查看: 11737|回复: 1
来个大神帮忙看看程序!!!!!
发表于 2015-11-26 15:51:18 | 显示全部楼层 |阅读模式
   #include <DallasTemperature.h>
   #include <OneWire.h>
   #define ONE_WIRE_BUS 9
   OneWire oneWire(ONE_WIRE_BUS);
   DallasTemperature sensors(&oneWire);
    unsigned char LED_0F[] =
    {// 0         1          2           3        4         5          6           7        8         9          A           b        C    d          E    F    -
            0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf
    unsigned char LED[4];        //用于LED的4位显示缓存
    int SCLK = 4;
    int RCLK = 3;
    int DIO = 2; //这里定义了那三个脚
    int a;
    int b;
    int c;
    int d;
    void setup ()
      pinMode(SCLK,OUTPUT);
      pinMode(RCLK,OUTPUT);
      pinMode(DIO,OUTPUT); //让三个脚都是输出状态
      Serial.println("Demo");
      sensors.begin();
      Temperatures();
      LED[3]=d;
            LED[2]=a;
            LED[1]=b;
            LED[0]=12;
      LED4_Display ();
      Serial.println("TEXT");
    void Temperatures()
      Serial.print("Requesting temperatures...");
      sensors.requestTemperatures();
      Serial.println("DONE");
      Serial.print("Temperature for the device 1(index 0) is:");
      Serial.println(sensors.getTempCByIndex(0));
      c=sensors.getTempCByIndex(0);
      a=c/10;
      b=c%10;
      if (c>=0)
        d=0;
        d=16;
    void LED4_Display ()
            unsigned char *led_table;          // 查表指针
            unsigned char i;
            //显示第1位
            led_table = LED_0F + LED[0];
            i = *led_table;
            LED_OUT(i);
      LED_OUT(0x01);
        digitalWrite(RCLK,LOW);
        digitalWrite(RCLK,HIGH);
        delay(500);
            //显示第2位
            led_table = LED_0F + LED[1];
            i = *led_table;
            LED_OUT(i);
      LED_OUT(0x02);
              delay(500);
            //显示第3位
            led_table = LED_0F + LED[2];
            i = *led_table;
            LED_OUT(i);
            LED_OUT(0x04);
              delay(500);
            //显示第4位
            led_table = LED_0F + LED[3];
            i = *led_table;
            LED_OUT(i);
            LED_OUT(0x08);
        delay(500);
    void LED_OUT(unsigned char X)
      unsigned char i;
      for(i=8;i>=1;i--)
        if (X&0x80)
                  digitalWrite(DIO,HIGH);
                  digitalWrite(DIO,LOW);
        X<<=1;
                digitalWrite(SCLK,LOW);
                digitalWrite(SCLK,HIGH);
这个4位数码管只能从右到左依次显示,不能4位同时显示,做了个温度计,不能一起显示看起来很累啊,试了修改void LED4_Display ()里的延迟函数不管用,改到最小就闪的更快了,什么也看不清,改大了能显示清楚就是一位一位的显示。求问大神怎么改这个程序?
发表于 2015-11-26 16:13:32 | 显示全部楼层
所谓显示四位,其实是一个个点亮,不断扫描显示的
这个是数码管显示的原理
GMT+8, 2026-7-24 11:13 , Processed in 0.109474 second(s), 19 queries .
