查看: 14429|回复: 2
关于W5100和SD卡冲突的问题
发表于 2016-4-24 22:18:39 | 显示全部楼层 |阅读模式
代码如下,W5100初始化成功后,在调用SD卡库就不能对卡进行操作了。
实地检测,如果在5100初始化成功后,把片选直接拉高,sd卡也不能进行操作。
5100芯片内部发生了什么
  Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "185.119.255.57";    // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 199, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
/*TF卡*/
File myFile;
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(10, OUTPUT);
  digitalWrite(10,HIGH);
  digitalWrite(4,LOW);
  if (!SD.begin(4)) {
    Serial.println("init failed!");
    return;
  if (Ethernet.begin(mac) == 0) {
    // no point in carrying on, so do nothing forevermore:
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  delay(1000);
  digitalWrite(10,INPUT);
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
//    // Make a HTTP request:
   client.println("POST /disk/ HTTP/1.1\r");
    client.println("Accept: text/html, application/xhtml+xml, image/jxr, */*");
    client.println("Referer: http://185.119.255.57/disk/");
    client.println("Accept-Language: zh-CN");
    client.println("Content-Type: multipart/form-data; boundary=sosad");
    client.println("Origin: http: //185.119.255.57");
    client.println("Accept-Encoding: gzip, deflate");
    client.println("Host: 185.119.255.57");
    client.println("Content-Length: 613");
    client.println("Connection: Keep-Alive");
    client.println("Cache-Control: no-cache");
    client.print("\n");
    client.println("--sosad");
    client.println("Content-Disposition: form-data; name=\"username\"");
    client.println();
    client.println("surunbing");
    client.println("Content-Disposition: form-dat; name=\"headImg\"; filename=\"test.txt\"");
    client.println("Content-Type: text/plain");
    client.println();
    myFile = SD.open("test.txt",FILE_READ);
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    // close the file:
    myFile.close();
  } else {
    // if the file didn't open, print an error:
    Serial.println("error opening");
    client.println();
    client.println("--sosad--");
    client.stop();
  else {
    // kf you didn't get a connection to the server:
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
发表于 2016-4-24 23:42:51 | 显示全部楼层
用不同的片选引脚
 楼主| 发表于 2016-4-25 00:01:04 | 显示全部楼层
davidce 发表于 2016-4-24 23:42
用不同的片选引脚
片选没有用
GMT+8, 2026-6-14 21:19 , Processed in 0.037061 second(s), 19 queries .
