查看: 14485|回复: 2
關於平衡車檢測角度數據程式碼
发表于 2016-2-2 06:59:31 | 显示全部楼层 |阅读模式
小弟最近好不容易求到了可以讓平衡車子站起來的程式碼
#include "Wire.h"
#include <Servo.h>
#include <Kalman.h>
#include "I2Cdev.h"
#include "MPU6050.h"
float fRad2Deg = 57.295779513f;       //将弧度转为角度的乘数
const int nCalibTimes = 1000;         //校准时读数的次数
int calibData[6];                     //校准数据
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
bool blinkState = false;
char flag = false;                    //打印开关
unsigned long nLastTime = 0;          //上一次读数的时间
Kalman kalmanRoll;                    //Roll角滤波器
Kalman kalmanPitch;                   //Pitch角滤波器
/*********** PID控制器参数 *********/
float ITerm, lastInput;              // 积分项、前次输入
float Output = 0.0;                  // PID输出值
/***********电机参数**************/
Servo ServoL;
Servo ServoR;
/***********四元数参数***********/
#define KP 0.025f//10.0f
#define KI 0.0f//0.008f
#define halfT 0.001f
float q0 = 1, q1 = 0, q2 = 0, q3 = 0;
float exInt = 0, eyInt = 0, ezInt = 0;
float Angle_roll, Angle_pitch, Angle_yaw;
byte ENA = 5;byte IN1 = 9; byte IN2 = 10;
byte ENB = 6;byte IN3 = 11;byte IN4 = 12;
    // join I2C bus (I2Cdev library doesn't do this automatically)
    Wire.begin();
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    Serial.begin(38400);
    // initialize device
    Serial.println("Initializing I2C devices...");
    accelgyro.initialize();
    // verify connection
for( byte i = 0; i <= 12 ; i++){
pinMode(i,OUTPUT);
    // configure Arduino LED for
    int16_t readouts[6];
  ReadAccGyr(readouts); //读出测量值
  float realVals[6];
  Rectify(readouts, realVals); //根据校准的偏移量进行纠正
  //四元数解析出欧拉角
// AngleUpdate(realVals);
  //计算加速度向量的模长,均以g为单位
  float fRoll = GetRoll(realVals); //计算Roll角
  float fPitch = GetPitch(realVals); //计算Pitch角
  //计算两次测量的时间间隔dt,以秒为单位
  unsigned long nCurTime = micros();
  float dt = (double)(nCurTime - nLastTime) / 1000000.0;
  //对Roll角和Pitch角进行卡尔曼滤波
  float fNewRoll = kalmanRoll.getAngle(fRoll, realVals[4], dt);
  float fNewPitch = kalmanPitch.getAngle(fPitch, realVals[5], dt);
  //更新本次测的时间
  nLastTime = nCurTime;
  //PID控制
  nCurTime = millis();                                    // 当前时间(ms)
  float TimeCh = (nCurTime - nLastTime) / 1000.0;         // 采样时间(s)
  float Kp = 3.5, Ki = 0.0, Kd = 0.0;                    // 比例系数、积分系数、微分系数
  float SampleTime = 0.1;                                 // 采样时间(s)
  float Setpoint = 0;                                     // 设定目标值(degree)
  float outMin = -255, outMax = +255;                     // 输出上限、输出下限
  if (TimeCh >= SampleTime) {                             // 到达预定采样时间时
    float Input = fNewPitch;                            // 输入赋值
    float error = Setpoint - Input;                     // 偏差值
    ITerm += (Ki * error * TimeCh);                     // 计算积分项
    ITerm = constrain(ITerm, outMin, outMax);           // 限定值域
    float DTerm = Kd * (Input - lastInput) / TimeCh;    // 计算微分项
    Output = Kp * error + ITerm - DTerm;                // 计算输出值
    Output = constrain(Output, outMin, outMax);         // 限定值域
    //servoL.write(Output + servoL_offset);             // 控制左驱
    //servoR.write(Output + servoR_offset);             // 控制右驱
    lastInput = Input;                                  // 记录输入值
    nLastTime = nCurTime;                               // 记录本次时间
  if (Serial.available() > 0) {
    char rece = Serial.read();
    delay(10);
    if (rece == (char)'#')
      Serial.println("Nano is Activity...");
    flag = rece;
  if (flag == (char)'R')
    Serial.print("Roll: (" );
    Serial.print(fNewRoll);
    Serial.print(" ) \t");
    Serial.print("Pitch : (" );
    Serial.print(fNewPitch);
    Serial.print(" ) \ r \ n ");
  if(Output > 0){
  analogWrite(ENA,Output);
  digitalWrite(IN1,HIGH);digitalWrite(IN2,LOW);
   analogWrite(ENB,Output);
  digitalWrite(IN3,HIGH);digitalWrite(IN4,LOW);
  else{analogWrite(ENA,Output);
  digitalWrite(IN1,LOW);digitalWrite(IN2,HIGH);
  digitalWrite(IN3,LOW);digitalWrite(IN4,HIGH);
void ReadAccGyr(int16_t *pVals)
  accelgyro.getMotion6(&pVals[0], &pVals[1], &pVals[2], &pVals[3], &pVals[4], &pVals[5]);
//对大量读数进行统计,校准平均偏移量
void Calibration()
  int16_t valSums[6] = {0};
  //先求和
  for (int i = 0; i < nCalibTimes; ++i)
    ReadAccGyr(valSums);
  //再求平均
  for (int i = 0; i < 6; ++i)
    calibData = int(valSums / nCalibTimes);
  calibData[2] += 16384; //设芯片Z轴竖直向下,设定静态工作点。
//对读数进行纠正,消除偏移,并转换为物理量。公式见文档。
void Rectify(int *pReadout, float *pRealVals)
  for (int i = 0; i < 3; ++i)
    pRealVals = (float)(pReadout - calibData) / 16384.0f;
  for (int i = 3; i < 6; ++i)
    pRealVals = (float)(pReadout - calibData) / 131.0f;
//算得Roll角。算法见文档。
float GetRoll(float *pRealVals)
  float fNorm = sqrt(pRealVals[0] * pRealVals[0] + pRealVals[1] * pRealVals[1] + pRealVals[2] * pRealVals[2]);
  float fNormXZ = sqrt(pRealVals[0] * pRealVals[0] + pRealVals[2] * pRealVals[2]);
  float fCos = fNormXZ / fNorm;
  if (pRealVals[1] > 0)
    return -acos(fCos) * fRad2Deg;
    return acos(fCos) * fRad2Deg;
//算得Pitch角。算法见文档。
float GetPitch(float *pRealVals)
  float fNormYZ = sqrt(pRealVals[1] * pRealVals[1] + pRealVals[2] * pRealVals[2]);
  float fCos = fNormYZ / fNorm;
  if (pRealVals[0] < 0)
void AngleUpdate(float *pRealVals)
  float norm;
  float vx, vy, vz;
  float ex, ey, ez;
  if (pRealVals[0]*pRealVals[1]*pRealVals[2] == 0)
    return;
  norm = sqrt(pRealVals[0] * pRealVals[0] + pRealVals[1] * pRealVals[1] + pRealVals[2] * pRealVals[2]);
  vx = 2 * (q1 * q3 - q0 * q2);
  vy = 2 * (q0 * q1 - q3 * q2);
  vz = q0 * q0 - q1 * q1 - q2 * q2 + q3 * q3;
  ex = pRealVals[1] / norm * vz - pRealVals[2] / norm * vy;
  ey = pRealVals[2] / norm * vx - pRealVals[0] / norm * vz;
  ez = pRealVals[0] / norm * vy - pRealVals[1] / norm * vx;
  exInt = exInt + ex * KI;
  eyInt = eyInt + ey * KI;
  ezInt = ezInt + ez * KI;
  q0 = q0 + (-q1 * pRealVals[3] + KP * ex + exInt - q2 * pRealVals[4] + KP * ey + eyInt - q3 * pRealVals[5] + KP * ez + ezInt) * halfT;
  q1 = q1 + (q0 * pRealVals[3] + KP * ex + exInt + q2 * pRealVals[5] + KP * ez + ezInt - q3 * pRealVals[4] + KP * ey + eyInt) * halfT;
  q2 = q2 + (q0 * pRealVals[4] + KP * ey + eyInt - q1 * pRealVals[5] + KP * ez + ezInt + q3 * pRealVals[3] + KP * ex + exInt) * halfT;
  q3 = q3 + (q0 * pRealVals[5] + KP * ez + ezInt + q1 * pRealVals[4] + KP * ey + eyInt - q2 * pRealVals[3] + KP * ex + exInt) * halfT;
  norm = sqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
  q0 = q0 / norm;
  q1 = q1 / norm;
  q2 = q2 / norm;
  q3 = q3 / norm;
  Angle_roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2 * q2 + 1) * fRad2Deg;
  Angle_pitch = asin(-2 * q1 * q3 + 2 * q0 * q2) * fRad2Deg;
  Angle_yaw = atan2(2 * q1 * q2 + 2 * q0 * q3, -2 * q2 * q2 - 2 * q3 * q3 + 1) * fRad2Deg;
我看了裡面的程式碼有卡爾曼濾波 跟pid的程式碼 已知要調整比例係數,就可以做修正了
區間是1-10 可是我調了好幾次 都沒有自動校正
因為車子車身本身不平衡 看了板上蠻多車子都是靠MPU6050來做平衡校正
東西要趨近於0 我東西是要看pitch 上下 特別的是趨近於0馬達會動 也不太懂是啥意思
照理說因該是頃斜後他自己會重新立起來跟不倒翁一樣
有必要傳小車圖片? 我的電機是用香蕉電機跟板上的很多位大大一樣 不過我香蕉電機是平放 不是豎在車子旁邊
控制電機是l298n 但是無法用9v的方型電池催動 只能用6個1.5v的電池催動
請問板上大大都是用哪種電壓的電池?
目前遇到的難關就這幾個
1.香蕉電機不會做平衡校正
2.電池的電壓不足供應給電機做校正
3.PID角度不太懂如何抓
4.MPU6050如何對晶片+香蕉電機做校正?
5.是MPU6050控制重心還是要以現實重心讓車子平衡?
雖然網路上有別人做好的晶片 我還是想用手邊的mpu6050
我的mpu6050型號是GY-521
之前看蠻多大大 好像加了很多東西才讓東西立起來
目前我手邊只有 MPU6050+L298N的東西 之後要用藍芽控制前後左右
程式碼已經規劃好 希望各位大大可以給些建議或解答幫忙小弟渡過難關
先謝謝大大
发表于 2016-2-2 08:54:14 | 显示全部楼层
  1. 小弟最近好不容易求到了可以讓平衡車子站起來的程式碼
  2. #include "Wire.h"
  3. #include <Servo.h>
  4. #include <Kalman.h>
  5. #include "I2Cdev.h"
  6. #include "MPU6050.h"
  7. float fRad2Deg = 57.295779513f;       //将弧度转为角度的乘数
  8. const int nCalibTimes = 1000;         //校准时读数的次数
  9. int calibData[6];                     //校准数据
  10. MPU6050 accelgyro;
  11. int16_t ax, ay, az;
  12. int16_t gx, gy, gz;
  13. bool blinkState = false;
  14. char flag = false;                    //打印开关
  15. unsigned long nLastTime = 0;          //上一次读数的时间
  16. Kalman kalmanRoll;                    //Roll角滤波器
  17. Kalman kalmanPitch;                   //Pitch角滤波器
  18. /*********** PID控制器参数 *********/
  19. float ITerm, lastInput;              // 积分项、前次输入
  20. float Output = 0.0;                  // PID输出值
  21. /***********电机参数**************/
  22. Servo ServoL;
  23. Servo ServoR;
  24. /***********四元数参数***********/
  25. #define KP 0.025f//10.0f
  26. #define KI 0.0f//0.008f
  27. #define halfT 0.001f
  28. float q0 = 1, q1 = 0, q2 = 0, q3 = 0;
  29. float exInt = 0, eyInt = 0, ezInt = 0;
  30. float Angle_roll, Angle_pitch, Angle_yaw;
  31. byte ENA = 5;byte IN1 = 9; byte IN2 = 10;
  32. byte ENB = 6;byte IN3 = 11;byte IN4 = 12;
  33. void setup() {
  34.     // join I2C bus (I2Cdev library doesn't do this automatically)
  35.     Wire.begin();
  36.     // initialize serial communication
  37.     // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
  38.     // it's really up to you depending on your project)
  39.     Serial.begin(38400);
  40.     // initialize device
  41.     Serial.println("Initializing I2C devices...");
  42.     accelgyro.initialize();
  43.     // verify connection
  44.     Serial.println("Testing device connections...");
  45.     Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
  46. for( byte i = 0; i <= 12 ; i++){
  47. pinMode(i,OUTPUT);
  48. }
  49.     // configure Arduino LED for
  50. }
  51. void loop() {
  52.     int16_t readouts[6];
  53.   ReadAccGyr(readouts); //读出测量值
  54.   float realVals[6];
  55.   Rectify(readouts, realVals); //根据校准的偏移量进行纠正
  56.   //四元数解析出欧拉角
  57. // AngleUpdate(realVals);
  58.   //计算加速度向量的模长,均以g为单位
  59.   float fRoll = GetRoll(realVals); //计算Roll角
  60.   float fPitch = GetPitch(realVals); //计算Pitch角
  61.   //计算两次测量的时间间隔dt,以秒为单位
  62.   unsigned long nCurTime = micros();
  63.   float dt = (double)(nCurTime - nLastTime) / 1000000.0;
  64.   //对Roll角和Pitch角进行卡尔曼滤波
  65.   float fNewRoll = kalmanRoll.getAngle(fRoll, realVals[4], dt);
  66.   float fNewPitch = kalmanPitch.getAngle(fPitch, realVals[5], dt);
  67.   //更新本次测的时间
  68.   nLastTime = nCurTime;
  69.   //PID控制
  70.   nCurTime = millis();                                    // 当前时间(ms)
  71.   float TimeCh = (nCurTime - nLastTime) / 1000.0;         // 采样时间(s)
  72.   float Kp = 3.5, Ki = 0.0, Kd = 0.0;                    // 比例系数、积分系数、微分系数
  73.   float SampleTime = 0.1;                                 // 采样时间(s)
  74.   float Setpoint = 0;                                     // 设定目标值(degree)
  75.   float outMin = -255, outMax = +255;                     // 输出上限、输出下限
  76.   if (TimeCh >= SampleTime) {                             // 到达预定采样时间时
  77.     float Input = fNewPitch;                            // 输入赋值
  78.     float error = Setpoint - Input;                     // 偏差值
  79.     ITerm += (Ki * error * TimeCh);                     // 计算积分项
  80.     ITerm = constrain(ITerm, outMin, outMax);           // 限定值域
  81.     float DTerm = Kd * (Input - lastInput) / TimeCh;    // 计算微分项
  82.     Output = Kp * error + ITerm - DTerm;                // 计算输出值
  83.     Output = constrain(Output, outMin, outMax);         // 限定值域
  84.     //servoL.write(Output + servoL_offset);             // 控制左驱
  85.     //servoR.write(Output + servoR_offset);             // 控制右驱
  86.     lastInput = Input;                                  // 记录输入值
  87.     nLastTime = nCurTime;                               // 记录本次时间
  88.   }
  89.   if (Serial.available() > 0) {
  90.     char rece = Serial.read();
  91.     delay(10);
  92.     if (rece == (char)'#')
  93.     {
  94.       Serial.println("Nano is Activity...");
  95.     }
  96.     flag = rece;
  97.   }
  98.   if (flag == (char)'R')
  99.   {
  100.     Serial.print("Roll");
  101.     Serial.print(fNewRoll);
  102.     Serial.print(")\t");
  103.     Serial.print("itch");
  104.     Serial.print(fNewPitch);
  105.     Serial.print(")\r\n");
  106.   }
  107.
  108.   if(Output > 0){
  109.   analogWrite(ENA,Output);
  110.   digitalWrite(IN1,HIGH);digitalWrite(IN2,LOW);
  111.    analogWrite(ENB,Output);
  112.   digitalWrite(IN3,HIGH);digitalWrite(IN4,LOW);
  113.   }
  114.   else{analogWrite(ENA,Output);
  115.   digitalWrite(IN1,LOW);digitalWrite(IN2,HIGH);
  116.    analogWrite(ENB,Output);
  117.   digitalWrite(IN3,LOW);digitalWrite(IN4,HIGH);
  118.
  119.
  120.   }
  121. }
  122. void ReadAccGyr(int16_t *pVals)
  123. {
  124.   accelgyro.getMotion6(&pVals[0], &pVals[1], &pVals[2], &pVals[3], &pVals[4], &pVals[5]);
  125. }
  126. //对大量读数进行统计,校准平均偏移量
  127. void Calibration()
  128. {
  129.   int16_t valSums[6] = {0};
  130.   //先求和
  131.   for (int i = 0; i < nCalibTimes; ++i)
  132.   {
  133.     ReadAccGyr(valSums);
  134.   }
  135.   //再求平均
  136.   for (int i = 0; i < 6; ++i)
  137.   {
  138.     calibData[i] = int(valSums[i] / nCalibTimes);
  139.   }
  140.   calibData[2] += 16384; //设芯片Z轴竖直向下,设定静态工作点。
  141. }
  142. //对读数进行纠正,消除偏移,并转换为物理量。公式见文档。
  143. void Rectify(int *pReadout, float *pRealVals)
  144. {
  145.   for (int i = 0; i < 3; ++i)
  146.   {
  147.     pRealVals[i] = (float)(pReadout[i] - calibData[i]) / 16384.0f;
  148.   }
  149.   for (int i = 3; i < 6; ++i)
  150.   {
  151.     pRealVals[i] = (float)(pReadout[i] - calibData[i]) / 131.0f;
  152.   }
  153. }
  154. //算得Roll角。算法见文档。
  155. float GetRoll(float *pRealVals)
  156. {
  157.   float fNorm = sqrt(pRealVals[0] * pRealVals[0] + pRealVals[1] * pRealVals[1] + pRealVals[2] * pRealVals[2]);
  158.   float fNormXZ = sqrt(pRealVals[0] * pRealVals[0] + pRealVals[2] * pRealVals[2]);
  159.   float fCos = fNormXZ / fNorm;
  160.   if (pRealVals[1] > 0)
  161.   {
  162.     return -acos(fCos) * fRad2Deg;
  163.   }
  164.   else
  165.     return acos(fCos) * fRad2Deg;
  166. }
  167. //算得Pitch角。算法见文档。
  168. float GetPitch(float *pRealVals)
  169. {
  170.   float fNorm = sqrt(pRealVals[0] * pRealVals[0] + pRealVals[1] * pRealVals[1] + pRealVals[2] * pRealVals[2]);
  171.   float fNormYZ = sqrt(pRealVals[1] * pRealVals[1] + pRealVals[2] * pRealVals[2]);
  172.   float fCos = fNormYZ / fNorm;
  173.   if (pRealVals[0] < 0)
  174.   {
  175.     return -acos(fCos) * fRad2Deg;
  176.   }
  177.   else
  178.     return acos(fCos) * fRad2Deg;
  179. }
  180. void AngleUpdate(float *pRealVals)
  181. {
  182.   float norm;
  183.   float vx, vy, vz;
  184.   float ex, ey, ez;
  185.   if (pRealVals[0]*pRealVals[1]*pRealVals[2] == 0)
  186.     return;
  187.   norm = sqrt(pRealVals[0] * pRealVals[0] + pRealVals[1] * pRealVals[1] + pRealVals[2] * pRealVals[2]);
  188.   vx = 2 * (q1 * q3 - q0 * q2);
  189.   vy = 2 * (q0 * q1 - q3 * q2);
  190.   vz = q0 * q0 - q1 * q1 - q2 * q2 + q3 * q3;
  191.   ex = pRealVals[1] / norm * vz - pRealVals[2] / norm * vy;
  192.   ey = pRealVals[2] / norm * vx - pRealVals[0] / norm * vz;
  193.   ez = pRealVals[0] / norm * vy - pRealVals[1] / norm * vx;
  194.   exInt = exInt + ex * KI;
  195.   eyInt = eyInt + ey * KI;
  196.   ezInt = ezInt + ez * KI;
  197.   q0 = q0 + (-q1 * pRealVals[3] + KP * ex + exInt - q2 * pRealVals[4] + KP * ey + eyInt - q3 * pRealVals[5] + KP * ez + ezInt) * halfT;
  198.   q1 = q1 + (q0 * pRealVals[3] + KP * ex + exInt + q2 * pRealVals[5] + KP * ez + ezInt - q3 * pRealVals[4] + KP * ey + eyInt) * halfT;
  199.   q2 = q2 + (q0 * pRealVals[4] + KP * ey + eyInt - q1 * pRealVals[5] + KP * ez + ezInt + q3 * pRealVals[3] + KP * ex + exInt) * halfT;
  200.   q3 = q3 + (q0 * pRealVals[5] + KP * ez + ezInt + q1 * pRealVals[4] + KP * ey + eyInt - q2 * pRealVals[3] + KP * ex + exInt) * halfT;
  201.   norm = sqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
  202.   q0 = q0 / norm;
  203.   q1 = q1 / norm;
  204.   q2 = q2 / norm;
  205.   q3 = q3 / norm;
  206.   Angle_roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2 * q2 + 1) * fRad2Deg;
  207.   Angle_pitch = asin(-2 * q1 * q3 + 2 * q0 * q2) * fRad2Deg;
  208.   Angle_yaw = atan2(2 * q1 * q2 + 2 * q0 * q3, -2 * q2 * q2 - 2 * q3 * q3 + 1) * fRad2Deg;
  209. }
 楼主| 发表于 2016-2-4 13:11:13 | 显示全部楼层
請問這兩個程式碼要做用它才會做平衡?
還是要加啥下去才會做平衡?
剛開始只是測角度 後來馬達沒有自己做校正
請問它是要調哪裡才會自己做校正呢?
這兩行前面去掉會有錯
我當初拿到這程式碼 只有說調整角度 可式調整完之後電機輪子沒辦法自己做平衡
電壓絕對夠 可是不清楚做用
有大大可以開導一下?
GMT+8, 2026-7-23 10:18 , Processed in 0.036073 second(s), 18 queries .
