查看: 24422|回复: 1
ARDUINO在串口通信时分别使用数字0和数字1脚作为RX和TX脚?
发表于 2016-4-3 18:43:31 | 显示全部楼层 |阅读模式
Duemilanove的串口脚是数字0和数字1,与安卓板进行串口通讯,安卓板的串口是RX TX各占一个引脚,但ARDUINO用下面的代码,接受发送都只用一个数字0脚,怎么让RX 和TX各自使用数字0和数字1脚?
String inputString = "";
boolean stringComplete = false
  // initialize serial:
  // reserve 200 bytes for the inputString:
  inputString.reserve(200);
  // print the string when a newline arrives:
  if (stringComplete) {
    Serial.println(inputString);
    // clear the string:
    inputString = "";
    stringComplete = false;
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
 楼主| 发表于 2016-4-3 22:42:01 | 显示全部楼层
自己解决了,用SOFTWAREserial
http://www.arduino.cc/en/Tutorial/SoftwareSerialExample
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
void loop() { // run over and over
  if (mySerial.available()) {
    Serial.write(mySerial.read());
  if (Serial.available()) {
    mySerial.write(Serial.read());
GMT+8, 2026-6-15 18:17 , Processed in 0.036379 second(s), 18 queries .
