查看: 4628|回复: 0
谁能帮我看懂这段代码
发表于 2015-12-25 20:49:08 | 显示全部楼层 |阅读模式
int permtonum(char* p){
        int n=0;
        for ( int a=0; a<4; a++) {
                n*=4-a;
                for( int b=a; ++b<4; )
                        if (p[b]<p[a]) n++;
        return n;
// convert number in range 0..23 to permutation of 4 chars.
void numtoperm(char* p,int n,int o){
        p+=o;
        p[3]=o;
        for (int a=3; a--;){
                p[a] = n%(4-a) +o;
                n/=4-a;
                for (int b=a; ++b<4; )
                        if ( p[b] >= p[a]) p[b]++;
// get index of cube position from table t
int getposition(int t){
        int i=-1,n=0;
        switch(t){
        // case 0 does nothing so returns 0
        case 1://edgeflip
                // 12 bits, set bit if edge is flipped
                for(;++i<12;) n+= ori[i]<<i;
        case 2://cornertwist
                // get base 3 number of 8 digits - each digit is corner twist
                for(i=20;--i>11;) n=n*3+ori[i];
        case 3://middle edge choice
                // 12 bits, set bit if edge belongs in Um middle slice
                for(;++i<12;) n+= (pos[i]&8)?(1<<i):0;
        case 4://ud slice choice
                // 8 bits, set bit if UD edge belongs in Fm middle slice
                for(;++i<8;) n+= (pos[i]&4)?(1<<i):0;
        case 5://tetrad choice, twist and parity
                int corn[8],j,k,l,corn2[4];
                // 8 bits, set bit if corner belongs in second tetrad.
                // also separate pieces for twist/parity determination
                k=j=0;
                for(;++i<8;)
                        if((l=pos[i+12]-12)&4){
                                corn[l]=k++;
                                n+=1<<i;
                        }else corn[j++]=l;
                //Find permutation of second tetrad after solving first
                for(i=0;i<4;i++) corn2[i]=corn[4+corn[i]];
                //Solve one piece of second tetrad
                for(;--i;) corn2[i]^=corn2[0];
                // encode parity/tetrad twist
                n=n*6+corn2[1]*2-2;
                if(corn2[3]<corn2[2])n++;
        case 6://two edge and one corner orbit, permutation
                n=permtonum(pos)*576+permtonum(pos+4)*24+permtonum(pos+12);
        case 7://one edge and one corner orbit, permutation
                n=permtonum(pos+8)*24+permtonum(pos+16);
        return n;
// sets cube to any position which has index n in table t
void setposition(int t, int n){
        int i=0,j=12,k=0;
        char *corn="QRSTQRTSQSRTQTRSQSTRQTSR";
        reset();
        switch(t){
        // case 0 does nothing so leaves cube solved
        case 1://edgeflip
                for(;i<12;i++,n>>=1) ori[i]=n&1;
                for(i=12;i<20;i++,n/=3) ori[i]=n%3;
                for(;i<12;i++,n>>=1) pos[i]= 8*n&8;
                for(;i<8;i++,n>>=1) pos[i]= 4*n&4;
        case 5://tetrad choice,parity,twist
                corn+=n%6*4;
                n/=6;
                for(;i<8;i++,n>>=1)
                        pos[i+12]= n&1 ? corn[k++]-CHAROFFSET : j++;
        case 6://slice permutations
                numtoperm(pos,n%24,12);n/=24;
                numtoperm(pos,n%24,4); n/=24;
                numtoperm(pos,n   ,0);
        case 7://corner permutations
                numtoperm(pos,n/24,8);
                numtoperm(pos,n%24,16);
GMT+8, 2026-7-27 21:12 , Processed in 0.059799 second(s), 18 queries .
