查看: 12990|回复: 4
为什么我收不到大气压,温度湿度数据,帮我看看
发表于 2016-2-19 16:25:06 | 显示全部楼层 |阅读模式
[pre lang="arduino" line="1" file="yeelink"]#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <math.h>
#include <Adafruit_BMP085.h>
#include "DHT.h"
int BH1750address = 0x23;
byte buff[2];
int BMP085address = 0x25;
#define DHTPIN 2
#define DHTTYPE DHT11   // DHT 11
// for yeelink api
#define APIKEY         "67091e8255dc2f2d8e589974bc166531" // replace your yeelink api key here
#define deviceid       164872 // replace your device ID
#define sensorid       183023 // replace your sensor ID
#define sensorid       183049 // replace your sensor ID
#define sensorid       183050 // replace your sensor ID
#define sensorid       381365 // replace your sensor ID
// assign a MAC address for the ethernet controller.
byte mac[] = { 0x5A, 0x94, 0x5D, 0x2a, 0x96, 0x9C};
// initialize the library instance:
EthernetClient client;
char server[] = "api.yeelink.net";   // name address for yeelink API
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 5*1000; // delay between 2 datapoints, 30s
DHT dht(DHTPIN, DHTTYPE);
Adafruit_BMP085 bmp;
  Wire.begin();
  // start serial port:
  Serial.begin(57600);
  dht.begin();
  bmp.begin();
  // start the Ethernet connection with DHCP:
  if (Ethernet.begin(mac) == 0) {
    for(;;)
  else {
    Serial.println("Ethernet configuration OK");
   float h = dht.readHumidity();
  Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature = ");
    Serial.print(bmp.readTemperature());
    Serial.println(" *C");
    Serial.print("Pressure = ");
    Serial.print(bmp.readPressure());
    Serial.println(" Pa");
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    Serial.println();
    client.stop();
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    // read sensor data, replace with your code
    int sensorReading = readLightSensor();
    //send data to server
    sendData(sensorReading);
  // store the state of the connection for next time through
  // the loop:
  lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void sendData(int thisData) {
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    // send the HTTP PUT request:
    client.print("POST /v1.0/device/");
    client.print(deviceid);
    client.print("/sensor/");
    client.print(sensorid);
    client.print("/datapoints");
    client.println(" HTTP/1.1");
    client.println("Host: api.yeelink.net");
    client.print("Accept: *");
    client.print("/");
    client.println("*");
    client.print("U-ApiKey: ");
    client.println(APIKEY);
    client.print("Content-Length: ");
    // calculate the length of the sensor reading in bytes:
    // 8 bytes for {"value":} + number of digits of the data:
    int thisLength = 10 + getLength(thisData);
    client.println(thisLength);
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.println("Connection: close");
    client.println();
    // here's the actual content of the PUT request:
    client.print("{\"value\":");
    client.print(thisData);
    client.println("}");
  else {
    // if you couldn't make a connection:
    Serial.println();
    client.stop();
   // note the time that the connection was made or attempted:
// This method calculates the number of digits in the
// sensor reading.  Since each digit of the ASCII decimal
// representation is a byte, the number of digits equals
// the number of bytes:
int getLength(int someValue) {
  // there's at least one byte:
  int digits = 1;
  // continually divide the value by ten,
  // adding one to the digit count for each
  // time you divide, until you're at 0:
  int dividend = someValue /10;
  while (dividend > 0) {
    dividend = dividend /10;
    digits++;
  // return the number of digits:
  return digits;
// get data from light sensor
// you can replace this code for your sensor
int readLightSensor()
  float t = dht.readTemperature();
    Serial.print(h);
  uint16_t val=0;
  BH1750_Init(BH1750address);
  delay(200);
  if(2==BH1750_Read(BH1750address))
    val=((buff[0]<<8)|buff[1])/1.2;
  Serial.print("Sensor value is: ");
  Serial.println((int)val);
  return val;
int BH1750_Read(int address) //
  int i=0;
  Wire.beginTransmission(address);
  Wire.requestFrom(address, 2);
  while(Wire.available()) //
    buff = Wire.read();  // receive one byte
    i++;
  Wire.endTransmission();
  return i;
void BH1750_Init(int address)
  Wire.write(0x10);//1lx reolution 120ms
}[/code]
发表于 2016-2-19 22:50:16 | 显示全部楼层
代码太长了,建议你先单独调试模块,没问题再合并代码
 楼主| 发表于 2016-2-20 10:59:31 | 显示全部楼层
我模块都没问题
发表于 2016-2-20 11:37:31 | 显示全部楼层
正如楼上 lovezyph 大大所说, 先分开独立测试再合拼, 是找出问题的好方法.
简单来说, 可以分开两部份独立测试:
1) 接收传感器回传的数据
2) 向物联网发送数据
先看看3是那部份出了问题, 再合并来测试吧.
当然, 每部份也可以再细分 (比如 2, 有可能是网络问题, 也有可能是物联网连线问题, 亦有可能是帐户设定问题), 先从大的地方分开, 慢慢细分, 就可以看出问题.
 楼主| 发表于 2016-2-20 12:16:34 | 显示全部楼层
那你们谁有将DHT11数据上传yeelink的代码
GMT+8, 2026-6-15 03:37 , Processed in 0.036266 second(s), 19 queries .
