查看: 21405|回复: 6
asp.net读取arduino上温度传感器数据
发表于 2012-10-29 02:49:27 | 显示全部楼层 |阅读模式
我手上有arduino 2560 和 一个w5100的网络模块,我想从一个asp.net的网站读取arduino上温度传感器数据,各位能否指点一二?我只熟悉asp.net,对PHP没有太多了解。
发表于 2012-10-29 08:36:04 | 显示全部楼层
如果只是在asp.net页面上显示温度的话,可以把Arduino2560和W5100写成一个WebServer,读取温度值并输出一个网页。用asp.net写的页面里嵌入这个2560的页面,但一定要把页面组织好,要不不好看。只是一个建议,效果不一定好。如果要是还要把数据读取并写入数据库,建议用Arduino2560和W5100写成一个WebClient,通过url调用把温度定时写入数据库,然后asp.net再从数据库里取温度值。
 楼主| 发表于 2012-11-4 01:12:45 | 显示全部楼层
#include <SPI.h>
#include <Ethernet.h>
#define APIKEY         "YOUR API KEY GOES HERE" // replace your pachube api key here
#define FEEDID         00000 // replace your feed ID
#define USERAGENT      "My Project" // user agent is the project name
// assign a MAC address for the ethernet controller.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
// fill in your address here:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// fill in an available IP address on your network here,
// for manual configuration:
IPAddress ip(192,168,1,254);
// initialize the library instance:
EthernetClient client;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
IPAddress server(192,168,1,5);
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 10*1000; //delay between updates to Pachube.com
  // Open serial communications and wait for port to open:
    while (!Serial) {
     ; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
   if (Ethernet.begin(mac) == 0) {
     // DHCP failed, so use a fixed IP address:
     Ethernet.begin(mac, ip);
   // read the analog sensor:
   int sensorReading = analogRead(A0);
  // if there's incoming data from the net connection.
   // send it out the serial port.  This is for debugging
   // purposes only:
   if (client.available()) {
     char c = client.read();
     Serial.print(c);
  // if there's no net connection, but there was one last time
   // through the loop, then stop the client:
   if (!client.connected() && lastConnected) {
     Serial.println();
     client.stop();
  // if you're not connected, and ten seconds have passed since
   // your last connection, then connect again and send data:
   if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
     sendData(sensorReading);
   // store the state of the connection for next time through
   // the loop:
   lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void sendData(int thisData) {
   // if there's a successful connection:
   if (client.connect(server, 80)) {
    // send the HTTP PUT request:
    client.print("POST /iems/default.aspx?");
    client.print("temp_sensor=");
    client.print(thisData);
    client.println(" HTTP/1.1");
    client.println("Host: 192.168.1.5");
    client.print("Content-Length: ");
    client.println(thisData.length());
    // last pieces of the HTTP PUT request:
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.println("Connection: close");
    client.println();
    // here's the actual content of the PUT request:
    client.println(thisData);
  else {
     // if you couldn't make a connection:
     Serial.println();
     client.stop();
    // note the time that the connection was made or attempted:
// This method calculates the number of digits in the
// sensor reading.  Since each digit of the ASCII decimal
// representation is a byte, the number of digits equals
// the number of bytes:
int getLength(int someValue) {
   // there's at least one byte:
   int digits = 1;
   // continually divide the value by ten,
  // adding one to the digit count for each
   // time you divide, until you're at 0:
   int dividend = someValue /10;
   while (dividend > 0) {
     dividend = dividend /10;
     digits++;
   // return the number of digits:
   return digits;
串口监视一直提示:connection failed       disconnecting
能帮忙分析一下原因吗?192.168.1.5是一个asp.net网站,获取的数据上传asp.net网站的页面显示
发表于 2012-11-4 10:39:16 | 显示全部楼层
会asp.net,想必也会C#或者VB.net了,你可以这样的:
1.写一个窗口程序,通过串口读取arduino的温度值,然后写入一个xml文件
2.做asp.net网站,读取前面的xml文件,解析后写入页面。。。
 楼主| 发表于 2012-11-6 22:58:31 | 显示全部楼层
可以通过arduino的Ethernet模块先将数据传送到Mysql数据库吗?我不想数据走串口,直接走网络传送,有解决的办法吗?
发表于 2015-8-11 16:15:18 | 显示全部楼层
有同样的问题求解,php一点不懂
发表于 2015-12-28 15:23:09 | 显示全部楼层
有同样的问题求解,php一点不懂可以通过arduino的Ethernet模块先将数据传送到Mysql数据库吗?我不想数据走串口,直接走网络传送,有解决的办法吗?
GMT+8, 2026-6-16 04:30 , Processed in 0.068930 second(s), 22 queries .
