我才12岁
- Hardware connections:
- - (GND) to GND
- + (VDD) to 3.3V
- (WARNING: do not connect + to 5V or the sensor will be damaged!)
- You will also need to connect the I2C pins (SCL and SDA) to your
- Arduino. The pins are different on different Arduinos:
- Any Arduino pins labeled: SDA SCL
- Uno, Redboard, Pro: A4 A5
- Mega2560, Due: 20 21
- Leonardo: 2 3
- Leave the IO (VDDIO) pin unconnected. This pin is for connecting
- the BMP180 to systems with lower logic levels such as 1.8V
- Have fun! -Your friends at SparkFun.
- The SFE_BMP180 library uses floating-point equations developed by the
- Weather Station Data Logger project: http://wmrx00.sourceforge.net/
- Our example code uses the "beerware" license. You can do anything
- you like with this code. No really, anything. If you find it useful,
- buy me a beer someday.
- V10 Mike Grusin, SparkFun Electronics 10/24/2013
- // Your sketch must #include this library, and the Wire library.
- // (Wire is a standard library included with Arduino.):
- #include <Ethernet.h>
- #include <WiFi.h>
- #include <SPI.h>
- #include <yl_data_point.h>
- #include <yl_device.h>
- #include <yl_w5100_client.h>
- #include <yl_wifi_client.h>
- #include <yl_messenger.h>
- #include <yl_sensor.h>
- #include <yl_value_data_point.h>
- #include "dht11.h"
- #include <SFE_BMP180.h>
- #include <Wire.h>
- //this example reads data from a lm35dz sensor, convert value to degree Celsius
- //and then post it to yeelink.net
- //replace 2633 3539 with ur device id and sensor id
- yl_device ardu(2633);
- yl_sensor therm(3539, &ardu);
- //replace first param value with ur u-apikey
- yl_w5100_client client;
- yl_messenger messenger(&client, "u-apikey", "api.yeelink.net");
- const int pin = 5;
- dht11 DHT11; // the Object for sensor DHT11
- int temp; // 溫度, 因為 DHT11 只有給整數 !
- int humi; // 濕度, 因為 DHT11 只有給整數 !
- SFE_BMP180 pressure;
- double baseline; // baseline pressure
- void setup()
- Serial.begin(9600); //for output information
- Serial.println("REBOOT");
- byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xAA};
- Ethernet.begin(mac);
- Serial.println("Testing the DHT11 and dht11.h Library !");
- int chk = DHT11.read(pin);
- Serial.print(String("Error code=") + chk);
- Serial.println(String("Humidity=") + DHT11.humidity + ", Temperature=" + DHT11.temperature);
- if (pressure.begin())
- Serial.println("BMP180 init success");
- else
- // Oops, something went wrong, this is usually a connection problem,
- // see the comments at the top of this sketch for the proper connections.
- Serial.println("BMP180 init fail (disconnected?)\n\n");
- while (1); // Pause forever.
- // Get the baseline pressure:
- baseline = getPressure();
- Serial.print("baseline pressure: ");
- Serial.print(baseline);
- Serial.println(" mb");
- void loop()
- delay(2000); // Wait 2 seconds between measurements.
- if (chk != 0 ) { // 讀取 DHT11 有問題
- Serial.println("DHT11 reading Error !");
- } else { // 把這行注釋掉就可以有錯也照印 !
- temp = DHT11.temperature;
- humi = DHT11.humidity;
- Serial.print("Humidity: ");
- Serial.print(humi);
- Serial.print(" %\t");
- Serial.println(String("Temperature: ") + temp + " oC");
- double a, P;
- // Get a new pressure reading:
- P = getPressure();
- // Show the relative altitude difference between
- // the new reading and the baseline reading:
- a = pressure.altitude(P, baseline);
- Serial.print("relative altitude: ");
- if (a >= 0.0) Serial.print(" "); // add a space for positive numbers
- Serial.print(a, 1);
- Serial.print(" meters, ");
- Serial.print(a * 3.28084, 0);
- Serial.println(" feet");
- delay(500);
- double getPressure()
- char status;
- double T, P, p0, a;
- // You must first get a temperature measurement to perform a pressure reading.
- // Start a temperature measurement:
- // If request is successful, the number of ms to wait is returned.
- // If request is unsuccessful, 0 is returned.
- status = pressure.startTemperature();
- if (status != 0)
- // Wait for the measurement to complete:
- delay(status);
- // Retrieve the completed temperature measurement:
- // Note that the measurement is stored in the variable T.
- // Use '&T' to provide the address of T to the function.
- // Function returns 1 if successful, 0 if failure.
- status = pressure.getTemperature(T);
- if (status != 0)
- // Start a pressure measurement:
- // The parameter is the oversampling setting, from 0 to 3 (highest res, longest wait).
- status = pressure.startPressure(3);
- if (status != 0)
- delay(status);
- // Retrieve the completed pressure measurement:
- // Note that the measurement is stored in the variable P.
- // Use '&P' to provide the address of P.
- // Note also that the function requires the previous temperature measurement (T).
- // (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
- status = pressure.getPressure(P, T);
- if (status != 0)
- return (P);
- else Serial.println("error retrieving pressure measurement\n");
- else Serial.println("error starting pressure measurement\n");
- else Serial.println("error retrieving temperature measurement\n");
- else Serial.println("error starting temperature measurement\n");
- }// if..else..
- } // loop(
- - (GND) to GND
- + (VDD) to 3.3V
- Leonardo: 2 3
- #include <WiFi.h>
- #include <SPI.h>
- #include <Wire.h>
- void setup()
- else
- void loop()
- double a, P;
- delay(500);
- char status;
- if (status != 0)
- delay(status);
- if (status != 0)
- if (status != 0)
- delay(status);
- if (status != 0)
- return (P);
- }// if..else..
- } // loop(
复制代码 帮我把W5100的代码改成可以上传至yeelink的代码可以吗? |
