查看: 7859|回复: 0
帮我看一下,我想把数据发送直yeelink,但收不到数据
发表于 2016-2-17 14:59:25 | 显示全部楼层 |阅读模式
[pre lang="arduino" line="1" file="sketch_yeelink"]#include <Ethernet.h>
#include <LiquidCrystal.h> //LCD1602的库
#include <WiFi.h>
#include <SPI.h>
#include <HttpClient.h>
#include <yl_data_point.h>
#include <yl_device.h>
#include <yl_w5100_client.h>
#include <yl_wifi_client.h>
#include <yl_messenger.h>
#include <yl_sensor.h>
#include <yl_value_data_point.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include "DHT.h"
#include <math.h>
#define DHTPIN 7     // what pin we're connected to
int BH1750address = 0x23;
byte buff[2];
LiquidCrystal lcd1602(12, 11, 5, 4, 3, 2);//设置Arduino与LCD液晶屏的接口
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
char ssid[] = "HomeWiFi";      // your network SSID (name)
char pass[] = "";   // your network password
Adafruit_BMP085 bmp;
DHT dht(DHTPIN, DHTTYPE);
yl_device ardu(164872);
yl_sensor generic(183023, &ardu);
yl_sensor generic2(183049, &ardu);
yl_sensor generic3(183050, &ardu);
yl_sensor generic4(381365, &ardu);
//replace first param value with ur u-apikey
yl_w5100_client client;
yl_messenger messenger(&client, "u-apikey", "api.yeelink.net");
  Serial.begin(9600);  //for output information
  byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xAA};
  Ethernet.begin(mac);
  bmp.begin();
  dht.begin();
  Wire.begin(); //初始化总线
    Serial.print("yeelink:");
  uint16_t val = 0;
  BH1750_Init(BH1750address);
  delay(200);
  if (2 == BH1750_Read(BH1750address))
    val = ((buff[0] << 8) | buff[1]) / 1.2;
  Serial.print("Sensor value is: ");
  Serial.println((int)val);
int BH1750_Read(int address) //
  int i = 0;
  Wire.beginTransmission(address);
  Wire.requestFrom(address, 2);
  while (Wire.available()) //
    buff = Wire.read();  // receive one byte
    i++;
  Wire.endTransmission();
  return i;
void BH1750_Init(int address)
  Wire.write(0x10);//1lx reolution 120ms
  Serial.print("Temperature = ");
  Serial.print(bmp.readTemperature());
  Serial.println(" *C");
  Serial.print("Pressure = ");
  Serial.print(bmp.readPressure());
  Serial.println(" Pa");
  float h = dht.readHumidity();
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    delay(5000);
  }[/code]
GMT+8, 2026-6-15 01:09 , Processed in 0.077925 second(s), 17 queries .
