(5000);
        delay(5000);
      x = 0;
      CheckSumX5 = 0;
      CheckSumX7 = 0;
   delay(10);
    j++;//按键后变量加1;
      switch(j)
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
j=0;
default:
 楼主| 发表于 2015-9-8 16:43:05 | 显示全部楼层
RE: 哪位大侠看看串口问题
maxims 发表于 2015-9-6 18:47
你居然换了ID,又来问这个。。。。。
我为什加上这段。对比程序就不管用了。循环不进去吗没。
   delay(10);
    j++;//按键后变量加1;
液晶屏串口程序
int j=0;//初使化加数变量
int x = 0;
int CheckSumX1 = 0;
int CheckSumX2 = 0;
int CheckSumX3 = 0;
int CheckSumX4 = 0;
int CheckSumX5 = 0;
int CheckSumX6 = 0;
int CheckSumX7 = 0;
int CheckSumX8 = 0;
int CheckSumX9 = 0;
      CheckSumX1++;
      CheckSumX2++;
      CheckSumX3++;
      CheckSumX4++;
      CheckSumX5++;
      CheckSumX6++;
      CheckSumX7++;
      CheckSumX8++;
      CheckSumX9++;
      CheckSumX10++;
    x++;
    if (x == 9) {
        delay(5000);
        delay(5000);
      x = 0;
      CheckSumX5 = 0;
      CheckSumX7 = 0;
   delay(10);
    j++;//按键后变量加1;
      switch(j)
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
j=0;
default:
GMT+8, 2026-6-17 21:32 , Processed in 0.041987 second(s), 22 queries .
