查看: 4793|回复: 0
谁来给我修改一下代码? 帮我把W5100的代码改成可以上传至yeelink的代码可以吗?
发表于 2016-1-23 09:20:32 | 显示全部楼层 |阅读模式
#include "DHT.h"
#include <SFE_BMP180.h>
#include <Wire.h>
#include <SPI.h>
#include <Ethernet.h>
#include "RTClib.h"
DHT dht;
RTC_DS1307 RTC;
SFE_BMP180 pressure;
byte mac[] = {
   0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 51, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
   Serial.println();
   Wire.begin();
   RTC.begin();
   Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
     dht.setup(2); // data pin 2
     if (! RTC.isrunning()) {
       Serial.println("RTC is NOT running!");
       // following line sets the RTC to the date & time this sketch was compiled
       RTC.adjust(DateTime(__DATE__, __TIME__));
         while (!Serial) {
         ; // wait for serial port to connect. Needed for Leonardo only
       // start the Ethernet connection and the server:
       Ethernet.begin(mac, ip);
       server.begin();
       Serial.print("server is at ");
       Serial.println(Ethernet.localIP());
         Serial.println("REBOOT");
         // Initialize the sensor (it is important to get calibration values stored on the device).
         if (pressure.begin())
           Serial.println("BMP180 init success");
void loop() {&#65533;
  delay(dht.getMinimumSamplingPeriod());
   float humidity = dht.getHumidity();
   float temperature = dht.getTemperature();
   Serial.print(dht.getStatusString());
   Serial.print("\t");
   Serial.print(humidity, 1);
   Serial.print("\t\t");
   Serial.print(temperature, 1);
   Serial.println(dht.toFahrenheit(temperature), 1);
   // listen for incoming clients
   EthernetClient client = server.available();
   if (client) {
     Serial.println("new client");
     // an http request ends with a blank line
     boolean currentLineIsBlank = true;
     while (client.connected()) {
       if (client.available()) {
         char c = client.read();
         Serial.write(c);
         // if you've gotten to the end of the line (received a newline
         // character) and the line is blank, the http request has ended,
         // so you can send a reply
         if (c == '\n' && currentLineIsBlank) {
           // send a standard http response header
           client.println("HTTP/1.1 200 OK");
           client.println("Content-Type: text/html");
           client.println("Connection: close");  // the connection will be closed after completion of the response
           client.println("Refresh: 5");  // refresh the page automatically every 5 sec
           client.println();
           client.println("<!DOCTYPE HTML>");
           client.println("<html>");
           // output the value of each analog input pin
           for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
             int sensorReading = analogRead(analogChannel);
             client.print("analog input ");
             client.print(analogChannel);
             client.print(" is ");
             client.print(sensorReading);
             client.println("<br />");
           client.println("</html>");
         if (c == '\n') {
           // you're starting a new line
         else if (c != '\r') {
           // you've gotten a character on the current line
           currentLineIsBlank = false;
     // give the web browser time to receive the data
     delay(1);
     // close the connection:
     client.stop();
     Serial.println("client disconnected");
     char status;
     double T, P, p0, a;
     // Loop here getting pressure readings every 10 seconds.
     // If you want sea-level-compensated pressure, as used in weather reports,
     // you will need to know the altitude at which your measurements are taken.
     // We're using a constant called ALTITUDE in this sketch:
     Serial.println();
     Serial.print("provided altitude: ");
     Serial.print(ALTITUDE, 0);
     Serial.print(" meters, ");
     Serial.print(ALTITUDE * 3.28084, 0);
     Serial.println(" feet");
     // If you want to measure altitude, and not pressure, you will instead need
     // to provide a known baseline pressure. This is shown at the end of the sketch.
     // You must first get a temperature measurement to perform a pressure reading.
     // Start a temperature measurement:
     // If request is successful, the number of ms to wait is returned.
     // If request is unsuccessful, 0 is returned.
     status = pressure.startTemperature();
     if (status != 0)
       // Wait for the measurement to complete:
       delay(status);
       // Retrieve the completed temperature measurement:
       // Note that the measurement is stored in the variable T.
       // Function returns 1 if successful, 0 if failure.
       status = pressure.getTemperature(T);
       if (status != 0)
         // Print out the measurement:
         Serial.print("temperature: ");
         Serial.print(T, 2);
         Serial.print(" deg C, ");
         Serial.print((9.0 / 5.0)*T + 32.0, 2);
         Serial.println(" deg F");
         // Start a pressure measurement:
         // The parameter is the oversampling setting, from 0 to 3 (highest res, longest wait).
         status = pressure.startPressure(3);
         if (status != 0)
           delay(status);
           // Retrieve the completed pressure measurement:
           // Note that the measurement is stored in the variable P.
           // Note also that the function requires the previous temperature measurement (T).
           // (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
           status = pressure.getPressure(P, T);
           if (status != 0)
             Serial.print("absolute pressure: ");
             Serial.print(P, 2);
             Serial.print(" mb, ");
             Serial.print(P * 0.0295333727, 2);
             Serial.println(" inHg");
             // The pressure sensor returns abolute pressure, which varies with altitude.
             // To remove the effects of altitude, use the sealevel function and your current altitude.
             // This number is commonly used in weather reports.
             // Parameters: P = absolute pressure in mb, ALTITUDE = current altitude in m.
             // Result: p0 = sea-level compensated pressure in mb
             p0 = pressure.sealevel(P, ALTITUDE); // we're at 1655 meters (Boulder, CO)
             Serial.print("relative (sea-level) pressure: ");
             Serial.print(p0, 2);
             Serial.print(p0 * 0.0295333727, 2);
             // On the other hand, if you want to determine your altitude from the pressure reading,
             // use the altitude function along with a baseline pressure (sea-level or other).
             // Parameters: P = absolute pressure in mb, p0 = baseline pressure in mb.
             // Result: a = altitude in m.
             a = pressure.altitude(P, p0);
             Serial.print("computed altitude: ");
             Serial.print(a, 0);
             Serial.print(a * 3.28084, 0);
           else Serial.println("error retrieving pressure measurement\n");
         else Serial.println("error starting pressure measurement\n");
       else Serial.println("error retrieving temperature measurement\n");
     else Serial.println("error starting temperature measurement\n");
     delay(5000);  // Pause for 5 seconds.
     DateTime now = RTC.now();
     Serial.print(now.year(), DEC);
     Serial.print('/');
     Serial.print(now.month(), DEC);
     Serial.print('/');
     Serial.print(now.day(), DEC);
     Serial.print(' ');
     Serial.print(now.hour(), DEC);
     Serial.print(':');
     Serial.print(now.minute(), DEC);
     Serial.print(':');
     Serial.print(now.second(), DEC);
     Serial.println();
     Serial.print(" since midnight 1/1/1970 = ");
     Serial.print(now.unixtime());
     Serial.print("s = ");
     Serial.print(now.unixtime() / 86400L);
     Serial.println("d");
     // calculate a date which is 7 days and 30 seconds into the future
     DateTime future (now.unixtime() + 7 * 86400L + 30);
     Serial.print(" now + 7d + 30s: ");
     Serial.print(future.year(), DEC);
     Serial.print('/');
     Serial.print(future.month(), DEC);
     Serial.print('/');
     Serial.print(future.day(), DEC);
     Serial.print(' ');
     Serial.print(future.hour(), DEC);
     Serial.print(':');
     Serial.print(future.minute(), DEC);
     Serial.print(':');
     Serial.print(future.second(), DEC);
     Serial.println();
     Serial.println();
     delay(3000);
GMT+8, 2026-7-25 04:44 , Processed in 0.052551 second(s), 17 queries .
