查看: 17147|回复: 2
舵机反转,怎么写啊
发表于 2012-10-9 21:46:43 | 显示全部楼层 |阅读模式
如题,官方的教程都是0-180或者180-0转,我想知道反过来该如何该这程序
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 90; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(10);                       // waits 15ms for the servo to reach the position
  for(pos = 90; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
发表于 2012-10-10 13:57:09 | 显示全部楼层
你这上半部分是正转,下半部分是反转。还能怎么转?
难道下面这样?一开始就是180度?
int pos = 180;
myservo.write(pos);
for(pos = 180; pos > 0 ; pos -= 1)
myservo.write(pos);
 楼主| 发表于 2012-10-10 14:07:17 | 显示全部楼层
难道下面这样?一开始就是180度?
int pos = 180;
还在研究,舵机上装了机械手,舵机控制起来不是太好
GMT+8, 2026-7-26 17:32 , Processed in 0.176795 second(s), 18 queries .
