查看: 15742|回复: 3
四总线LCD1602中的一个函数问题
发表于 2012-8-19 16:39:26 | 显示全部楼层 |阅读模式
int LCD1602_RS=12;
int LCD1602_RW=11;
int LCD1602_EN=10;
int DB[] = { 6, 7, 8, 9};
char str1[]="Welcome to";
char str2[]="geek-workshop";
char str3[]="this is the";
char str4[]="4-bit interface";
void LCD_Command_Write(int command)
int i,temp;
digitalWrite( LCD1602_RS,LOW);
digitalWrite( LCD1602_RW,LOW);
digitalWrite( LCD1602_EN,LOW);
temp=command & 0xf0;
for (i=DB[0]; i <= 9; i++)
   digitalWrite(i,temp & 0x80);
   temp <<= 1;
digitalWrite( LCD1602_EN,HIGH);
delayMicroseconds(1);
temp=(command & 0x0f)<<4;
for (i=DB[0]; i <= 10; i++)
   temp <<= 1;
void LCD_Data_Write(int dat)
int i=0,temp;
digitalWrite( LCD1602_RS,HIGH);
temp=dat & 0xf0;
   temp <<= 1;
temp=(dat & 0x0f)<<4;
   temp <<= 1;
void LCD_SET_XY( int x, int y )
  int address;
  if (y ==0)    address = 0x80 + x;
  else          address = 0xC0 + x;
  LCD_Command_Write(address);
void LCD_Write_Char( int x,int y,int dat)
  LCD_SET_XY( x, y );
  LCD_Data_Write(dat);
void LCD_Write_String(int X,int Y,char *s)
    LCD_SET_XY( X, Y );    //设置地址
    while (*s)             //写字符串
      LCD_Data_Write(*s);
      s ++;
void setup (void)
  int i = 0;
  for (i=6; i <= 12; i++)
     pinMode(i,OUTPUT);
  delay(100);
  LCD_Command_Write(0x28);//4线 2行 5x7
  delay(50);
  LCD_Command_Write(0x06);
  delay(50);
  LCD_Command_Write(0x0c);
  delay(50);
  LCD_Command_Write(0x80);
  delay(50);
  LCD_Command_Write(0x01);
  delay(50);
void loop (void)
   delay(50);
   LCD_Write_String(3,0,str1);//第1行,第4个地址起
   delay(50);
   LCD_Write_String(1,1,str2);//第2行,第2个地址起
   delay(5000);
   delay(50);
   LCD_Write_String(0,0,str3);
   delay(50);
   LCD_Write_String(0,1,str4);
   delay(5000);
这是代码。
其中
int i,temp;
   temp <<= 1;
   temp <<= 1;
求高人解析这段函数。谢谢!
发表于 2012-8-19 20:30:17 | 显示全部楼层
这是在用arduino的io口模拟1602的时序
你查1602的手册自然会发现的
发表于 2012-8-21 01:35:12 | 显示全部楼层
4 线式的工作原理是,用4个IO口,把数据发两次发送出去。
void LCD_Command_Write(int command)//LCD指令控制,
int i,temp;
digitalWrite( LCD1602_RW,LOW);//RS低,RW低,E高脉冲(下面为脉冲信号生成),写指令
temp=command & 0xf0;//0xf0,设置数据D4-7方向为输出,D0-3为输入
   digitalWrite(i,temp & 0x80);//0x80+地址,设置LCD第一行的数据指针初始地址
   temp <<= 1;
digitalWrite( LCD1602_EN,LOW);//生成脉冲信号
   temp <<= 1;
如出现开机显示乱码等情况,你把delayMicroseconds(1);这个值修改为1~3范围就可以,因为很多国产1602用的芯片比较杂,芯片的性能都不一样,不要给这些数值局限死,我就为了初始化显示乱码问题,困扰了2个月!
 楼主| 发表于 2012-8-21 13:41:46 | 显示全部楼层
感激不尽
GMT+8, 2026-7-23 21:03 , Processed in 0.052923 second(s), 19 queries .
