楼主: Ansifa
Arduino学习笔记A8 - Arduino 连接 DS1302时钟模块
发表于 2018-3-6 17:41:39 | 显示全部楼层
辛苦楼主了,这个很有用,哈哈家里正好有个模块,加个 lcd1602,组个闹钟用.
发表于 2018-4-1 15:09:34 | 显示全部楼层
大神,有arduino+ds3231+lcd12864的资料吗
发表于 2018-4-14 15:42:46 | 显示全部楼层
很有用的东西!
发表于 2018-5-20 21:31:22 | 显示全部楼层
可否问下楼主是否还需要一个“WProgram.h”文件,我编译的时候出现了问题,下面是错误信息:
Arduino:1.8.4 (Windows 10), 开发板:"Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Lenovo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Lenovo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Lenovo\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10804 -build-path C:\Users\Lenovo\AppData\Local\Temp\arduino_build_688817 -warnings=none -build-cache C:\Users\Lenovo\AppData\Local\Temp\arduino_cache_521753 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Program Files (x86)\Arduino\libraries\DS1302\examples\set_clock\set_clock.pde
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Lenovo\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Lenovo\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Lenovo\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10804 -build-path C:\Users\Lenovo\AppData\Local\Temp\arduino_build_688817 -warnings=none -build-cache C:\Users\Lenovo\AppData\Local\Temp\arduino_cache_521753 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Program Files (x86)\Arduino\libraries\DS1302\examples\set_clock\set_clock.pde
Using board 'uno' from platform in folder: C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Using core 'arduino' from platform in folder: C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Detecting libraries used...
"C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\Lenovo\AppData\Local\Temp\arduino_build_688817\sketch\set_clock.pde.cpp" -o "nul"
"C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\DS1302" "C:\Users\Lenovo\AppData\Local\Temp\arduino_build_688817\sketch\set_clock.pde.cpp" -o "nul"
"C:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\DS1302" "C:\Users\Lenovo\AppData\Local\Temp\arduino_build_688817\sketch\set_clock.pde.cpp" -o "C:\Users\Lenovo\AppData\Local\Temp\arduino_build_688817\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Program Files (x86)\Arduino\libraries\DS1302\examples\set_clock\set_clock.pde:11:0:
C:\Program Files (x86)\Arduino\libraries\DS1302/DS1302.h:31:22: fatal error: WProgram.h: No such file or directory
#include "WProgram.h"
compilation terminated.
使用库 DS1302 在文件夹: C:\Program Files (x86)\Arduino\libraries\DS1302 (legacy)
exit status 1
为开发板 Arduino/Genuino Uno 编译时出错。
然后我打开“DS1302.h”文件,哭笑不得的发现了这行代码:
  1. #include "WProgram.h"
顺便说一下,我用的是1.8.4的Arduino IDE
GMT+8, 2026-7-22 17:01 , Processed in 0.035807 second(s), 20 queries .
