查看: 13929|回复: 0
rc522怎么写入卡号?
发表于 2015-12-11 18:25:38 | 显示全部楼层 |阅读模式
某宝买的可擦写的空白卡,我就试着给它换个卡号。
unsigned char writeDate[16] ={
  '9','0','F','D','1','0','1','4'};
writeCard(0);//然后往0块写入
最后失败了
这个程序就是RFID库里的测试程序改了这两个地方。
以下贴上测试程序
#include <SPI.h>
#include <RFID.h>
//D10 - 读卡器CS引脚、D5 - 读卡器RST引脚
RFID rfid(10,5);
//4字节卡序列号,第5字节为校验字节
unsigned char serNum[5];
unsigned char status;
unsigned char str[MAX_LEN];
unsigned char blockAddr;        //选择操作的块地址0~63
//写卡数据,想要写的数据(16个字节内)
  'W', 'e', 'l', 'c', 'o', 'm', 'e', ' ', 'Y', 'F', 'R', 'o', 'b', 'o', 't', 0};
//原扇区A密码,16个扇区,每个扇区密码6Byte
unsigned char sectorKeyA[16][16] = {
  {  0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF  } ,
  {  0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF  } ,};
  SPI.begin();
  rfid.init();
  //找卡
  rfid.findCard(PICC_REQIDL, str);
    //防冲突检测,读取卡序列号
    if (rfid.anticoll(str) == MI_OK){
      Serial.print("The card's number is  : ");
      //显示卡序列号
      for(int i = 0; i < 4; i++){
        Serial.print(0x0F & (str[i] >> 4),HEX);
        Serial.print(0x0F & str[i],HEX);
      Serial.println("");
      memcpy(rfid.serNum,str,5);
  //选卡,返回卡容量(锁定卡片,防止多次读写)
  rfid.selectTag(rfid.serNum);
  //向卡数据块中写数据(16字节内),这里以数据块4为例
  writeCard(4);
  //读数据块中数据,这里以数据块4为例
  readCard(4);
  rfid.halt();
//写数据卡
void writeCard(int blockAddr){
  if (rfid.auth(PICC_AUTHENT1A, blockAddr, sectorKeyA[blockAddr/4], rfid.serNum) == MI_OK)  //认证
    //写数据
    //status = rfid.write((blockAddr/4 + 3*(blockAddr/4+1)), sectorKeyA[0]);
    Serial.print("set the new card password, and can modify the data of the Sector: ");
    Serial.println(blockAddr/4,DEC);
    ////选择扇区中的块写数据
    if(rfid.write(blockAddr, writeDate) == MI_OK){
      Serial.println("Write card OK!");
//读卡
void readCard(int blockAddr){
  if ( rfid.auth(PICC_AUTHENT1A, blockAddr, sectorKeyA[blockAddr/4], rfid.serNum) == MI_OK)  //认证
    //选择扇区中的块读数据
    Serial.print("Read from the blockAddr of the card : ");
    Serial.println(blockAddr,DEC);
    if( rfid.read(blockAddr, str) == MI_OK){
      Serial.print("The data is : ");
      Serial.println((char *)str);
GMT+8, 2026-7-24 23:18 , Processed in 0.034024 second(s), 18 queries .
