Arduino GPS System 2010-09-05
A fully functional GPS receiver with the ability to display the current location, heading, speed, average speed and maximum speed, the distance traveled, the bearing, distance and ETA to a way-point or coordinates, and the date and time.
原贴 http://www.seancarney.ca/projects/arduino-gps-receiver/arduino-gps-system#.Vho9wVKheM9
程序编译通过,界面正常,只是收不到GPS信号,哪位大仙能验证一下。
// GPS SYSTEM
/* Keys
/ 1
/ 4 3 0
/ 2
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <LiquidCrystal.h>
#include <EEPROM.h>
#include <math.h>
union bitFloat {
float float_num;
char byte[4];
byte upArrow[8] = {
B00100,
B01110,
B10101,
B00100,
B00100,
B00100,
B00100,
B00000
byte downArrow[8] = {
B00100,
B00100,
B00100,
B00100,
B10101,
B01110,
B00100,
B00000
byte degree[8] = {
B01100,
B10010,
B10010,
B01100,
B00000,
B00000,
B00000,
B00000
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int adcKeyIn;
int NUM_KEYS = 5;
int key=-1;
int oldKey=-1;
int adcKeyVal[5] ={
30, 150, 360, 535, 760 };
// Options
boolean useCurrentSpeed = 0;
boolean useDirections = 0;
boolean useAbsoluteHeadings = 0;
byte timeZone = 0;
TinyGPS gps;
SoftwareSerial nss(3, 2);// RX, TX
// Maximum speed and last known position
float maxSpeed = 0;
float lastFlat = 0;
float lastFlon = 0;
// Default location to navigate from
float targetFlat = 49.88622;
float targetFlon = -97.15256;
// Current waypoint selected
byte waypoint = 1;
// To track time elasped for average speed calculation
byte startHour = 0;
byte startMinute = 0;
byte startSecond = 0;
// Default menu choice
byte screen = 0;
boolean started = 1;
long distance = 0;
const int DEBOUNCE_DELAY = 50;
byte screenRefresh = 120;
void gpsdump(TinyGPS &gps);
bool feedgps();
void printFloat(double f, int digits = 2);
Serial.begin(57600);
nss.begin(4800);
pinMode(13, OUTPUT); //we'll use the debug LED to output a heartbeat
lcd.createChar(0, upArrow);
lcd.createChar(1, downArrow);
lcd.createChar(2, degree);
lcd.begin(16, 2);
showSplash();
// Load settings
useCurrentSpeed = (boolean)EEPROM.read(0);
useDirections = (boolean)EEPROM.read(1);
useAbsoluteHeadings = (boolean)EEPROM.read(2);
timeZone = EEPROM.read(3);
showMenu();
bool newdata = false;
unsigned long start = millis();
// Every 5 seconds we print an update
while (millis() - start < 100)
if (feedgps())
newdata = true;
if (checkKeyDebounce() == 4)
showNavigationMenu();
if (newdata)
Serial.println("Acquired Data");
Serial.println("-------------");
gpsdump(gps);
Serial.println();
else {
Serial.println("No data");
int checkKeyDebounce() {
adcKeyIn = analogRead(0); // read the value from the
key = getKey(adcKeyIn); // convert into key press
if (key != oldKey) { // if keypress is detected
delay(50); // wait for debounce time
adcKeyIn = analogRead(0); //read the value from the sensor
oldKey = key;
if (key >=0) {
return key;
return -1;
return -1;
return -1;
int getKeyDebounce() {
// wait for no keypress, then return keypress held for debounce period
adcKeyIn = analogRead(0); // read the value from the sensor
do {
key = getKey(analogRead(0));
while (key != -1);
oldKey = key;
while (oldKey == -1 || key == -1 || key != oldKey) {
oldKey = key;
delay(DEBOUNCE_DELAY);
return key;
// Convert ADC value to key number
int getKey(unsigned int input)
int k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adcKeyVal[k])
return k;
if (k >= NUM_KEYS)
k = -1; // No valid key pressed
return k;
void printLCDFloat(double number, int digits)
// Handle negative numbers
if (number < 0.0)
lcd.print("-");
number = -number;
// Round correctly so that print(1.999, 2) prints as "2.00"
double rounding = 0.5;
for (uint8_t i=0; i<digits; ++i)
rounding /= 10.0;
number += rounding;
// Extract the integer part of the number and print it
unsigned long int_part = (unsigned long)number;
double remainder = number - (double)int_part;
char sTemp[10];
ltoa(int_part, sTemp, 10);
lcd.print(sTemp);
// Print the decimal point, but only if there are digits beyond
if (digits > 0)
lcd.print(".");
// Extract digits from the remainder one at a time
while (digits-- > 0)
remainder *= 10.0;
int toPrint = int(remainder);
ltoa(toPrint, sTemp, 10);
lcd.print(sTemp);
remainder -= toPrint;
void printFloat(double number, int digits)
if (number < 0.0)
Serial.print('-');
number = -number;
rounding /= 10.0;
number += rounding;
Serial.print(int_part);
if (digits > 0)
Serial.print(".");
remainder *= 10.0;
Serial.print(toPrint);
if (screenRefresh == 120)
lcd.clear();
screenRefresh = 0;
screenRefresh++;
float flat, flon;
unsigned long age;
int year;
byte month, day, hour, minute, second, hundredths;
feedgps(); // If we don't feed the gps during this long routine, we may drop characters and get checksum errors
gps.f_get_position(&flat, &flon, &age);
Serial.print("Lat/Long(float): ");
printFloat(flat, 5);
Serial.print(", ");
printFloat(flon, 5);
Serial.print(" Fix age: ");
Serial.print(age);
Serial.println("ms.");
feedgps();
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
Serial.print("Date: ");
Serial.print(static_cast<int>(month));
Serial.print("/");
Serial.print(static_cast<int>(day));
Serial.print("/");
Serial.print(year);
Serial.print(" Time: ");
Serial.print(static_cast<int>(hour));
Serial.print(":");
Serial.print(static_cast<int>(minute));
Serial.print(":");
Serial.print(static_cast<int>(second));
Serial.print(".");
Serial.print(static_cast<int>(hundredths));
Serial.print(age);
feedgps();
Serial.print("Alt(cm): ");
Serial.print(gps.altitude());
Serial.print(" Course(10^-2 deg): ");
Serial.print(gps.course());
Serial.print(" Speed(10^-2 knots): ");
Serial.println(gps.speed());
Serial.print("Alt(float): ");
printFloat(gps.f_altitude());
Serial.print(" Course(float): ");
printFloat(gps.f_course());
Serial.println();
Serial.print("Speed(knots): ");
printFloat(gps.f_speed_knots());
Serial.print(" (mph): ");
printFloat(gps.f_speed_mph());
Serial.print(" (mps): ");
printFloat(gps.f_speed_mps());
Serial.print(" (kmph): ");
printFloat(gps.f_speed_kmph());
Serial.println();
if (started == 1)
startHour = hour;
startMinute = minute;
startSecond = second;
float hours = (hour - startHour) + (((minute) - static_cast<float>(startMinute)) / 60) + (((second) - static_cast<float>(startSecond)) / 60 / 60);
if ((gps.f_speed_kmph() > maxSpeed) && (gps.f_speed_kmph() < 1000)) // check for fastest speed and limit to 999 kmph
maxSpeed = gps.f_speed_kmph();
if (gps.f_speed_kmph() > 3.9)
if (started == 1)
started = 0;
lastFlat = flat;
lastFlon = flon;
distance = distance + calc_dist(flat, flon, lastFlat, lastFlon);
lastFlat = flat;
lastFlon = flon;
if (age > 30000)
lcd.clear();
lcd.setCursor(4, 0);
lcd.print("WARNING!");
lcd.setCursor(0, 1);
lcd.print("Fix Age: ");
printLCDFloat(age/1000, 0);
lcd.print(" s");
delay(3000);
lcd.clear();
if (screen == 0) // Latitude longitude speed and heading
lcd.setCursor(0, 0);
printLCDFloat(flat, 5);
lcd.print(" ");
printLCDFloat(flon, 5);
lcd.print(" ");
lcd.setCursor(12, 1);
if (useDirections == 0) {
if (gps.f_course()<100)
lcd.print(" ");
if (gps.f_course()<10)
lcd.print(" ");
printLCDFloat(gps.f_course(), 0);
lcd.write(2);
else {
lcd.print(" ");
printHeadingDirection(gps.f_course());
lcd.setCursor(10, 0);
if (gps.f_speed_kmph()<99.5)
lcd.print(" ");
if (gps.f_speed_kmph()<9.5)
lcd.print(" ");
printLCDFloat(gps.f_speed_kmph(), 0);
lcd.print("kmh");
if (screen == 1) // Distance, Average speed and maximum speed
lcd.print("Dist ");
float fDist = distance;
fDist /= 1000;
float avgSpeed = 0;
if (hours != 0)
avgSpeed = fDist / hours;
printLCDFloat(fDist, 3);
lcd.print("km");
lcd.print("Av/Mx ");
printLCDFloat(avgSpeed, 0);
lcd.print("/");
printLCDFloat(maxSpeed, 0);
lcd.print("kmh");
if ((screen == 2)||(screen == 3)) // Navigate to Coordinates
lcd.setCursor(0,0);
lcd.print("Go ");
float fDist = (double)calc_dist(flat, flon, targetFlat, targetFlon) / 1000;
float avgSpeed = 0;
float fDist2 = distance;
fDist2 /= 1000;
if (hours != 0)
avgSpeed = fDist2 / hours;
lcd.print("km");
if (useAbsoluteHeadings == 1) {
if (calc_bearing(flat, flon, targetFlat, targetFlon) < 99.5)
lcd.print(" ");
if (calc_bearing(flat, flon, targetFlat, targetFlon) < 9.5)
lcd.print(" ");
printLCDFloat(calc_bearing(flat, flon, targetFlat, targetFlon), 0);
lcd.write(2);
lcd.print(" T");
else {
if ((calc_bearing(flat, flon, targetFlat, targetFlon) - gps.f_course()) > 0) {
if (calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course() < 99.5)
lcd.print(" ");
if (calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course() < 9.5)
lcd.print(" ");
printLCDFloat(calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course(), 0);
lcd.write(2);
lcd.print(" R");
else {
if (calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course()+360 < 99.5)
lcd.print(" ");
if (calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course()+360 < 9.5)
lcd.print(" ");
printLCDFloat(calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course()+360, 0);
lcd.write(2);
lcd.print(" R");
lcd.print(" ");
else {
printHeadingDirection(calc_bearing(flat, flon, targetFlat, targetFlon));
lcd.print(" T");
else {
printHeadingDirection(calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course());
lcd.print(" R");
else {
printHeadingDirection(calc_bearing(flat, flon, targetFlat, targetFlon)-gps.f_course()+360);
lcd.print(" R");
lcd.setCursor(8, 1);
long ETA = 0;
if (useCurrentSpeed == 1)
if (gps.f_speed_kmph() != 0)
ETA = (fDist/gps.f_speed_kmph())*60*60;
if (avgSpeed != 0)
ETA = ((double)fDist/(double)avgSpeed)*60*60;
if (ETA/60/60 < 10)
lcd.print("0");
if (ETA/60/60 < 100) // limit display to 99 hours
printLCDFloat((ETA/60/60)%100, 0);
int ETAHours = ETA/60/60;
lcd.print(":");
if ((ETA/60-(ETAHours*60) < 10))
lcd.print("0");
printLCDFloat((ETA/60-(ETAHours*60)), 0);
int ETAMinutes = (ETA/60);
lcd.print(":");
if ((ETA-(ETAMinutes*60) < 10))
lcd.print("0");
printLCDFloat((ETA-(ETAMinutes*60)), 0);
if (screen == 5) // Date and Time
int timeIZone;
if (timeZone <= 12)
timeIZone = (int)timeZone;
timeIZone = ((int)timeZone - 12) * - 1;
int ihour = (int)hour + timeIZone;
if (ihour > 23) {
ihour = ihour - 24;
day = day - 1;
if (ihour < 0) {
ihour = ihour + 24;
day = day - 1;
lcd.print("Date ");
printLCDFloat(year, 0);
lcd.print("/");
if (month < 10)
lcd.print("0");
printLCDFloat(month, 0);
lcd.print("/");
if (day < 10)
lcd.print("0");
printLCDFloat(day, 0);
lcd.print("Time ");
if (ihour < 10)
lcd.print("0");
printLCDFloat(ihour, 0);
lcd.print(":");
if (minute < 10)
lcd.print("0");
printLCDFloat(minute, 0);
lcd.print(":");
if (second < 10)
lcd.print("0");
printLCDFloat(second, 0);
if (age > 30000)
delay(3000);
void showNavigationMenu() {
boolean inMenu = 0;
byte lastOption = 1;
byte option = 0;
while (inMenu == 0) {
if ((option == 0)&&(lastOption != 0))
lcd.clear();
lcd.print(" Mark as");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" waypoint");
lastOption = 0;
if ((option == 1)&&(lastOption != 1))
lcd.clear();
lcd.write(0.0);
lcd.print(" Return to");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" main menu");
lastOption = 1;
if ((option == 2)&&(lastOption != 2))
lcd.clear();
lcd.write(0.0);
lcd.print(" Cancel");
lastOption = 2;
switch (getKeyDebounce())
case 1:
if (option != 0)
option--;
case 2:
if (option != 2)
option++;
case 4:
if (option == 1) {
showMenu(); }
else if (screen == 0) {
selectWaypoint();
saveWaypoint(lastFlat, lastFlon);
editWaypointName();
lcd.clear(); }
inMenu = 1;
void showMenu() {
boolean inMenu = 0;
// lcd.clear();
// lcd.print("Please select");
// lcd.setCursor(5, 1);
// lcd.print("mode");
// delay(2000);
while (inMenu == 0)
// Main menu
if (screen == 0) // Coordinates heading, speed
lcd.clear();
lcd.print(" Coordinates,");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" heading, speed");
if (screen == 1) // Distance avg/max speed
lcd.clear();
lcd.write(0.0);
lcd.print(" Distance,");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" avg/max speed");
if (screen == 2) // Navigate to coordinates
lcd.clear();
lcd.write(0.0);
lcd.print(" Navigate to");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" coordinates");
if (screen == 3) // Navigate to waypoint
lcd.clear();
lcd.write(0.0);
lcd.setCursor(0,1);
lcd.write(1);
if (screen == 4) // View & edit waypoints
lcd.clear();
lcd.write(0.0);
lcd.print(" View & edit");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" waypoints");
if (screen == 5) // Date & time
lcd.clear();
lcd.write(0.0);
lcd.print(" Date & time");
lcd.setCursor(0,1);
lcd.write(1);
if (screen == 6) // Options
lcd.clear();
lcd.write(0.0);
lcd.print(" Options");
// Options menu
if (screen == 10) // Current vs average speed to get ETA
lcd.clear();
lcd.print(" Current speed");
lcd.print(" Average speed");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" to get ETA");
if (screen == 11) // Show headings as number vs letters
lcd.clear();
lcd.write(0.0);
lcd.print(" Show headings");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" as 353");
lcd.write(2);
lcd.print(" as NNW");
if (screen == 12) // Show headings as absolute vs relative
lcd.clear();
lcd.write(0.0);
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" as absolute");
lcd.print(" as relative");
if (screen == 13) // Set time zone
lcd.clear();
lcd.write(0.0);
lcd.print(" Time zone");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" GMT ");
int timeIZone;
if (timeZone <= 12)
printLCDFloat(timeIZone, 0);
if (screen == 15)
lcd.clear();
lcd.write(0.0);
lcd.print(" Delete all");
lcd.setCursor(0,1);
lcd.write(1);
if (screen == 14)
lcd.clear();
lcd.write(0.0);
lcd.print(" Backup");
lcd.setCursor(0,1);
lcd.write(1);
if (screen == 16)
lcd.clear();
lcd.write(0.0);
lcd.setCursor(0,1);
// Reset menu
if (screen == 20)
lcd.clear();
lcd.print(" Are you sure?");
lcd.setCursor(0,1);
lcd.write(1);
lcd.print(" No!");
if (screen == 21)
lcd.clear();
lcd.write(0.0);
lcd.setCursor(0,1);
lcd.print(" Yes!");
case 1:
if ((screen != 0)&&(screen != 10)&&(screen != 20))
screen--;
case 2:
if ((screen != 6)&&(screen != 16)&&(screen != 21))
screen++;
case 4:
// Main menu
setTargetCoords();
inMenu = 1;
else if (screen == 3) // Navigate to waypoint
selectWaypoint();
printTargetCoords();
delay(2000);
inMenu = 1;
else if (screen == 4) // View & edit waypoints
selectWaypoint();
editWaypointName();
setTargetCoords();
saveWaypoint(targetFlat, targetFlon);
else if (screen == 6) // Options
screen = 10;
// Options menu
else if (screen == 14) // Backup
saveEEPROM();
else if (screen == 15) // Reset menu
screen = 20;
else if (screen == 16) // Exit options menu
screen = 6;
// Reset menu
else if (screen == 20) // Exit reset menu
screen = 15;
else if (screen == 21) // Reset device
clearEEPROM();
screen = 15;
else if ((screen == 0)||(screen == 1)||(screen == 2)||(screen == 3)||(screen == 5)) // Enter the main loop
inMenu = 1;
case 0:
// Options menu
if (screen == 10) {
if (useCurrentSpeed == 0)
useCurrentSpeed = 1;
EEPROM.write(0,(byte)useCurrentSpeed);
if (screen == 11) {
useDirections = 1;
useDirections = 0;
EEPROM.write(1,(byte)useDirections);
if (screen == 12) {
if (useAbsoluteHeadings == 0)
useAbsoluteHeadings = 1;
EEPROM.write(2,(byte)useAbsoluteHeadings);
if (screen == 13) {
timeZone = timeZone + 1;
if (timeZone == 25)
timeZone = 0;
EEPROM.write(3,(byte)timeZone);
case 3:
// Options menu
if (screen == 10) {
if (screen == 11) {
useDirections = 1;
useDirections = 0;
if (screen == 12) {
if (screen == 13) {
timeZone = timeZone - 1;
if (timeZone == 255) // This is a byte so negative values will wrap back to 255
timeZone = 24;
lcd.clear();
lcd.print("Acquiring");
lcd.print("signal...");
void selectWaypoint() {
lcd.clear();
lcd.print("Select a");
lcd.print("waypoint...");
delay(2000);
boolean inMenu = 0;
lcd.clear();
if (waypoint != 1)
lcd.write(0.0);
lcd.print(" ");
lcd.print(" Waypoint #");
printLCDFloat(waypoint, 0);
if (waypoint != 20)
lcd.write(1);
lcd.print(" ");
lcd.print(" ");
for (int i = 0; i < 14; i++)
lcd.print((char)EEPROM.read((waypoint * 22) + 8 + i));
case 1:
if (waypoint != 1)
waypoint--;
case 2:
if (waypoint != 20)
waypoint++;
case 4:
inMenu = 1;
bitFloat loadFloat;
loadFloat.byte[0] = EEPROM.read((22 * waypoint) + 0);
loadFloat.byte[1] = EEPROM.read((22 * waypoint) + 1);
loadFloat.byte[2] = EEPROM.read((22 * waypoint) + 2);
loadFloat.byte[3] = EEPROM.read((22 * waypoint) + 3);
targetFlat = loadFloat.float_num;
loadFloat.byte[0] = EEPROM.read((22 * waypoint) + 4);
loadFloat.byte[1] = EEPROM.read((22 * waypoint) + 5);
loadFloat.byte[2] = EEPROM.read((22 * waypoint) + 6);
loadFloat.byte[3] = EEPROM.read((22 * waypoint) + 7);
targetFlon = loadFloat.float_num;
void saveWaypoint(float saveLat, float saveLon) {
bitFloat saveFloat;
saveFloat.float_num = saveLat;
EEPROM.write((22 * waypoint) + 0, saveFloat.byte[0]);
EEPROM.write((22 * waypoint) + 1, saveFloat.byte[1]);
EEPROM.write((22 * waypoint) + 2, saveFloat.byte[2]);
EEPROM.write((22 * waypoint) + 3, saveFloat.byte[3]);
saveFloat.float_num = saveLon;
EEPROM.write((22 * waypoint) + 4, saveFloat.byte[0]);
EEPROM.write((22 * waypoint) + 5, saveFloat.byte[1]);
EEPROM.write((22 * waypoint) + 6, saveFloat.byte[2]);
EEPROM.write((22 * waypoint) + 7, saveFloat.byte[3]);
void editWaypointName() {
byte cursorPosition = 1;
lcd.blink();
boolean updated = 1;
boolean inMenu = 0;
while (inMenu == 0)
lcd.clear();
lcd.print("Waypoint name:");
lcd.setCursor(0,1);
for (int i = 0; i < 14; i++) {
char printLetter;
printLetter = EEPROM.read(((waypoint * 22) + 8 + i));
lcd.print(printLetter);
switch (cursorPosition)
case 1:
case 2:
lcd.setCursor(1,1);
case 3:
lcd.setCursor(2,1);
case 4:
lcd.setCursor(3,1);
case 5:
lcd.setCursor(4,1);
case 6:
lcd.setCursor(5,1);
case 7:
lcd.setCursor(6,1);
case 8:
lcd.setCursor(7,1);
case 9:
lcd.setCursor(8,1);
case 10:
lcd.setCursor(9,1);
case 11:
lcd.setCursor(10,1);
case 12:
lcd.setCursor(11,1);
case 13:
lcd.setCursor(12,1);
case 14:
lcd.setCursor(13,1);
case 1: {
byte letter = EEPROM.read((waypoint * 22) + 7 + cursorPosition);
letter++;
if (letter >= 91)
letter = 48;
if (letter == 33)
letter = 65;
if (letter == 58)
letter = 32;
EEPROM.write((waypoint * 22) + 7 + cursorPosition, letter);
break; }
case 2: {
letter--;
if (letter == 64)
letter = 32;
if (letter == 47)
letter = 90;
if (letter <= 31)
letter = 57;
break; }
case 0: {
cursorPosition++;
if (cursorPosition > 14)
cursorPosition = 1;
break; }
case 3: {
cursorPosition--;
if (cursorPosition < 0)
cursorPosition = 14;
break; }
case 4: {
inMenu = 1;
lcd.noBlink();
break; }
void printTargetCoords() {
lcd.clear();
if (targetFlat > 0)
lcd.print("(N) + ");
if (targetFlat < 10)
lcd.print("0");
printLCDFloat(targetFlat, 5);
lcd.print("(S) - ");
if (targetFlat > -10)
lcd.print("0");
printLCDFloat(targetFlat*-1, 5);
lcd.setCursor(0,1);
if (targetFlon > 0)
lcd.print("(E) +");
if (targetFlon < 100)
lcd.print("0");
if (targetFlon < 10)
lcd.print("0");
printLCDFloat(targetFlon, 5);
lcd.print("(W) -");
if (targetFlon > -100)
lcd.print("0");
if (targetFlon > -10)
lcd.print("0");
printLCDFloat(targetFlon*-1, 5);
void setTargetCoords() {
boolean inMenu = 0;
lcd.clear();
lcd.print("Please enter");
lcd.print("coordinates");
delay(2000);
lcd.blink();
while (inMenu == 0)
if (updated == 1)
case 1:
lcd.setCursor(1, 0);
case 2:
lcd.setCursor(4,0);
case 3:
lcd.setCursor(6,0);
case 4:
lcd.setCursor(7,0);
case 5:
lcd.setCursor(9,0);
case 6:
lcd.setCursor(10,0);
case 7:
lcd.setCursor(11,0);
case 8:
lcd.setCursor(12,0);
case 9:
lcd.setCursor(13,0);
case 10:
lcd.setCursor(1,1);
case 11:
lcd.setCursor(4,1);
case 12:
lcd.setCursor(5,1);
case 13:
lcd.setCursor(6,1);
case 14:
lcd.setCursor(7,1);
case 15:
lcd.setCursor(9,1);
case 16:
case 17:
case 18:
case 19:
updated = 0;
case 0:
cursorPosition++;
if (cursorPosition == 20)
cursorPosition = 1;
updated = 1;
case 3:
cursorPosition--;
if (cursorPosition == 0)
cursorPosition = 19;
updated = 1;
case 1:
case 1:
targetFlat *= -1;
case 2:
targetFlat *= -1;
case 3:
targetFlat += 10;
case 4:
targetFlat += 1;
case 5:
targetFlat += .1;
case 6:
targetFlat += .01;
case 7:
targetFlat += .001;
case 8:
targetFlat += .0001;
case 9:
targetFlat += .00001;
case 10:
targetFlon *= -1;
case 11:
targetFlon *= -1;
case 12:
targetFlon += 100;
case 13:
targetFlon += 10;
case 14:
targetFlon += 1;
case 15:
targetFlon += .1;
case 16:
targetFlon += .01;
case 17:
targetFlon += .001;
case 18:
targetFlon += .0001;
case 19:
targetFlon += .00001;
updated = 1;
case 2:
case 1:
targetFlat *= -1;
case 2:
targetFlat *= -1;
case 3:
targetFlat -= 10;
case 4:
targetFlat -= 1;
case 5:
targetFlat -= .1;
case 6:
targetFlat -= .01;
case 7:
targetFlat -= .001;
case 8:
targetFlat -= .0001;
case 9:
targetFlat -= .00001;
case 10:
targetFlon *= -1;
case 11:
targetFlon *= -1;
case 12:
targetFlon -= 100;
case 13:
targetFlon -= 10;
case 14:
targetFlon -= 1;
case 15:
targetFlon -= .1;
case 16:
targetFlon -= .01;
case 17:
targetFlon -= .001;
case 18:
targetFlon -= .0001;
case 19:
targetFlon -= .00001;
updated = 1;
case 4:
inMenu = 1;
lcd.noBlink();
printFloat(targetFlat,5);
printFloat(targetFlon,5);
void showSplash() {
lcd.clear();
lcd.print("Arduino GPS");
lcd.print("Version 2.0");
delay(3000);
bool feedgps()
while (nss.available())
if (gps.encode(nss.read()))
return true;
return false;
void printHeadingDirection(float heading) {
if ((heading > 348.75)||(heading < 11.25))
lcd.print(" N");
if ((heading >= 11.25)&&(heading < 33.75))
lcd.print("NNE");
if ((heading >= 33.75)&&(heading < 56.25))
lcd.print(" NE");
if ((heading >= 56.25)&&(heading < 78.75))
lcd.print("ENE");
if ((heading >= 78.75)&&(heading < 101.25))
lcd.print(" E");
if ((heading >= 101.25)&&(heading < 123.75))
lcd.print("ESE");
if ((heading >= 123.75)&&(heading < 146.25))
lcd.print(" SE");
if ((heading >= 146.25)&&(heading < 168.75))
lcd.print("SSE");
if ((heading >= 168.75)&&(heading < 191.25))
lcd.print(" S");
if ((heading >= 191.25)&&(heading < 213.75))
lcd.print("SSW");
if ((heading >= 213.75)&&(heading < 236.25))
lcd.print(" SW");
if ((heading >= 236.25)&&(heading < 258.75))
lcd.print("WSW");
if ((heading >= 258.75)&&(heading < 281.25))
lcd.print(" W");
if ((heading >= 281.25)&&(heading < 303.75))
lcd.print("WNW");
if ((heading >= 303.75)&&(heading < 326.25))
lcd.print(" NW");
if ((heading >= 326.25)&&(heading < 348.75))
lcd.print("NWN");
int calc_bearing(float flat1, float flon1, float flat2, float flon2)
float calc;
float bear_calc;
float x = 69.1 * (flat2 - flat1);
float y = 69.1 * (flon2 - flon1) * cos(flat1/57.3);
calc=atan2(y,x);
bear_calc= degrees(calc);
if(bear_calc<=1){
bear_calc=360+bear_calc;
return bear_calc;
unsigned long calc_dist(float flat1, float flon1, float flat2, float flon2)
float dist_calc=0;
float dist_calc2=0;
float diflat=0;
float diflon=0;
//I've to spplit all the calculation in several steps. If i try to do it in a single line the arduino will explode.
diflat=radians(flat2-flat1);
flat1=radians(flat1);
flat2=radians(flat2);
diflon=radians((flon2)-(flon1));
dist_calc = (sin(diflat/2.0)*sin(diflat/2.0));
dist_calc2= cos(flat1);
dist_calc2*=cos(flat2);
dist_calc2*=sin(diflon/2.0);
dist_calc +=dist_calc2;
dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
dist_calc*=6371000.0; //Converting to meters, i love the metric system.. =)
return dist_calc;
void clearEEPROM()
lcd.clear();
lcd.print("Formating EEPROM");
lcd.setCursor(2,1);
lcd.print("[");
lcd.print("]");
delay(2000);
bitFloat lat;
lat.float_num = 49.88622; //Default value for waypoints
bitFloat lon;
lon.float_num = -97.15256; //Default value for waypoints
for (int i = 1; i < 21; i++) {
EEPROM.write((22 * i) + 0, lat.byte[0]);
EEPROM.write((22 * i) + 1, lat.byte[1]);
EEPROM.write((22 * i) + 2, lat.byte[2]);
EEPROM.write((22 * i) + 3, lat.byte[3]);
EEPROM.write((22 * i) + 4, lon.byte[0]);
EEPROM.write((22 * i) + 5, lon.byte[1]);
EEPROM.write((22 * i) + 6, lon.byte[2]);
EEPROM.write((22 * i) + 7, lon.byte[3]);
for (int x = 1; x < 15; x++)
EEPROM.write((22 * i) + 7 + x, char(' '));
lcd.setCursor(((i+1)/2)+2,1);
lcd.print("-");
lcd.setCursor(6,1);
lcd.print("DONE");
delay(3000);
void saveEEPROM()
lcd.clear();
lcd.print("Start serial");
lcd.print("monitor @ 57600");
delay(5000);
lcd.clear();
lcd.setCursor(1,0);
lcd.print("Dumping EEPROM");
lcd.setCursor(2,1);
lcd.print("[");
lcd.print("]");
delay(2000);
Serial.println("#include <EEPROM.h>");
Serial.println("#include <LiquidCrystal.h>");
Serial.println("LiquidCrystal lcd(8, 9, 4, 5, 6, 7);");
Serial.println("void setup() {");
Serial.println("lcd.begin(16, 2);");
Serial.println("lcd.clear();");
Serial.println("lcd.setCursor(1,0);");
Serial.println("lcd.print(\"Loading EEPROM\");");
Serial.println("lcd.setCursor(2,1);");
Serial.println("lcd.print(\"[ BUSY ]\");");
for (int i = 0; i < 1024; i++)
Serial.print("EEPROM.write(");
Serial.print(i);
Serial.print(",");
Serial.print(int(EEPROM.read(i)));
Serial.println(");");
lcd.setCursor(((i)/103)+3,1);
lcd.print("-");
Serial.println("lcd.setCursor(6,1);");
Serial.println("lcd.print(\"DONE\");");
Serial.println("}");
Serial.println("void loop() {");
lcd.setCursor(6,1);
lcd.print("DONE");
delay(3000);
