查看: 7259|回复: 4
谁能仿照写好的光立方程序帮我写多点啊
发表于 2012-11-17 18:40:10 | 显示全部楼层 |阅读模式
本人小白一个,这是基于Arduino的光立方程序,希望有大神帮忙写点程序,感谢,QQ邮箱:[email protected]
 楼主| 发表于 2012-11-17 18:41:12 | 显示全部楼层
*  A3D8_master.ino
*        animation with the support of dot-matrix library
*        master animation sample on arduino managing 3D8S 8x8x8 led cubic display
*  The onboard arduino uno does both animation calc and led driving
*  Created on: 2012-7-11
*        Author: Weihong Guan
*        Blog: http://aguegu.net
*        E-mail: [email protected]
*        Code license: Attribution-NonCommercial-ShareAlike 3.0 Unported (CC BY-NC-SA 3.0)
*        http://creativecommons.org/licenses/by-nc-sa/3.0/
*        source host: https://github.com/aguegu/dot-matrix
#include "DotMatrix3D.h"
#include "Driver_3D8.h"
#define BYTE_LENGTH 64
DotMatrix3D dm(1);
Driver_3D8 cube(dm, 9, 10, 17, 8, 11, 5, 4, 3);
byte * cache;
uint8_t led_top = 6;
uint8_t led_bottom = 7;
const uint8_t PROGMEM PATTERN_LOVE[] =
{ 0x00, 0x81, 0x81, 0xFF, // I
                0x38, 0xFC, 0xFE, 0x3F, //heart
                0x00, 0xFF, 0xFF, 0x01, // U
const uint8_t PROGMEM PATTERN_ARROW[] =
{ 0x08, 0x14, 0x22, 0x77, 0x14, 0x14, 0x14, 0x14, 0x14, 0x1c, };
        pinMode(led_top, OUTPUT);
        pinMode(led_bottom, OUTPUT);
        digitalWrite(led_top, HIGH);
        digitalWrite(led_bottom, HIGH);
        TCCR2B = (TCCR2B & 0xf8) | 0x02;
        cache = new byte(BYTE_LENGTH);
        dm.clear(0x00);
        cube.setBrightness(0xff);
void animationFlash(word k)
        byte value = k & 0x01 ? 0xff : 0x00;
        dm.clear(value);
void animationBreathe(word k)
        k = k % 0x80;
        byte brightness = k < 0x40 ? 0xff - (k << 2) : (k << 2) - 0xff;
        cube.setBrightness(brightness);
void animationFacetScan(word k)
        byte value = _BV(k%8);
        dm.clear(value);
void animationBlockScan(word k)
        k = k % 8;
        byte value = _BV(k+1) - 1;
        dm.clear(value);
void animationFlowZPosi(word k)
        dm.setMoveDirection(DotMatrix3D::Z_POSI);
        dm.move(false);
        for (byte i = 0; i < random(4); i++)
                byte x = random(8);
                byte y = random(8);
                dm.setDot(x, y, 0);
void animationMoveSide(word k)
        if (k == 0)
                dm.clear(0x01);
        byte index;
        for (word i = dm.countBytes(); i;)
                i--;
                byte temp = dm.getByte(i) & 0x81;
                dm.setByte(i, ((dm.getByte(i) & 0x7e) << 1) | temp);
        if (bitRead(dm.orValue(),0) == true)
                do
                        index = random(64);
                } while (dm.getByte(index) != 0x01);
                dm.setByte(index, 0x02);
void animationMoveSideQuick(word k)
        k %= 16;
        if (k % 8 == 0)
                for (byte i = 0; i < BYTE_LENGTH; i++)
                        cache = _BV(random(8));
        if (k < 8)
                        byte temp = dm.getByte(i);
                        if (dm.getByte(i) < cache)
                                dm.setByte(i, temp << 1);
                        if (dm.getByte(i) < 0x80)
void animationWave2D(word k)
        k %= 16;
        byte value = k < 8 ? k : 15 - k;
        dm.setMoveDirection(DotMatrix3D::Y_POSI);
        dm.move(false);
        dm.setByte(value, 0xff);
void animationWave3D(word k)
        k %= 16;
        for (byte i = 0; i < 8; i++)
                cache = dm.getByte(i);
        dm.move(false);
                dm.setByte(i, cache);
        for (byte i = 7; i; i--)
                dm.setByte(i, dm.getByte(i - 1));
        dm.setByte(0x00, _BV(value));
void animationWaveShake(word k)
        k %= 16;
        dm.setMoveDirection(DotMatrix3D::X_POSI);
        dm.move(false);
        dm.setLine(0, value, 7, 7 - value);
void animationWaveRotate(word k)
        k %= 28;
        dm.move(false);
        byte temp = k % 7;
        cache[0] = 0;
        cache[1] = temp;
        cache[2] = 7;
        cache[3] = 7 - temp;
        byte i = k / 7;
        dm.setLine(cache[i % 4], cache[(i + 1) % 4], cache[(i + 2) % 4],
                        cache[(i + 3) % 4]);
void animationDance(word k)
        if (k == 0)
                cache[0] = 0;
                cache[1] = 0;
        char x = cache[0];
        char y = cache[1];
        dm.move();
        char vx = random(3) - 1;
        char vy = random(3) - 1;
        x += vx;
        y += vy;
        if (x >= 8 || x < 0)
                x -= vx + vx;
        if (y >= 8 || y < 0)
                y -= vy + vy;
        cache[0] = x;
        cache[1] = y;
        dm.setDot(x, y, 0);
void animationRotateArrow(word k)
        k %= 28;
        dm.rotate(0, false, false);
        if (k < 10)
                dm.setByte(0, pgm_read_byte_near(PATTERN_ARROW+k));
void animationRotateLove(word k)
        k %= 28 * 6;
        if (k % 56 == 0)
                for (byte i = 0; i < 4; i++)
                        byte value = DotMatrix::reverseByte(
                                        pgm_read_byte_near(PATTERN_LOVE+(k/56)*4+i));
                        dm.setByte(0x20 + i, value);
                        dm.setByte(0x27 - i, value);
                        dm.setByte(0x18 + i, value);
                        dm.setByte(0x1f - i, value);
        dm.rotateSync(true, true);
void callAnimation(void (*p)(word), word span, word times, byte init_value,
                Driver_3D8::ScanMode mode)
        static word frame_id = 0;
        cube.setMode(mode);
        dm.clear(init_value);
        while (times--)
                (*p)(frame_id++);
                cube.display(span);
        frame_id = 0;
void callAnimationInModes(void (*p)(word), word span, word times,
                byte init_value)
        for (byte i = 0; i < 3; i++)
                callAnimation(p, span, times, init_value, (Driver_3D8::ScanMode) i);
        callAnimation(animationFlash, 0x10, 0x08, 0x00, Driver_3D8::XYZ);
        callAnimation(animationBreathe, 0x01, 0xff * 2, 0xff, Driver_3D8::XYZ);
        callAnimationInModes(animationFacetScan, 0x08, 0x08, 0x00);
        callAnimationInModes(animationBlockScan, 0x08, 0x08, 0x00);
        callAnimationInModes(animationFlowZPosi, 0x04, 0x40, 0x00);
        callAnimationInModes(animationMoveSide, 0x04, 72, 0x00);
        callAnimationInModes(animationMoveSideQuick, 0x04, 0x10, 0x01);
        callAnimationInModes(animationWave2D, 0x04, 14 * 4, 0x00);
        callAnimation(animationWave3D, 0x02, 14 * 16, 0x00, Driver_3D8::ZXY);
        callAnimation(animationWaveShake, 0x02, 14 * 16, 0x00, Driver_3D8::XYZ);
        callAnimation(animationWaveRotate, 0x02, 14 * 8, 0x00, Driver_3D8::XYZ);
        callAnimation(animationWaveRotate, 0x02, 14 * 8, 0x00, Driver_3D8::YZX);
        callAnimation(animationDance, 0x02, 0x80, 0x00, Driver_3D8::ZXY);
        callAnimation(animationRotateArrow, 0x04, 28 * 3, 0x00, Driver_3D8::YZX);
        callAnimation(animationRotateArrow, 0x04, 28 * 3, 0x00, Driver_3D8::ZXY);
        callAnimation(animationRotateLove, 0x04, 28 * 6, 0x00, Driver_3D8::ZXY);
 楼主| 发表于 2012-11-17 18:45:11 | 显示全部楼层
8*8*8的光立方
发表于 2012-11-17 21:06:46 | 显示全部楼层
楼主,我也想做光立方,不知从何下手。。你从哪 弄的资料?
发表于 2015-3-17 12:13:03 | 显示全部楼层
同问楼i主,我也想要点资料
GMT+8, 2026-6-19 03:49 , Processed in 0.036223 second(s), 20 queries .
