查看: 12434|回复: 0
红外遥控器控制RGB切换颜色失效
发表于 2015-9-23 12:25:00 | 显示全部楼层 |阅读模式
弄了一个RGB灯,用红外遥控器来切换灯的效果,结果发现红外遥控器只有首次有用,后续再按键的时候就没有用了,相当于是遥控器失效了,为啥?求大神指正,如果把灯显示的时间调的够小,刚好完成一个等的显示时按下按键是可以切换状态的,遇上这种情况怎么处理?
#include <IRremote.h>
#include <Adafruit_NeoPixel.h>
#define PIN 13          //RGB灯引脚
int RECV_PIN = 2;             //定义红外接收引脚为2号引脚
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn();
  strip.begin();
  strip.show();
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
//  for(uint16_t i=0; i<20; i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);      //延时
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
          strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
        strip.show();
        delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
    if(irrecv.decode(&results))
       irrecv.resume();            //接收下一个编码
        switch(results.value)
            case 0XFFA25D: colorWipe(strip.Color(5, 0, 0), 100);break;          //按下A键,
            case 0XFF629D: colorWipe(strip.Color(0, 5, 0), 100);break;          //按下B键,
            case 0XFFE21D: colorWipe(strip.Color(0, 0, 5), 100);break;            //按下C键,
            case 0XFFC23D: colorWipe(strip.Color(0, 0, 0), 100);break;             //按下E键,
            case 0XFFA857: rainbowCycle(20);break;            //按下四个箭头中间的键,
GMT+8, 2026-6-15 16:05 , Processed in 0.032163 second(s), 17 queries .
