查看: 19316|回复: 9
怎么把w5100从网络上获得的时间送给另一块Arduino
发表于 2016-4-11 21:56:27 | 显示全部楼层 |阅读模式
发表于 2016-4-12 09:34:15 | 显示全部楼层
ntp获取时间后,串口、I2C发给另一个arduino就可以啦
 楼主| 发表于 2016-4-13 15:55:39 | 显示全部楼层
无法获得ntp的信息,这是怎么回事。自定义的IP gateway subnet
发表于 2016-4-15 20:32:21 | 显示全部楼层
代码贴上吧
 楼主| 发表于 2016-4-18 09:47:51 | 显示全部楼层
zhangyadong300 发表于 2016-4-15 20:32
代码贴上吧
#include <Time.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xE2 };
// NTP Servers:
IPAddress ip(10,0,49,243);
IPAddress gateway(10,0,49,254);
IPAddress subnet(255,255,255,128);
IPAddress timeServer(132,163,4,101); // time-a.timefreq.bldrdoc.gov
// IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov
// IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov
const int timeZone = +8;     // Central European Time
//const int timeZone = -5;  // Eastern Standard Time (USA)
//const int timeZone = -4;  // Eastern Daylight Time (USA)
//const int timeZone = -8;  // Pacific Standard Time (USA)
//const int timeZone = -7;  // Pacific Daylight Time (USA)
EthernetUDP Udp;
unsigned int localPort = 8888;  // local port to listen for UDP packets
  while (!Serial) ; // Needed for Leonardo only
  delay(250);
  Serial.println("TimeNTP Example");
//  if (Ethernet.begin(mac) == 0) {
//    // no point in carrying on, so do nothing forevermore:
//    while (1) {
//      Serial.println("Failed to configure Ethernet using DHCP");
//      delay(10000);
  Ethernet.begin(mac,ip,gateway,subnet);
  Serial.print("IP number assigned  is ");
  Serial.println(Ethernet.localIP());
  Udp.begin(localPort);
  Serial.println("waiting for sync");
  setSyncProvider(getNtpTime);
time_t prevDisplay = 0; // when the digital clock was displayed
  if (timeStatus() != timeNotSet) {
    if (now() != prevDisplay) { //update the display only if time has changed
      prevDisplay = now();
      digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
  Serial.println();
void printDigits(int digits){
  // utility for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
/*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
  while (Udp.parsePacket() > 0) ; // discard any previously received packets
  Serial.println("Transmit NTP Request");
  sendNTPpacket(timeServer);
  uint32_t beginWait = millis();
  while (millis() - beginWait < 1500) {
    int size = Udp.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Receive NTP Response");
      Udp.read(packetBuffer, NTP_PACKET_SIZE);  // read packet into the buffer
      unsigned long secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 =  (unsigned long)packetBuffer[40] << 24;
      secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
      secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
      secsSince1900 |= (unsigned long)packetBuffer[43];
      return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
  Serial.println("No NTP Response :-(");
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress &address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  Udp.endPacket();
发表于 2016-4-21 11:22:20 | 显示全部楼层
zhangxiaoyang77 发表于 2016-4-18 09:47
#include
#include
#include
不知道你上级路由怎么设置的,10,0,49,254是你路由器的地址么?
感觉一般家里都直接192.168.1.1了吧。是二级路由器么?
还有你的IPAddress subnet(255,255,255,128);
你把10,0,49,129-10,0,49,254分成一个子网是做什么?
你设置的ntp服务器我没ping通。试试time.nist.gov 的 128.138.141.172
 楼主| 发表于 2016-4-22 15:33:44 | 显示全部楼层
感觉一般家里都直接192.168.1.1了吧。是 ...
我用的公司内网,在家里做的实验室可以的,我用的这个地址是没有问题的。使用的time库函数。是不是内网配置有问题
 楼主| 发表于 2016-4-22 15:34:05 | 显示全部楼层
发表于 2016-4-23 16:03:09 | 显示全部楼层
不太清楚你们公司网络状况,不好硬答了
 楼主| 发表于 2016-6-2 14:32:47 | 显示全部楼层
设置一下dns就可以了
GMT+8, 2026-7-24 03:32 , Processed in 0.034414 second(s), 18 queries .
