查看: 10979|回复: 1
如何改寫馬達的控制方式...?
发表于 2016-1-13 19:47:07 | 显示全部楼层 |阅读模式
各位好,我是剛接觸arduino約一年多的菜鳥,最近試著改寫機器人控制的程式,卻遇到不會的地方。
我想要在程式裡添加可以直接控制任一顆馬達的角度的case,但試過幾種寫法仍然沒辦法達到,該怎麼改才會對呢?
#include <Servo.h>
#define POWER 17     // Servo power supply control pin
#define SHIFT 7
#define TIME 15      // Column of Time
#define MAXSN 12     // Max Number of Servos
#define MAXMN 10     // Max Number of Motions
#define MAXFN 8      // Max Number of Frames
double startTime =   0;                // Motion start time(msec)
double endTime =     0;                // Motion end time(msec)
int remainingTime =  0;                // Motion remaining time(msec)
uint8_t bufferTime = 0;                // Motion buffer time (0.1sec)
uint8_t motionNumber = 0;
uint8_t frameNumber = 0;
char mode = 'M';
int i = 0;
int t = 1;
Servo servo[MAXSN];
int trim[MAXSN] = { 0,  // Head yaw
                    0,  // Waist yaw
                    0,  // R Sholder roll
                    0,  // R Sholder pitch
                    0,  // R Hand grip
                    0,  // L Sholder roll
                    0,  // L Sholder pitch
                    0,  // L Hand grip
                    0,  // R Foot yaw
                    0,  // R Foot pitch
                    0,  // L Foot yaw
                    0}; // L Foot pitch
int nowAngle[MAXSN] =        { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};  // Initialize array to 0
int targetAngle[MAXSN] =     { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};  // Initialize array to 0
int deltaAngle[MAXSN] =      { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};  // Initialize array to 0
uint8_t bufferAngle[MAXSN] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};  // Initialize array to 0
uint8_t tempAngle[MAXSN] =   { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
uint8_t motion[MAXMN][MAXFN][16]={
{  // 0 Stop
  { 90, 90,  0,130, 90,180, 50, 90, 90, 90, 90, 90,  0,  0,255, 10},
  { 90, 90,  0,130, 90,180, 50, 90, 90, 90, 90, 90,  0,  0,  0,  0},
{  // 1 Forward
  { 90, 90,  0, 90, 90,180, 90, 90, 80,110, 80,120,  0,  0,  0,  5},
  { 90, 90,  0, 90, 90,180, 90, 90, 70, 90, 70, 90,  0,  0,255,  5},
  { 90, 90,  0, 90, 90,180, 90, 90, 70, 70, 70, 80,  0,  0,255,  5},
  { 90, 90,  0, 90, 90,180, 90, 90,100, 60,100, 70,  0,  0,  0,  5},
  { 90, 90,  0, 90, 90,180, 90, 90,110, 90,110, 90,  0,  0,255,  5},
  { 90, 90,  0, 90, 90,180, 90, 90,110,100,110,110,  0,  0,255,  5},
  { 90, 90,  0, 90, 90,180, 90, 90, 90, 90, 90, 90,  0,  0,  0,  0},
{  // 2 Push
  { 90, 90, 90,130,110,180, 50, 90, 90, 90, 90, 90,  0,  0,  0, 10},
  { 90, 90, 90,130,110,180, 50, 90, 90, 90, 90, 90,  0,  0,255,  5},
  { 90, 90, 90,130,110,180, 50, 90, 90, 90, 90, 90,  0,  0,255, 25},
  { 90, 90, 90,130, 90,180, 50, 90, 90, 90, 90, 90,  0,  0,  0,  5},
  { 40,140, 90, 70, 90,180, 90, 90, 90, 90, 90, 90,  0,  0,255, 10},
  { 40,140, 90, 70, 90,180, 90, 90, 90, 90, 90, 90,  0,  0,255, 25},
  servo[0].attach(7);   // Head yaw
  servo[1].attach(9);   // Waist yaw
  servo[2].attach(10);    // R Sholder roll
  servo[3].attach(8);    // R Sholder pitch
  servo[4].attach(11);    // R Hand grip
  servo[5].attach(12);   // L Sholder roll
  servo[6].attach(13);   // L Sholder pitch
  servo[7].attach(14);   // L Hand grip
  servo[8].attach(4);    // R Foot yaw
  servo[9].attach(2);    // R Foot pitch
  servo[10].attach(15);  // L Foot yaw
  servo[11].attach(16);  // L Foot pitch
for( i = 0; i < MAXSN; i++) {
    targetAngle[i] = motion[0][0][i] << SHIFT;
    nowAngle[i] = targetAngle[i];
    servo[i].write((nowAngle[i] >> SHIFT) + trim[i]);
  Serial.begin(115200);   //port
  Serial.print("Ready");
  pinMode(POWER, OUTPUT);
  digitalWrite(POWER, HIGH);
   Serial.flush();
  if (Serial.available())
    static int v=0;
    char ch = Serial.read();
    switch(ch)
        case '0'...'9':                                         //angle function   (問題點)
      v = v*10 + ch - '0';
      case 'a':                                            //control servo[0]    (問題點)
      servo[0].write(v);  //set angle
      v = 0;
      case 'b':                                       //control servo[1]    (問題點)
      servo[1].write(v);
      v = 0;
      delay(50);
      case 'c':                                        //control servo[2]    (問題點)
      servo[2].write(v);
      v = 0;
case '!':
            motionNumber = 0;
            mode = 'M';
            Serial.print("Motion");
            Serial.print(motionNumber);
case '@':
            motionNumber = 1;
            mode = 'M';
case '#':
            motionNumber = 2;
            mode = 'M';
if(endTime > millis()) {
    remainingTime = (endTime - millis()) / 10;
      nowAngle[i] = targetAngle[i] - (deltaAngle[i] * remainingTime);
    else if(mode == 'M') {
    nextFrame();
else if(endTime + 500 < millis()){
      //digitalWrite(POWER, LOW);
//Motion Play
void nextFrame() {
  frameNumber++;
  if(frameNumber >= MAXFN) {
    frameNumber = 0;
  for(i = 0; i < MAXSN; i++) {
    bufferAngle[i] = motion[motionNumber][frameNumber][i];
  bufferTime = motion[motionNumber][frameNumber][TIME];
  nextPose();
//Make a pose
int nextPose() {
  if(bufferTime > 0) {
      targetAngle[i] = bufferAngle[i] << SHIFT;
      deltaAngle[i] = ((bufferAngle[i] << SHIFT) - nowAngle[i]) / (bufferTime * 10);
  } else {
      deltaAngle[i] = 0;
  startTime = millis();
  endTime = startTime + (bufferTime * 100);
  bufferTime = 0;
发表于 2016-1-13 20:25:31 | 显示全部楼层
rapiro的代码,你可以参考完整的代码,里面可以实现单独的servo控制。另外,请在发帖时如果有代码可以使用代码模式。
GMT+8, 2026-6-16 16:42 , Processed in 0.036354 second(s), 19 queries .
