查看: 22413|回复: 2
使用arduino uno r3 将pulse sensor传感器测量脉搏 在1602LCD上显示数据
发表于 2016-1-3 18:21:54 | 显示全部楼层 |阅读模式
求各路大神帮我解决下问题
小ry 想使用arduino uno r3 将pulsesensor传感器测量脉搏 在1602LCD上显示数据
★ pulsesensor的官方程序 看不懂在哪里获取数据
★ arduino IDE1.6.7或1.6.6版本
★ 1602 LCD 用4线接arduino 有显示但 出现乱码(估计是程序出错),用8线接arduino板 只亮背光没有显示字符
PS:为了解决LCD占用arduino线口太多的窘况,     特意买了个IIC转接板
程序:
●pulsesensor 传感器
/*  Pulse Sensor Amped 1.4    by Joel Murphy and Yury Gitman   http://www.pulsesensor.com
----------------------  Notes ----------------------  ----------------------
This code:
1) Blinks an LED to User's Live Heartbeat   PIN 13
2) Fades an LED to User's Live HeartBeat
3) Determines BPM
4) Prints All of the Above to Serial
Read Me:
https://github.com/WorldFamousElectronics/PulseSensor_Amped_Arduino/blob/master/README.md
//  Variables
int pulsePin = 0;                 // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 13;                // pin to blink led at each beat
int fadePin = 5;                  // pin to do fancy classy fading blink at each beat
int fadeRate = 0;                 // used to fade LED on with PWM on fadePin
// Volatile Variables, used in the interrupt service routine!
volatile int BPM;                   // int that holds raw Analog in 0. updated every 2mS
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false;     // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
// Regards Serial OutPut  -- Set This Up to your needs
static boolean serialVisual = true;   // Set to 'false' by Default.  Re-set to 'true' to see Arduino Serial Monitor ASCII Visual Pulse
void setup(){
  pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
  pinMode(fadePin,OUTPUT);          // pin that will fade to your heartbeat!
  Serial.begin(115200);             // we agree to talk fast!
  interruptSetup();                 // sets up to read Pulse Sensor signal every 2mS
   // IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
   // UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
//   analogReference(EXTERNAL);
//  Where the Magic Happens
void loop(){
    serialOutput() ;
  if (QS == true){     // A Heartbeat Was Found
                       // BPM and IBI have been Determined
                       // Quantified Self "QS" true when arduino finds a heartbeat
        digitalWrite(blinkPin,HIGH);     // Blink LED, we got a beat.
        fadeRate = 255;         // Makes the LED Fade Effect Happen
                                // Set 'fadeRate' Variable to 255 to fade LED with pulse
        serialOutputWhenBeatHappens();   // A Beat Happened, Output that to serial.
        QS = false;                      // reset the Quantified Self flag for next time
  ledFadeToBeat();                      // Makes the LED Fade Effect Happen
  delay(20);                             //  take a break
void ledFadeToBeat(){
    fadeRate -= 15;                         //  set LED fade value
    fadeRate = constrain(fadeRate,0,255);   //  keep LED fade value from going into negative numbers!
    analogWrite(fadePin,fadeRate);          //  fade LED
/////////  All Serial Handling Code,
/////////  It's Changeable with the 'serialVisual' variable
/////////  Set it to 'true' or 'false' when it's declared at start of code.
void serialOutput(){   // Decide How To Output Serial.
if (serialVisual == true){
     arduinoSerialMonitorVisual('-', Signal);   // goes to function that makes Serial Monitor Visualizer
} else{
      sendDataToSerial('S', Signal);     // goes to sendDataToSerial function
//  Decides How To OutPut BPM and IBI Data
void serialOutputWhenBeatHappens(){
if (serialVisual == true){            //  Code to Make the Serial Monitor Visualizer Work
    Serial.print("*** Heart-Beat Happened *** ");  //ASCII Art Madness
    Serial.print("BPM: ");
    Serial.print(BPM);
    Serial.print("  ");
} else{
        sendDataToSerial('B',BPM);   // send heart rate with a 'B' prefix
        sendDataToSerial('Q',IBI);   // send time between beats with a 'Q' prefix
//  Sends Data to Pulse Sensor Processing App, Native Mac App, or Third-party Serial Readers.
void sendDataToSerial(char symbol, int data ){
    Serial.print(symbol);
    Serial.println(data);
void arduinoSerialMonitorVisual(char symbol, int data ){
  const int sensorMin = 0;      // sensor minimum, discovered through experiment
const int sensorMax = 1024;    // sensor maximum, discovered through experiment
  int sensorReading = data;
  // map the sensor range to a range of 12 options:
  int range = map(sensorReading, sensorMin, sensorMax, 0, 11);
  // do something different depending on the
  // range value:
  switch (range) {
  case 0:
    Serial.println("");     /////ASCII Art Madness
  case 1:
    Serial.println("---");
  case 2:
    Serial.println("------");
  case 3:
    Serial.println("---------");
  case 4:
    Serial.println("------------");
  case 5:
    Serial.println("--------------|-");
  case 6:
    Serial.println("--------------|---");
  case 7:
    Serial.println("--------------|-------");
  case 8:
    Serial.println("--------------|----------");
  case 9:
    Serial.println("--------------|----------------");
  case 10:
    Serial.println("--------------|-------------------");
  case 11:
    Serial.println("--------------|-----------------------");
volatile int rate[10];                    // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0;          // used to determine pulse timing
volatile unsigned long lastBeatTime = 0;           // used to find IBI
volatile int P =512;                      // used to find peak in pulse wave, seeded
volatile int T = 512;                     // used to find trough in pulse wave, seeded
volatile int thresh = 525;                // used to find instant moment of heart beat, seeded
volatile int amp = 100;                   // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false;      // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
  // Initializes Timer2 to throw an interrupt every 2mS.
  TCCR2A = 0x02;     // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
  TCCR2B = 0x06;     // DON'T FORCE COMPARE, 256 PRESCALER
  OCR2A = 0X7C;      // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
  TIMSK2 = 0x02;     // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
  sei();             // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
// THIS IS THE TIMER 2 INTERRUPT SERVICE ROUTINE.
// Timer 2 makes sure that we take a reading every 2 miliseconds
ISR(TIMER2_COMPA_vect){                         // triggered when Timer2 counts to 124
  cli();                                      // disable interrupts while we do this
  Signal = analogRead(pulsePin);              // read the Pulse Sensor
  sampleCounter += 2;                         // keep track of the time in mS with this variable
  int N = sampleCounter - lastBeatTime;       // monitor the time since the last beat to avoid noise
    //  find the peak and trough of the pulse wave
  if(Signal < thresh && N > (IBI/5)*3){       // avoid dichrotic noise by waiting 3/5 of last IBI
    if (Signal < T){                        // T is the trough
      T = Signal;                         // keep track of lowest point in pulse wave
  if(Signal > thresh && Signal > P){          // thresh condition helps avoid noise
    P = Signal;                             // P is the peak
  }                                        // keep track of highest point in pulse wave
  //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
  // signal surges up in value every time there is a pulse
  if (N > 250){                                   // avoid high frequency noise
    if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ){
      Pulse = true;                               // set the Pulse flag when we think there is a pulse
      digitalWrite(blinkPin,HIGH);                // turn on pin 13 LED
      IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
      lastBeatTime = sampleCounter;               // keep track of time for next pulse
      if(secondBeat){                        // if this is the second beat, if secondBeat == TRUE
        secondBeat = false;                  // clear secondBeat flag
        for(int i=0; i<=9; i++){             // seed the running total to get a realisitic BPM at startup
          rate = IBI;
      if(firstBeat){                         // if it's the first time we found a beat, if firstBeat == TRUE
        firstBeat = false;                   // clear firstBeat flag
        secondBeat = true;                   // set the second beat flag
        sei();                               // enable interrupts again
        return;                              // IBI value is unreliable so discard it
      // keep a running total of the last 10 IBI values
      word runningTotal = 0;                  // clear the runningTotal variable
      for(int i=0; i<=8; i++){                // shift data in the rate array
        rate = rate[i+1];                  // and drop the oldest IBI value
        runningTotal += rate;              // add up the 9 oldest IBI values
      rate[9] = IBI;                          // add the latest IBI to the rate array
      runningTotal += rate[9];                // add the latest IBI to runningTotal
      runningTotal /= 10;                     // average the last 10 IBI values
      BPM = 60000/runningTotal;               // how many beats can fit into a minute? that's BPM!
      QS = true;                              // set Quantified Self flag
      // QS FLAG IS NOT CLEARED INSIDE THIS ISR
  if (Signal < thresh && Pulse == true){   // when the values are going down, the beat is over
   digitalWrite(blinkPin,LOW);            // turn off pin 13 LED
    Pulse = false;                         // reset the Pulse flag so we can do it again
    amp = P - T;                           // get amplitude of the pulse wave
    thresh = amp/2 + T;                    // set thresh at 50% of the amplitude
    P = thresh;                            // reset these for next time
    T = thresh;
  if (N > 2500){                           // if 2.5 seconds go by without a beat
    thresh = 512;                          // set thresh default
    P = 512;                               // set P default
    T = 512;                               // set T default
    lastBeatTime = sampleCounter;          // bring the lastBeatTime up to date
    firstBeat = true;                      // set these to avoid noise
    secondBeat = false;                    // when we get the heartbeat back
  sei();                                   // enable interrupts when youre done!
}// end isr
1602 LCD:
int LCD1602_RS=12;
int LCD1602_RW=11;
int LCD1602_EN=10;
int DB[] = { 6, 7, 8, 9};
char str1[]="Welcome to";
char str2[]="geek-workshop";
char str3[]="this is the";
char str4[]="4-bit interface";
void LCD_Command_Write(int command)
int i,temp;
digitalWrite( LCD1602_RS,LOW);
digitalWrite( LCD1602_RW,LOW);
digitalWrite( LCD1602_EN,LOW);
temp=command & 0xf0;
for (i=DB[0]; i <= 9; i++)
   digitalWrite(i,temp & 0x80);
   temp <<= 1;
digitalWrite( LCD1602_EN,HIGH);
delayMicroseconds(1);
temp=(command & 0x0f)<<4;
   temp <<= 1;
void LCD_Data_Write(int dat)
int i=0,temp;
digitalWrite( LCD1602_RS,HIGH);
temp=dat & 0xf0;
   temp <<= 1;
temp=(dat & 0x0f)<<4;
   temp <<= 1;
void LCD_SET_XY( int x, int y )
  int address;
  if (y ==0)    address = 0x80 + x;
  else          address = 0xC0 + x;
  LCD_Command_Write(address);
void LCD_Write_Char( int x,int y,int dat)
  LCD_SET_XY( x, y );
  LCD_Data_Write(dat);
void LCD_Write_String(int X,int Y,char *s)
    LCD_SET_XY( X, Y );    //设置地址
    while (*s)             //写字符串
      LCD_Data_Write(*s);
      s ++;
void setup (void)
  int i = 0;
  for (i=6; i <= 12; i++)
     pinMode(i,OUTPUT);
  delay(100);
  LCD_Command_Write(0x28);//4线 2行 5x7
  delay(50);
  LCD_Command_Write(0x06);
  delay(50);
  LCD_Command_Write(0x0c);
  delay(50);
  LCD_Command_Write(0x80);
  delay(50);
  LCD_Command_Write(0x01);
  delay(50);
void loop (void)
   delay(50);
   LCD_Write_String(3,0,str1);//第1行,第4个地址起
   delay(50);
   LCD_Write_String(1,1,str2);//第2行,第2个地址起
   delay(5000);
   delay(50);
   LCD_Write_String(0,0,str3);
   delay(50);
   LCD_Write_String(0,1,str4);
   delay(5000);
发表于 2016-3-2 10:39:02 | 显示全部楼层
同求! 现在也购买了一块,找解决方案中,,接线方案?
发表于 2016-3-2 12:51:26 | 显示全部楼层
你先在控制台看数据对不对,然后再接液晶屏
GMT+8, 2026-7-26 09:47 , Processed in 0.037356 second(s), 21 queries .
